07-09-2013, 04:19 PM | #757 |
Drives: FR-S 10 #103 AT
I read something somewhere that gave me the distinct impression that he pretty much is the company.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid." |
07-09-2013, 04:26 PM | #758 |
Yeap, judging by some proposed setups so far, pretty scary indeed. At least get someone with electrical/electronics/controls major/eng to tag along....
07-09-2013, 05:06 PM | #759 |
My experience is in programming, specifically as it applies here to embedded systems. I've also done quite a bit of solid modeling, fea and machine work (I went to school for mechanical engineering and worked in the field prior to switching careers). I can offer those skills, but we'd definitely need someone good with pcb design (I've only dabbled in laying out custom pcbs) and electrical engineering. Surely someone here does that sorta stuff for a living.
07-09-2013, 05:14 PM | #760 |
As Mr. Neutron pointed out, this discussion should move to a different thread.
07-09-2013, 05:40 PM | #761 |
Drives: VW
The motor has no part # or model #, it is completely custom after many iterations.
07-09-2013, 05:48 PM | #762 | |
Drives: VW
The batteries are more of a 'cycle' use than deep discharge. The VW is 14 months with no degradation. 36 volts really is a different beast. Of course I've worked on higher voltage of various battery types, higher voltage units will be primarily to increase max flow not pressure. I hope to do my Wk2 SRT8 some day Rob |
07-09-2013, 06:06 PM | #763 | |
Drives: '13 GBS Subaru BRZ
http://www.ft86club.com/forums/showt...02#post1056302 I'll be updating it with some of the details/ideas I've had later.
07-09-2013, 06:46 PM | #764 | ||
That Guy
Drives: 2013 asphalt FRS MT
And another question, what kind of current draw are you seeing with the present configuration? I'm wondering about circuit breaker sizing. |
07-09-2013, 07:12 PM | #765 | |
Again, great job on pioneering the setup and working with the guys on here, I can't wait to see where you take it in the future. |
07-09-2013, 07:13 PM | #766 | |
Drives: VW
Circuit breaker? Like for an RV? I de-rate through logic and software. Rob |
07-09-2013, 09:40 PM | #767 | |
That Guy
And I'm wondering about a circuit breaker for safety. Something like the ones I use for stereo installs. http://www.delcity.net/store/High-Am...akers/p_167861 |
07-09-2013, 09:49 PM | #768 |
What's the lowest throttle setting so far? I went fora drive today, and I doubt I reached 80% throttle at all.
07-09-2013, 10:19 PM | #769 |
Drives: Raven Black
@Robftss I think it would be great if this system could tie into the ECU somehow and activate at a selectable RPM.
As we all know the shift light built into the car can be adjusted to activate at a range of RPM (I am not sure of the full range) but lets say from 3000-7400. I think it would be ideal if it could tie into this somehow. With the E-charger having the ability to activate at any selectable RPM it would make it so the system was easy to essentially 'turn on and off'. It would also allow full throttle application lower than the selected rpm without the E-charger activating. It would also allow the system to activate when not at full throttle. It would allow for a lot of adjustability. |
07-09-2013, 11:08 PM | #770 | |
Drives: 2001 Sunfire GT + 2007 Mazdaspeed3
You're asking about the lowest throttle setting, so I have a few questions for you. Why are you interested in lower throttle settings? Since you doubt you even reached 80% throttle, you obviously didn't need more power. If you wanted more power, you'd have gone to 90% or all the way, right? Now you seem to be wondering whether this might come on at lower throttle settings. What would you gain there? You obviously didn't need more power, as you had power to spare as it is. Do you see what I'm getting at? If you're not going to full throttle, then you're not using all the power you already have. Now, if you DID want more power, then you'd be giving it more throttle, and if you got to the end of what you'd have normally had, this gives you even more. |
Similar Threads | ||||
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras | Circuit Motorsports | Member's Car Journals | 4 | 03-21-2013 04:45 PM |
Subaru BRZ : Full Throttle, powerslide, hard revving & ride | ESBjiujitsu | BRZ Photos, Videos, Wallpapers, Gallery Forum | 20 | 05-30-2012 06:43 PM |
86 Full Throttle Video + another. | Aus86 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 2 | 04-02-2012 07:07 AM |
