Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
06-16-2020, 11:16 PM | #15 |
Drives: 2017 Toyota 86
Performance Pack Brembo Rear Brakes
Thanks to @86league, we have some pad radial height data. I recalculated the numbers and now come up with:
OEM base: 69.3% front bias OEM Brembo: 66.3% front bias Stoptech/Brembo: 64.9% front bias Stoptech/base: 69.3% front bias To summarize, it appears that the Brembo rear calipers apply about 14% more torque to the rear rotors versus base calipers, and the net impact of the Brembo performance pack brakes is to shift brake bias rearward by 3%. However, my numbers are different from 86league. Can anyone chime in to double check the math? Sent from my iPhone using Tapatalk Last edited by Chuckable; 06-16-2020 at 11:42 PM. |
06-20-2020, 09:01 PM | #16 | |
Drives: '13 BRZ Limited
Essex tells me their calculations show the stock system system at 65.5% front bias. Parts catalog shows that the front/rear pistons are same part number, so should be the same diameter. Using 40.4mm front and 40.4mm rear with the radial depth info posted above I get 65.56%. Very close to Essex's number. |
06-20-2020, 10:15 PM | #17 |
Thank you, 86league. It’s good to have an actual measurement of the front caliper pistons.
03-29-2021, 06:50 PM | #18 |
Drives: 2022 GR86
Awesome data, thanks for sharing!
Quoted that post in the thread. |
04-05-2021, 05:53 PM | #19 |
Drives: 2017 BRZ w/pp
Trying to find a thread that listed pads and the model numbers that fit the brz pp. If you know of thread I'm talking please share the link.
Sent from my Pixel 2 XL using Tapatalk Last edited by doug1234; 04-05-2021 at 07:19 PM. |
The Following User Says Thank You to doug1234 For This Useful Post: | BrahmaBull1990 (04-07-2021) |
06-13-2021, 05:25 AM | #21 |
Drives: 2014 GT86
Garvin29: obviously it can be. But: 1) stock wheels won't clear, 2) while PP brembos is good deal when bought anew, when you source it from parts for retrofit, it's cost gets unreasonably high, higher then that of aftermarket offerings.
07-20-2023, 01:31 PM | #23 |
Drives: Subaru BRZ 2017
sorry for reviving old thread.. So What's the verdict on mixing the stoptech with the rear brembo for daily/street driving?
07-20-2023, 02:55 PM | #24 | |
and also I realized no one brought up suspension suspension compared to OEM.
A stiffer setup would benefit with less front bias in comparison to OEM. So based on this: Quote:
Similar Threads | ||||
2017 BRZ Performance Package Brembo Brakes Part Numbers | Veloist | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 146 | 04-27-2023 09:36 AM |
SOLD: Performance Package Brembo Brakes. NEED TO MOVE! | Desain2137 | Brakes, Suspension, Chassis | 2 | 04-12-2020 01:11 AM |
Performance pack brakes | Jdmuscle | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 7 | 03-11-2019 05:05 PM |
FS; Brembo Brakes Performance PCKG 900 miles brz/frs | sokol | Brakes, Suspension, Chassis | 21 | 02-27-2019 01:15 AM |
WTB brembo bbk (performance pack preferred) | Mo | Want-To-Buy Requests | 2 | 12-28-2018 12:13 AM |
