Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
01-24-2015, 02:10 AM | #113 | |
Drives: 1FRS, 1 BRZ, 2S2000s, Evo8, Dak.R/T
Sorry if that's not the answer you're looking for, just thought it might help.
The Following User Says Thank You to killboy For This Useful Post: | 86•BRZ (01-24-2015) |
02-26-2015, 09:51 AM | #114 |
Drives: 13 BRZ Limited 6MT GBS
Having some issues with mine and wondering if anyone else has dealt with something similar. I set it up with the codes for oil temperature and it was working fine for a few days but then stopped working. There is no number displayed for oil temp now. I did a reset and that didn't help, I blanked out the x gauge and made a new one with the correct codes and that didn't help, I disconnected the scangauge and drove around for awhile and reconnected it and that didn't help either.
One thing I noticed at the same time as it initially broke was that the default display for water temperature changed from "deg F WT" to just "LWT", but it has since changed back.
11-01-2015, 07:01 PM | #115 |
Drives: Moped
Still looking for anyone with an aeroforce scan gauge installed to give impressions/pics...
01-18-2016, 07:36 AM | #116 | |
Drives: 2013 FRS / 2013 427 Vert
Code for boost ??
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor 2016 Audi TTS APR Tuned |
01-29-2016, 06:56 AM | #117 | |
[SIGPIC][/SIGPIC]
08-06-2016, 10:34 PM | #118 |
poor man's evora
Drives: Turbod BRZ
poor mans' P3 Gauge
04-07-2017, 03:51 PM | #119 |
Drives: 2014 Scion FR-S
So all I need to get things like air fuel and oil temp is get a scangauge and use these codes? Does the scangauge come with everything I need?
06-08-2017, 01:56 PM | #120 | |
Drives: '17 86
07-09-2017, 11:09 PM | #121 |
Drives: 2017 Toyota 86 Raven
The Following 2 Users Say Thank You to Nosreves For This Useful Post: | 86TOYO2k17 (12-15-2018), cat94 (07-10-2017) |
12-15-2018, 05:54 PM | #122 | |
Drives: 2017 toyota 86
I got AFR and auto trans temp working fine. Boost and coolant temp work fine. Just need that oil temp to work. Any find a working code for 2017+ ? |
12-16-2018, 08:07 AM | #123 |
22R
Drives: 2012 Camry SE 2017 Toyota 86
I could never get the oil temp to work on my 2017 86 either ???
22R |
02-25-2019, 04:21 PM | #124 |
Scangauge sent me a datalogger to get some codes for the 2017 86 auto, although i am sure most should work for MT and possibly the BRZ.
Description TXD RXF RXD MTH NAME Notes Air to Fuel Ratio (#) 07E02104 056146040000 4010 006408B80000 A/F Ambient Temp (°F) 07E02101 032100000000 3008 00090005FFD8 AMB Battery Current (Amps) 07E02144 032580000000 4010 0140007DB1E0 AMP Battery State of Charge (%) 07E02145 03218000000 3810 000100010000 SOC Catalyst Temp Bank 1 Sensor 1 (°F) 07E02105 046105050000 3810 00090032FFD8 C11 Engine Oil Temperature (°F) 07E02101 032500000000 4808 00090005FFD8 EOT Battery Temperature Estimate (°F) 07E02145 056106450000 4010 0009000AFFD8 BAT Fuel Pressure (High) (PSI) 07E02101 032400000000 4010 001D00140000 FPH Fuel Pressure (Low) (PSI) 07E02101 032500000000 2810 001D00140000 FPL Fuel Pump Duty (%) 07E0213A 032100000000 3010 000A06670000 FPD Injector Timing (microseconds) 07E0213C 032100000000 1810 000100010000 INJ Current Gear (#) 07E02122 056106220000 3808 000100010001 GER Transmission Fluid Temperature (°F) 07E12182 046105820000 2808 00090005FFD8 TFT Engine Torque (ft-lbs) 07B02105 032100000000 2011 001703E80000 TRQ 4.51+ Last edited by 86TOYO2k17; 02-26-2019 at 09:22 AM. |
03-28-2019, 09:50 PM | #125 | |
Benz Tech
Drives: 2017 BRZ Premium
12-26-2022, 11:11 AM | #126 |
Drives: 2023 BRZ
I am sorry for bumping such an old post, but I figure if anyone does know this would be the most convenient place for others to find in the future.
Anyone happen to get oil temp working on 2022+? I've tried both of these for Fahrenheit with no joy... Code:
07E02101 032500000000 4808 00090005FFD8 07E02101 010702E80324 3008 00090005FFD8 # Edit to add also tried this one from here: https://www.gt86ownersclub.co.uk/threads/ultragauge-finding-oil-temperature-as-custom-gauge.19764/ 07E02101 010702E80324 3008 00010001FFD8 Edit: I ended up finding this thread: https://www.ft86club.com/forums/showthread.php?t=147905 . Seems like it may just be limited data available through OBD2 without making requests via SSM. Thanks to @timurrrr and @DocWalt for the work and documentation. Last edited by nissanfanatic; 12-31-2022 at 03:56 PM. |
Similar Threads | ||||
FT-86 low temp THERMOSTAT | ft86-UAE | Engine, Exhaust, Transmission | 52 | 08-30-2016 03:46 PM |
A/C Oil/Water temp gauge | Exhaust | Scion FR-S / Toyota 86 GT86 General Forum | 16 | 02-07-2013 01:19 PM |
Engine oil temp now available in Torque App | Yruyur | Engine, Exhaust, Transmission | 8 | 02-03-2013 10:52 PM |
exterior temp. gauge off? | Rayme | CANADA | 8 | 01-23-2013 09:06 PM |
Simple Oil Temp. Gauge | Sportsguy83 | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 01-19-2013 08:25 PM |
