Old 07-11-2013, 05:07 PM   #1
gvan1998
Drives: Blue FRS
FR-S TRD Lowering Springs and Sway Bars releasing soon
I just found out the part number for FRS TRD lowreing springs: PTR07-18130. I read somewhere it suppose to have a 1 -1.5 inch drop.
Found a part # for TRD Sway bar also PTR11-18130
gvan1998 is offline   Reply With Quote
The Following 5 Users Say Thank You to gvan1998 For This Useful Post:
BabaYaga (02-16-2015), cdo221 (07-11-2013), kaybee123 (03-06-2014), Mandy (07-12-2013), red1993sol (01-17-2014)
Old 07-11-2013, 05:14 PM   #2
cdo221
Drives: 2013 Ultramarine FR-S, 2015 RS 1.0
Nice, can't wait to see it. This is TRD USA right (since you said it's for the FRS), not JDM TRD?
cdo221 is offline   Reply With Quote
Old 07-11-2013, 05:14 PM   #3
DuMa
DuMa's Avatar
Drives: LR BRZ Limited
most likely these are rebranded springs
DuMa is offline   Reply With Quote
Old 07-11-2013, 05:15 PM   #4
husker741
Drives: 2013 Whiteout Scion FR-S 6MT
If they drop that much, I'll consider buying them and selling my RCEs, cuz these will be under warranty. BUT, it's TRD, so it'll probably be the price of most coilovers.
husker741 is offline   Reply With Quote
Old 07-11-2013, 05:26 PM   #5
gvan1998
Drives: Blue FRS
This is a part # from Toyota USA.
Old 07-11-2013, 05:29 PM   #6
trd_kid
13anned.
trd_kid's Avatar
Drives: Firestorm FR-S
googled the part number and it appears to be legit
http://www.toyotaracing.com/trd/cata...g_lowres_R.pdf
page 16
trd_kid is offline   Reply With Quote
Old 07-11-2013, 05:34 PM   #7
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Smile
0_o FR-S ‘13, FRONT AND REAR PTR07-18130
Its legit but eh, might be pricey from a dealer and install point.
Old 07-11-2013, 05:38 PM   #8
gvan1998
Drives: Blue FRS
I posted a link where you can preorder it. The price looks like 210 USD, cheaper than most aftermarket springs. I should of waited for TRD instead of installing Eibachs.
Found a part # for TRD Sway bar also PTR11-18130 http://www.toyotaterritory.com/scrip...idproduct=1733
Old 07-11-2013, 05:46 PM   #9
bear89103
Old Fart
bear89103's Avatar
Yeah I love my Swift springs, but dang.. 210 is a pretty dang good price.
And it stays all warranty approved. Damn.
bear89103 is offline   Reply With Quote
Old 07-11-2013, 05:51 PM   #10
monkeedoo
Senor Member
monkeedoo's Avatar
Drives: ME CRAZY
now will these still mess up your shocks??
monkeedoo is offline   Reply With Quote
Old 07-11-2013, 05:57 PM   #11
tennisfreak
Drives: 2018 BMW M240i
Hmmm if they are $210/per shock then what can we guestimate on price for all 4 installed?
$1200? If so would you pay that much? I might.........
Also monk why you ask if they will mess up your shocks?
The Following User Says Thank You to tennisfreak For This Useful Post:
CatDaddysBBQ (03-17-2014)
Old 07-11-2013, 05:59 PM   #12
kALMIGHTY
Drives: TRD Ultramarine '13
No they won't. TRD springs are made to work with stock or upgraded shocks and/or struts so you could use either. If they mess up in any way, like if you end up with blown struts, they'll be replaced under warranty because these are TRD parts.
Unless of course you got the TRD parts installed by a third party and Toyota rules out that any damage was caused by improper installation by the third party, in which case you'll be SOL.
The Following User Says Thank You to kALMIGHTY For This Useful Post:
monkeedoo (07-11-2013)
Old 07-11-2013, 06:00 PM   #13
monkeedoo
Senor Member
monkeedoo's Avatar
Drives: ME CRAZY
i was under the impression any lowering springs will wear out stock shocks in around 5k miles and if so would that be covered under warranty?
Old 07-11-2013, 06:00 PM   #14
kALMIGHTY
Pretty sure that's the price of the set of 4. Front and rear, according to the part number. If that's the case, they're right around the price of other lower springs like RCE's or Eibachs. I'm pretty sure the TRD springs will just be rebranded Eibachs anyway.
Lowering Springs|Alignment Kits|Strut bar|Sway Bars|Strut Mount +More SOURCE,LLC Brakes, Suspension, Chassis 445 05-11-2015 05:41 PM
ST Suspensions Lowering Springs & Anti-Sway Bars Now Available @ BMS! Boston Motorsports Brakes, Suspension, Chassis 84 07-23-2013 11:42 PM
Stock springs and sway bars Spencer Brakes, Suspension, Chassis 3 04-25-2013 09:41 AM
FR-S/BRZ SWAY BARS & STRUT BARS @ NINJA AUTOSPORTS!!! NJA Brakes, Suspension, Chassis 18 04-07-2013 06:00 PM
**The Eibach Thread** Springs, Coilovers, Sway Bars @ Pure Automotive Pure Automotive Brakes, Suspension, Chassis 1 02-06-2013 02:32 PM
