DIY (Do-It-Yourself) Guides For all DIYs. |
05-23-2013, 09:49 AM | #15 |
Drives: Ultramarine '13 FR-S
so you didnt detach the airbag at all? did you at least remove fuses or disconnect battery? Also could you share a link or a source for that emblem? Looks great btw
edit: read your website..got all the info i need. thanks! Last edited by UltraMarine86; 05-23-2013 at 09:50 AM. Reason: read your website..got all the info i need. thanks! |
05-23-2013, 10:15 AM | #16 |
AKA Mugen Dom
Drives: 2013 FR-S, 2007 FJ Voodoo Blue
I removed the airbag, then removed the charge after grounding myslef...Im not big on things exploding in my face from stray voltage. It took all of 5 minutes to remove the airbag and charge.
I also didnt want plastic shavings in my brand new car :/ |
05-23-2013, 12:12 PM | #17 |
Drives: 2013 Whiteout Scion FRS
I was going to but I could not get the airbag to pop off through the little holes and did not want to mess anything up so I went with leaving it in.
05-23-2013, 12:16 PM | #18 |
AKA Mugen Dom
Flathead screwdriver, push the clips in on the sides then the bottom theres 3 total...for future reference...and others. I work with explosives the airbag is an explosive charge essentially. Not something to take lightly.
05-30-2013, 01:15 AM | #19 |
Drives: GT86
I put my airbag back.
Now, the airbag and traction control idiot lights are on permanently....any advice?
...my turn...
05-30-2013, 08:39 AM | #20 |
AKA Mugen Dom
seems like you connected the wires wrong....diconnect the battery pull the bag and check the wiring to make sure theyre on the correct side...thats what I would do...might have messed a wire up even...doubt it but maybe.
07-02-2013, 06:09 PM | #21 |
Drives: 2003 Camry Blue | 2013 FR-S White
I'm about to do this soon to my car. I wanted to know if you had to hold the airbag or after you push the pins do they pop out? The original DIY was kinda vague in the description and said to pull on it -- not sure if that's such a good idea.
07-02-2013, 08:40 PM | #22 |
Drives: '14 Monogram FR-S(RIP)
Did you make sure not to allow the clock spring to move? Check all your connections and pray that was the only problem. A snapped clock spring will cost you about $250 or more just for the part.
07-03-2013, 08:37 AM | #23 |
AKA Mugen Dom
Its not going to fall out if thats what your worried about. Theres 3 clips that hold it on not two like the original DIY thing said also.
The Following User Says Thank You to Fett4Real For This Useful Post: | CamryDS (07-03-2013) |
07-03-2013, 07:30 PM | #24 |
Awesome, I figured after I try it I'm going to write a supplement to describe the process better. I wasn't sure if you just pressed on the 3 pins will you hear it pop up, and you slowly pry it out or you had to jerk it out of the steering wheel. I don't like to go crazy rough while doing this since the interior plastics are SO craptacular and soft.
07-03-2013, 08:41 PM | #25 |
AKA Mugen Dom
If anything it will want to pop back in
07-12-2013, 04:18 AM | #26 |
Shipping to Hawaii?...
Drives: '13 Asphalt FR-S
Jadewbj is there any chance you have the link from ebay? I'm finding the sizes to be larger than the original airbag emblem size.
~Matt
Efimia (asphalt FRS) |
07-12-2013, 08:04 AM | #27 | |
They told me it was from a prius. |
07-12-2013, 09:07 AM | #28 | |
AKA Mugen Dom
Similar Threads | ||||
Toyota logo instead of Scion on the Airbag? YES please :) | doggy | Cosmetic Modification (Interior/Exterior/Lighting) | 72 | 02-04-2016 10:55 PM |
Swap your Scion key emblem for a Toyota | Synack | Scion FR-S / Toyota 86 GT86 General Forum | 6 | 08-03-2012 05:58 PM |
Toyota MR2 motor swap | Abflug | Other Vehicles & General Automotive Discussions | 18 | 01-12-2011 06:12 PM |
