BRZ First-Gen (2012+) -- General Topics All discussions about the first-gen Subaru BRZ coupe |
02-10-2015, 07:29 PM | #1 |
Drives: 2014 SWP BRZ
Question about brz/frs tpms compatibility
Let's say I purchase oem frs wheels/tires and put them on my brz. Can I just as easily sync to the frs tpms with my
Brz ecu?? Thanks I haven't been able to find an answer. Sent from my iPhone using Tapatalk |
The Following User Says Thank You to Evo2Brz For This Useful Post: | HolyAssertion (02-12-2015) |
02-10-2015, 07:43 PM | #2 |
Drives: 2014 Subaru BRZ Limited WRB AT
I have a second set of BRZ OEM wheels and took the car to my Subaru dealer to reprogram the ECU - they told me to take it to Toyota since they didn't have the (Toyota) equipment yet to do the reprogramming! So I did and it was fine - but I asked the Toyota dealer to write down both sets of codes.
Then I bought the ATQ QuickSet tool and entered all the codes (summer/winter). This past fall I did my own reprogramming and it worked fine. It's a Toyota system so I can't believe that the FRS wheels would have a different TPMS than the BRZ wheels.
Cosworth Drop-In Air Filter, Diode Dynamics DRL module, Perrin Tips |
02-10-2015, 08:05 PM | #3 |
Great info. So basically, I put the frs wheels on my brz, take it to a scion dealership and they can set it up for me?
02-10-2015, 11:12 PM | #4 | |
02-11-2015, 01:42 PM | #5 | |
In your case either the dealer reprogrammed your codes or you haven't driven far enough since the last "sniff" (assuming you store your alternate wheels near your car).
02-11-2015, 01:59 PM | #6 |
That should work. Your Subaru dealer *may* by now have the tool also. Be aware that the cost for this service 1 time is almost the cost of the ATEQ tool. ($100 ish).
02-11-2015, 04:30 PM | #7 |
new set of tires and wheels from tire rack, light came on and stayed on, even thought parked next to old tires. went to the Subaru dealer and asked them to reprogram them. they said no can do. went home and found an update bulletin from Subaru telling them to get an update to do it. back to the dealer with bulletin number in hand. they were not happy with me for telling them their job, but two hours later they got it done.(that was a year ago so I have no idea where I got the number on the internet) I had to pay for their time to do the update. will be getting the tool this spring. I have heard the ATEQ is not easy but will work if you are persistent.
The Following User Says Thank You to ls1ac For This Useful Post: | jetsevo4 (02-12-2015) |
02-11-2015, 09:44 PM | #8 | |
02-11-2015, 10:34 PM | #9 |
So to some it all up... Frs tpms sensors are compatible to sync with a brz?
02-12-2015, 01:23 AM | #10 | |
Drives: '15 brz
02-12-2015, 09:00 PM | #11 | |
Drives: Traded BRZ for Supra
Keep in mind that sensors have to be activated. Usually it requires letting all air out of tire and filling it again. |
02-13-2015, 08:19 AM | #12 | |
1. (Follow the directions to) use the tool to read the codes for the wheels currently programmed into the car. 2. Upload those codes to the PC program. 3. Enter the new codes for the alternate wheels into the PC program. 4. Write the new codes to the tool. 5. Use the tool to reprogram the car after the new wheels are mounted. If you follow the directions and do this exact sequence there should be no confusion. It was somewhat confusing when I had both sets of codes on paper and tried to load both into the PC and the tool before attaching the tool to the car. I got it to work, but I had to scratch my head a couple of times. Full disclosure: I am an experienced software engineer.
02-14-2015, 04:40 AM | #13 |
Drives: Subaru BRZ
Do you really NEED the TPMS system? I mean, can't you just check the pressures every so often like we used to? If so, just take out your sensors and enclose them in a PVC tube sealed on both ends. Let the nozzle of one stick out of the tube so you can use it to fill the tube to the required PSI. Set the assembly in the trunk, and you're done. Never have to worry about sensors in wheels again. So much easier than paying for a reset and going through that silly process.
02-15-2015, 07:17 PM | #14 | |
Similar Threads | ||||
Question on swapping TPMS | Cards2323 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 3 | 05-12-2014 06:09 PM |
TPMS question | damaster32 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 01-25-2014 10:12 AM |
tpms noob question need help | juanam0909 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 10-29-2013 01:09 PM |
TPMS Question | Randyliciious | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 12 | 10-03-2013 02:03 AM |
TPMS Sensor Part Number or Compatibility | civicdrivr | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 15 | 11-07-2012 01:06 PM |
