Old 07-23-2021, 05:49 PM   #1
786speed
2013 with 65k and rod knock. Getting motor replaced, what else should I do?
So my 13 BRZ manual got the dreaded knock and luckily the repair is covered by the dealer. Since the motor is coming out, is there anything else I should maintain or upgrade at this time? Any upgrades I can do to prevent this from happening again?
786speed is offline   Reply With Quote
Old 07-24-2021, 02:10 AM   #2
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
Rocker Clips: https://denstoj.com.au/products/fa20...r-retainer-kit
Updated Throw out bearing for trans
Consider a upgraded clutch fork: https://www.verus-engineering.com/sh...tegory=1#attr=
Consider upgraded clutch fork pivot: https://www.verus-engineering.com/sh...tegory=1#attr=
Consider STI FA20 engine mounts
Consider poly bushing for the transmission (whiteline &/or perrin)
Consider replacing your Spark plugs AND coilpacks
The Following 4 Users Say Thank You to Bonburner For This Useful Post:
Denstoj (10-11-2021), humfrz (07-24-2021), kevaughan (10-16-2021), Spankopotomous (07-24-2021)
Old 07-24-2021, 02:20 AM   #3
jflogerzi
jflogerzi's Avatar
All perfect recommendations!
2013 Series 10 FRS #553
The Following User Says Thank You to jflogerzi For This Useful Post:
Old 07-24-2021, 12:04 PM   #4
TommyW
TommyW's Avatar
Drives: '13 Whiteout
The most important upgrade is to make sure the tech doing the work is versed on replacing the timing cover. You can do all the other upgrade mentioned that you want however ANY sealant, old or new, that gets in the engine and you'll be right back where you started
TommyW is offline   Reply With Quote
Old 07-24-2021, 08:40 PM   #5
radroach
Drives: car
-Subaru throw out bearing. New improved part, new part number
-Verus forged clutch fork
-Verus billet clutch fork pivot
-Front Bearing Retainer Cover
Old 07-27-2021, 10:51 PM   #6
BoxerRumble
Drives: 2015 Blue BRZ
I am in a similar situation, and I have been told get them to put in new spark plugs (to avoid 4 hrs of labor in the future), get that verus clutch fork, and probably an OEM Exody clutch itself (but you can ask them to look at how worn out your clutch is now, if it makes sense).
However I agree, most importantly, be sure that whoever does this recall has done many before, without issues. My car was apparently worked on by the best master technician at a dealer that has done many of these, but it had the issue. I may be getting a 2013 engine without the recall done. That is fine with me, I don't want them to do the recall and be right back where I started. Also ask about what your dealer will do if you get issues after the recall. Apparently there is no warranty on the recall work (despite some people saying there is) but your dealer may cover it in "good faith" if something goes wrong.
BoxerRumble is offline   Reply With Quote
Old 10-04-2021, 05:56 PM   #7
jeepmor
Drives: 84 CJ7, 08 Duramax, 2014 FRS
Consider an upgraded block and throw a turbo or SC kit in there, and everything bonburner mentioned.
jeepmor is offline   Reply With Quote
Knocking sound post recall, now i am told my motor needs to be replaced D_N_A Issues | Warranty | Recalls / TSB 15 12-11-2020 06:16 PM
2013 BRZ won't turn over replaced starter, battery, st cut relay dewittk Issues | Warranty | Recalls / TSB 22 02-07-2020 07:53 PM
2013 FRS engine for sale (rod knock) Yikes54 Engine, Exhaust, Transmission 0 04-29-2019 03:58 PM
Stock motor started knocking... (shortblock + more replaced, 1/18) resolved MarkR171 Engine, Exhaust, Transmission 139 01-18-2017 06:25 PM
4,000miles, 13x in for service, 2 computers and 1 motor replaced P5yk0t1c Issues | Warranty | Recalls / TSB 49 11-04-2013 06:20 PM
