Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum - FT86CLUB > Technical Topics > Mechanical Maintenance (Oil, Fluids, Break-In, Servicing)
Old 08-05-2020, 06:16 AM   #29
Petah78
Drives: 2017 BRZ sport-tech
Originally Posted by rice_classic View Post
Both are good but the syncromesh from amsoil is full synthetic so when things get hot and fast the oil will prevent the synchro from adequately slowing down the gear and youíll get a crunch. This is in track/racing scenarios.
I like the 75-110 but I race on the 75-90
Thanks for the reply. The reason why I ask is because I also have a Honda S2000 which i believe to also have a Aisin transmission. I was able to use amsoil syncromesh in that hence I figured I can in the BRZ. From my reading, all syncromesh fluid (5-30) is lighter than 75-90 which is what our transmission specs.
In regards to the diff, why go lighter in track situations where temps are higher?
Daijiro Katoh - Champion Forever!
Past: 92 EG w/JDM B18C, 00 EK w/JDM B18C, 04 600RR, 97 ITR #421, 03 Acura 1.7 EL, 10 Acura CSX-S
Current: 17 BRZ, 00 S2K - #0220
Petah78 is online now   Reply With Quote
Old 08-06-2020, 08:25 AM   #30
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
The wear isnít happening nor do I have a fancy lsd that needs thicker fluid, and thicker fluids can also contribute to higher temps. It wasnít a Ďsolutioní for me. On the advice of csg Mike and allowable by the T4 rules, I just installed the greddy diff cover so Iím looking forward to see how that improves the life of the diff fluid.
SCCA T4 - FRS
The Following User Says Thank You to rice_classic For This Useful Post:
Petah78 (08-09-2020)
Old 08-06-2020, 02:41 PM   #31
Westen86
Purist
Westen86's Avatar
Drives: 2013 FRS - Hot Lava
Pentosin MTF2 (75w80, GL-4) in the Gearbox, Motul 300 (75w90) in the diff. NOT LSD oil. There are no clutch discs in there.
WTB: Everything Verus
Westen86 is offline   Reply With Quote
differential, fluids, maintenance, oil, transmission fluid
Changed Diff/MT Trans Fluid to Motul 300 and super low MPG jfg5067 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 01-18-2016 09:24 AM
Trans and Diff fluid change feedback Freedom AFRICA 0 08-07-2015 11:52 AM
Manual Trans./Diff. Fluid Change.?. westmansweed Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 13 07-15-2015 08:02 AM
Replacing Trans & Diff Fluid, Hot vs Cold BRZNutt Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 8 12-22-2013 09:04 PM
Trans/Diff Fluid. DanoFA20 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 18 01-11-2013 03:11 PM
Copyright ©2000 - 2020, vBulletin Solutions Inc.
User Alert System provided by Advanced User Tagging v3.3.0 (Lite) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
