Cosmetic Modification (Interior/Exterior/Lighting) Discussions about cosmetic mods. |
05-17-2018, 08:55 PM | #1 |
Drives: 2015 Firestorm FRS
Installing nur spec wing
Has only 2 small holes each side And double sided tape. Will it be stable and will not drop off when i hit the freeway? Thanks http://imgur.com/a/xxTQ7sK |
05-17-2018, 11:43 PM | #2 |
Drives: 2015 BRZ Limited CWP
no
The Following User Says Thank You to sugoi For This Useful Post: | x808drifter (05-18-2018) |
05-18-2018, 12:08 AM | #3 |
05-18-2018, 05:15 PM | #5 |
Sarcastic SOB
I think 2 sided toupee tape should do the job.
Actually, they look a lot like WRX STI wings. I'm going to take a look in the garage... ...the bases are quite wide and stable looking. Peeking under the edge of the deck lid liner there appears to be 2 bolts per side in a 45 degree config relative to front/rear. No doubt some type of backing washer possibly with something to dampen contact with the sheet metal.
Similar Threads | ||||
Installing/Wiring Spec-D FRS lights into my Subaru BRZ | subtledriver | Cosmetic Modification (Interior/Exterior/Lighting) | 14 | 04-28-2018 01:53 PM |
Installing Spoiler Authority rear wing | blkwrxwag | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 06-06-2017 02:00 PM |
Nur Spec GT Wing / OEM Euro Spec Wing | SmireyFase | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 10-27-2016 02:03 PM |
Help installing wing? | MObrz5 | Northern California | 8 | 08-03-2014 01:14 PM |
Need urgent help installing the Spec D headlights up and running. | aznknightz17 | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 07-16-2014 02:17 PM |
