02-10-2013, 03:10 AM | #29 |
Drives: Firestorm FR-S 6MT
TPMS is on a different bus. Only Techstream and some expensive readers can read it.
2013 Scion Firestorm FR-S MT
02-10-2013, 03:17 AM | #30 |
Drives: 86 GTS
Just realised the steering wheel telescoped forward when I saw the nardi330 mobile and wonders why there was more room. This is the perfect spot.
02-10-2013, 09:13 PM | #31 |
Drives: GT86, 83 RX7
Does anyone know the codes for oil pressure? Oil pressure and temperature are the most important to me, it would be nice to have them both.
I have had a quick look around but have not had any luck finding anything. |
02-10-2013, 09:30 PM | #32 |
Drives: 86 GTS
Do we know if the ECU even logs it?
02-10-2013, 09:58 PM | #33 |
I Love custom Turbo kits
Drives: Limited BRZ
It is believed that there is no oil pressure sensor perse, just a signal triggered in a specific pressure value to turn the dash light on when it gets to very low psi. By that time, damage is already done.
02-11-2013, 10:10 PM | #34 | |
02-11-2013, 10:35 PM | #35 |
Drives: '13 GBS Subaru BRZ
A big thanks to everyone working on this. After seeing that we can read oil temp I was sold and ordered my scanguage yesterday.
02-12-2013, 09:37 PM | #36 |
Confirmed. The disable seatbelt beep code from Prius genIII is working on our car.
Code:
Seat Belt Beep Query 07C021A7 046115A70000 2808 000100010000 SBQ C0 for stock, 00 for disable Seat Belt Beep Disable 07C03BA700 047B15A70000 2008 000100010000 SBS Should return A7. Replace '00' with 'C0' to go back to stock.
The Following User Says Thank You to pkny For This Useful Post: | TIE Pilot (02-12-2013) |
02-12-2013, 09:53 PM | #37 |
Drives: Moped
Does anyone know if Aeroforce offers any scan gauges compatible with the FRS/BRZ?
02-12-2013, 09:58 PM | #38 |
Drives: Some rust bucket
Can anyone clarify what sensors the Scangauge can read?
Oil temp? Water temp? Oil pressure? Anything else? Also, how does using the OEM sensors differ from using aftermarket gauge/sensors? |
02-12-2013, 10:03 PM | #39 |
Drives: TIE interceptor; BRZ13
Awesome. Now reverse beep... I know i know i need to buy my own.
"Speed has never killed anyone. Suddenly becoming stationary, that's what gets you." Jeremy Clarkson
02-12-2013, 10:15 PM | #40 |
Oil temp? Yes
Water temp? Yes Oil pressure? No. The car doesn't have the sensor. Anything else? See the 1st post and scanguage's website.
02-12-2013, 10:15 PM | #41 |
Updated the 1st post.
02-12-2013, 10:19 PM | #42 | |
Similar Threads | ||||
FT-86 low temp THERMOSTAT | ft86-UAE | Engine, Exhaust, Transmission | 52 | 08-30-2016 03:46 PM |
A/C Oil/Water temp gauge | Exhaust | Scion FR-S / Toyota 86 GT86 General Forum | 16 | 02-07-2013 01:19 PM |
Engine oil temp now available in Torque App | Yruyur | Engine, Exhaust, Transmission | 8 | 02-03-2013 10:52 PM |
exterior temp. gauge off? | Rayme | CANADA | 8 | 01-23-2013 09:06 PM |
Simple Oil Temp. Gauge | Sportsguy83 | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 01-19-2013 08:25 PM |
