02-15-2018, 02:29 AM | #169 |
Drives: 2013 Scion FRS
Thank you @Chaetagnath, @phanguy, @DustinS. I was able successfully execute a fully functioning Dual Climate control swap.
Vortech V3 Supercharger| 12 PSI|E85 MotoEast Flexfuel kit|Crawford AOS| Mishimoto Oil Cooler|3"Perrin Resonated CBE| 3" JDL Front/Over Pipe|OpenFlash Performance Headers|Exedy Stage 2 Ceramic Clutch |Yonaka Coilovers|17x9 O.Z. Wheels| 245/40r/17|TRD Brake Pads|Perrin Master Cylinder Brace |ChaseBay SSBrake Lines|CF Side Fins|OEM Shark Fin Athena|Yospeed Console Plaque|R/T Shift Knob|Fog Lights|Backup Camera|Navigation| |TRD Quickshifter|Motul Gear Oil|
The Following User Says Thank You to FRSToyota86 For This Useful Post: | DustinS (02-15-2018) |
02-15-2018, 07:58 AM | #170 | |
Drives: Whiteout FRS
02-15-2018, 09:30 AM | #171 |
Drives: 2013 Ultramarine FR-S
Or at least how you got the dash bar out haha. I have everything I need to finish full dual, but I couldn't get the dash bar out.
02-17-2018, 03:46 PM | #172 | |
What is not mentioned in the write up but perhaps in the manual is that you must pull outer sleeve out. Then there is one bolt that secures the steering column just before the u joint thingy. You have to open that and pull the column out completely. (update: Also its kind of difficult to put the column back over to the shaft. The best way of inserting it back is to pry it open with a screw driver just enough to so it slides back. The slit is right by the bolt you would take out on the last step, which you cant miss.) Note that once you disconnect that your steering might go back together straight. You might have to adjust steering wheel to make is straight and might even have to run Techstream VCS normalization, if the traction and ABS lights comes on.
The Following User Says Thank You to FRSToyota86 For This Useful Post: | DustinS (02-18-2018) |
02-18-2018, 01:00 PM | #173 | |
02-19-2018, 09:36 AM | #174 |
The only thing which is not right at this point is, as soon as I turn the dial to anything besides low, its blowing super hot air. It seems like there is no temp modulation.
Did you have such a problem at all?
02-19-2018, 09:48 AM | #175 |
Make sure the Temp sensor is plugged in and tube is attached. Mine had fallen off somehow. Although I don't have A/C yet as I am LS Swapped, if I had mine set at anything less than "HIGH" it would turn the heat very low and get cold in the car.
You may have to try and calibrate the motors, or set them a certain way.
The Following User Says Thank You to DustinS For This Useful Post: | FRSToyota86 (02-20-2018) |
02-20-2018, 02:20 AM | #176 |
Drives: 2013 White Pearl Toyota FRS
Hey guys! i just saw this post and im really interested in converting into true dual climate control system. so i just want to make sure if this is correct. We need need these items?
Driver side temp control servo: SU003-02045 Damper control servo: SU003-02044 Screws for the servos (need 5 total) SU003-02113 Blower transistor (73533AJ000) the climate control panel: 72311CA061 temperature sensor: 73730CA020 the hose assembly for the temperature sensor: 72313CA010 Connectors: 90980-12155 90980-12554 90980-12248 IL-AG5-7P-S3C1 90980-11918 90980-11909 90980-11135 90980-10796 and wiring for these connectors?????? o.O? |
02-20-2018, 09:18 AM | #177 | |
On occasion when the external temperature is cool, there is a large difference between the low setting and the next up on the auto (65), so it blows warmish. However on normal hot days it is pretty good at blowing cool air throughout. Maybe try adjusting the temp sensor location. |
The Following User Says Thank You to Chaetagnath For This Useful Post: | FRSToyota86 (02-20-2018) |
02-20-2018, 03:23 PM | #178 | |
02-20-2018, 07:39 PM | #179 |
i didnt noticed it at all till u point that out. Thanks. So my question is, with that list and the corresponding connector (IL-AG5-7S-S3C1) are what i need to do a complete swap? If so, i would start duplicating that harness.
02-24-2018, 07:30 PM | #180 | ||
Its working good now. When it comes to the Relay socket regular socket relay is not going to work. I ordered one and no good. So I 3d printed one relay socket, used 9mm male and female slip on connector for the thick relay terminals on both end with a wire in between. The original relay socket Randy used is only available in Europe. I probably should have ordered it, instead of relaying on eBay relays. At the end 3d solution worked just as well.
The Following User Says Thank You to FRSToyota86 For This Useful Post: | Chaetagnath (02-24-2018) |
04-16-2018, 01:21 AM | #182 |
Drives: 2017 86 Asphalt
im going to revive this old thread. Someone on one of the facebook groups claims that on the 17+ 86s (assuming the same for brz premium?) they run same exact wiring harness as the one used on the dual climate control equipped ones. Essentially if this is true, then i wouldnt have to go through the trouble of putting together a new harness for at least single zone climate control. Anybody know or willing to help me do the research to see if there is any truth to this?
Similar Threads | ||||
Wtb:pnp harness for automatic climate control for frs | Sangthing | Want-To-Buy Requests | 5 | 01-02-2015 04:11 PM |
BRZ limited dual climate control | Sangthing | Interior Parts (Incl. Lighting) | 6 | 09-12-2014 06:01 AM |
Ac knobs for BRZ limited / FRS with dual climate | dnizzle | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 08-15-2014 10:43 PM |
FS - BRZ Dual Climate Control Unit | dvsidboy | Audio/Visual, Electronics, Infotainment, NAV | 4 | 01-12-2014 08:52 PM |
