Forced Induction Turbo, Supercharger, Methanol, Nitrous |
07-19-2013, 09:13 PM | #29 | |
Love Boost!!!!!!!!
Drives: Whiteout Scion FR-S
i wish u had a 3 inch ecxhaust from overpipe to muffler
07-20-2013, 01:26 PM | #30 |
Corner Junkie
Drives: 13 BRZ, 11 STI, 99 RS
I'm bouncing between a couple options. The big roadblock at the moment is the header. I like the Nameless or FA20Club design. But I'm going to be running the Robispec radiator/oil cooler system so I'm worried about clearance. The problem is that it's tough to find a good EL 4-2-1 header. The HKS looks like a good choice, but it's pricey for a catless header.
Grumble-grumble. The catback is up in the air since I want something with volume and good tone because I'll only have 1 high flow cat. But I don't want it so loud that I can't enjoy that twin-screw whine. The ARK exhausts look and sound great. And that pTuning exhaust looks good too, but I haven't heard it yet. My biggest concern that is that the axleback flange isn't the lowest point. I've already damaged my Accelerated Performance catback because of that issue. So we'll see. Lots of choices. Lots of worries. But if someone were to make me choose at this very moment, it'd be: HKS EL catless header Nameless catted over/front with resonator ARK GRiP catback But as always, choices are subject to change until they're paid for. |
07-20-2013, 07:11 PM | #31 |
Drives: 2013 FRS
on vortech have ark test pipe and grip catback
07-21-2013, 07:00 AM | #32 |
Looks like the turbo heads are going with 3" diameter exhausts. I'm curious if the super charger heads are going with 3" exhaust too. Me thinking is that turbos provide the neccessary back pressure, therefore they can go 3" no problem. But, SC setups don't have anything inline to give back pressure, other than the cat and exhaust itself. So would a 3" exhaust be too big for a say, factory TRD super charger ?
07-21-2013, 08:29 AM | #33 | |
With a boosted car the intake manifold is under pressure, so the old volumetric efficiency math goes out the window, and you pretty much just want to get the exhaust out of there as quickly as possible. On a turbo car you want even less, as turbine efficiency is improved across the board by lower exhaust backpressure after the turbo (turbos work on pressure differential between the exhaust manifold and downpipe). Unfortunately none of the currently available supercharger kits make enough power to really require anything bigger than 2.5" exhaust (300whp is the general rule as to when 3" becomes beneficial). |
The Following User Says Thank You to jamesm For This Useful Post: | invzabomaster (07-22-2013) |
07-21-2013, 10:05 PM | #34 | |
Drives: White FR-S
After we finish with our 3" midpipe, we'll develop a 3" frontpipe too. |
07-21-2013, 10:09 PM | #35 |
Drives: Scion FRS
Since a 3inch overpipe wont fit how close to 3inches can you get? 2.75?
07-21-2013, 10:14 PM | #36 | |
Drives: White FR-S
Chambered mufflers, convoluted exhaust routing, and constricted or heavily louvered mufflers will affect your hp potential, especially on a higher powered turbo applications. Our exhaust is positioned as close to the rear subframe as is physically possible with a 3" tube. |
07-21-2013, 10:17 PM | #37 |
Drives: White FR-S
We haven't really tried fitting a 3" overpipe, since our turbo system uses an optimized 2.5" overpipe for our turbine inlet. However, it seems that shops that have tried have gone with a 2.75" overpipe.
07-22-2013, 08:42 AM | #38 |
3" exhaust or 2.5"
07-22-2013, 09:26 AM | #39 |
07-22-2013, 09:36 AM | #40 |
Drives: Scion FRS
Intrested in seeing how that ptuning setup sounds with a catless front pipe and the turbo kit.
hint hint |
07-22-2013, 10:05 AM | #41 |
Drives: 2013 SWP BRZ
I'm going with JDL UEL header - stock over pipe - Tsudo catted front pipe - ARK DT-S Exhaust. Running the Innovate S/C. Hoping its not too loud or there will be a change made somewhere in the system.
07-22-2013, 10:13 AM | #42 |
Drives: White FR-S
Our shop car is being put back together with all of our production turbo system parts, including our full 3" exhaust. As soon as we get everything in place, we'll make another video. It'll likely be one of the quieter straight-through 3" exhaust systems on the market.
The Following User Says Thank You to ptuning For This Useful Post: | dabocx (07-22-2013) |
Similar Threads | ||||
Loud exhaust / Buddy Club Spec II exhaust help! | chiefshayan | Engine, Exhaust, Transmission | 26 | 12-06-2019 05:59 PM |
Exhaust System/Exhaust Manifold Removal and Replacement | GrimmSpeed | DIY (Do-It-Yourself) Guides | 52 | 11-11-2015 09:30 PM |
Perrin Catback Exhaust vs Nameless Performance Exhaust. | vignesh | Engine, Exhaust, Transmission | 201 | 06-05-2013 09:47 PM |
Can someone explain the diffrence between catback exhaust and axleback exhaust? | speedy racer | Engine, Exhaust, Transmission | 12 | 09-23-2012 12:24 PM |
Catback Exhaust vs Axleback Exhaust – What’s the difference? | phenom86 | Engine, Exhaust, Transmission | 10 | 07-28-2012 09:08 AM |
