BRZ Second-Gen (2022+) -- General Topics General topics for the second-gen BRZ |
06-16-2023, 09:47 PM | #15 |
Jedi
Drives: Pikachu BRZ
Nail polish never let me down
06-18-2023, 08:27 AM | #16 |
Drives: "I drives like a Porsche"
What color mail polish matches?
06-21-2023, 04:41 PM | #17 |
Drives: '23 BRZ Limited
Why don't you trust hub rings? It's not like they are bearing any load. I've used them on multiple cars without issues.
"95% of the time, more throttle is the answer. 5% of the time, it ends the suspense."
06-30-2023, 01:11 AM | #18 | |
Drives: 2023 BRZ Limited
I have also heard that others had vibration problems with them. Additionally, I don't know for sure, but I'm thinking that they actually are load bearing. Don't they form a cone shape that centers the wheel on the hub? If so, once wheel bolts are tightened, I would imagine that the cone carries a little bit of force at least? The wheel bolts have the taper, which obviously positions the wheel, but then it seems to me that the full weight will rest on just the bolts, vs. being distributed over the bolts, and the hub. I don't know for sure, but if it didn't matter, why would OEM wheels sit on the hub that way? I just figured that if I'm tracking the car, and putting excessive forces on the wheels/tires/hubs, I want to have the strongest and most solid connection. I may be wrong about all of that, but I'm just trying to use logic. |
06-30-2023, 12:14 PM | #19 | |
For aftermarket wheels, it's easier to make a larger bore and fill the space with a hub ring. Sure they could make a small bore and machine it out to each specific application, but you're adding a lot of cost and the need for inventory sitting around and have the machinery, or having to ship the wheel to a 3rd party for machining before being sold. You technically don't even need hub rings as the lugs should center the wheel as it's tightened down. I always had issues getting it perfect that way, so I use hub rings to center the wheels on the studs/bolts. The hub isn't carrying any load after that, it's all in the bolts/studs. Never had an issue with multiple wheels on multiple different vehicles. Don't know anyone who has either. A lot of people will repeat things they've read with no personal experience because they think it makes them seem knowledgeable.
Similar Threads | ||||
sold | mib911 | Cars for Sale/Trade | 1 | 07-21-2023 01:06 AM |
Big paint chip, is touch up paint sufficient enough? | simplydang | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 6 | 03-02-2015 05:41 PM |
Touch up paint | Ryan86 | AFRICA | 71 | 10-16-2013 08:19 AM |
Where to buy touch up paint? | czar07 | AUSTRALIA | 10 | 11-10-2012 08:13 AM |
