Old 04-15-2014, 02:50 PM   #15
AVodka14
AVodka14's Avatar
Drives: 2013 Raven FRS MT
Originally Posted by Chaetagnath View Post
I don't think it is plug and play on the FRS. GT86 has the wiring because it comes with auto levelers stock correct?
He has the base GT86 that is similar to the FRS. The GTS has the HIDs in Europe.
AVodka14 is offline   Reply With Quote
Old 04-15-2014, 02:51 PM   #16
AVodka14
AVodka14's Avatar
Originally Posted by 2SeeKU View Post
Certainly was. Its entirely plug and play. Other then repining the looms, no other changes were required.
How did you level the headlights?
Old 04-15-2014, 03:20 PM   #17
86SPEED
86SPEED's Avatar
Drives: The silvertrooper 10 series
there still is a spot on the back to adjust the lights. the BRZ lights are a direct bolt in, just needing to swap plugs for the frs ones. its easy to repin them with a small flat head. For the signal its just tapping into the stock one or run that with a led and use it for parking/DRL also
86SPEED is offline   Reply With Quote
The Following User Says Thank You to 86SPEED For This Useful Post:
AVodka14 (04-15-2014)
Old 04-15-2014, 08:07 PM   #18
AVodka14
AVodka14's Avatar
Sweet, that is what I wanting to confirm. Does the DRL resistor need to be unplugged as you it would if one was installing the GT86 headlights?
Old 04-19-2014, 11:53 PM   #19
Chaetagnath
Drives: Whiteout FRS
I just installed the BRZ headlights on my FRS so I thought I'd post some info.
First of all, I have to give credit to @Moto-P for the info on the FRS headlight wiring here: http://www.ft86club.com/forums/showp...8&postcount=22
It's pretty simple to repin the male harness connector which is on the headlight itself from an 8 pin connector to a 6 pin connector. You can either take the 6 pin connector from the OEM headlamp, or order the connector. The part number is 90980-11033. You will need two (1 for each side). I did it this way so thatI would not need to pirate the connector from my current headlamps and could therefore get the wiring set up completely first, then simply swap the head lights out.
This is what the harness looks like on the BRZ headlamp:
As you can see (sorry for the crappy photo), there are 7 wires.
White = Turn signal +
Green = Boomerang LED +
Thin Black = Common Ground
Yellow = High beam +
Red = Low beam +
Thick Black = Low beam ground
Blue = High beam ground
To remove the pins, simply use a small metal probe or tiny flathead screwdriver to push the little plastic clip above the pin up, while gently pulling on the wire on the other side. It should slide right out the back. When you are done it looks like this:
Here is what the 6 pin connector looks like. The left side of the photo is the front view, where the pins actually would be, and the right side of the photo with the circular holes is the back of the connector, where the wire come out. Anyway, I have labeled both sides with the corresponding pin number locations.
There are a few ways to do the wiring. If all you want is for the boomerang to light up with the parking lights and headlights, then you will only need 6 of the 7 pins, and they will all fit in the connector
The FRS female harness side of this comes wired like this:
So if you set up the connector on each headlamp like this:
You will get the boomerangs on with the parking lights, and they will stay on with the headlamps.
Looks like this:
Swap out the headlights, plug it in and revel in a job well done. So sweet.
If you want the turn signal in the headlight housing to work, and/or want the boomerang to act as a DRL as well, it will require a couple extra steps.
Since the headlight harness only has 6 slots, you will either need to connect the turn signal wire directly to the connector, or create a new connector. To give it a more OEM look, I just ordered a couple of standard HID headlight wires for 8 bucks off of ebay.
I removed the pins from the male side, and inserted the turn signal and boomerang LED pins. Then, the female side I used to splice into the turn signal power from the car, and the DRL for the boomerang.
Ended up looking like this:
So it ends up being wired like this:
To tap the turn signal, I did it when the bumper was off for the headlight install. You want to tap the red wire here:
As for what to tap to get the boomerang as a DRL you probably want to do it the same way they do on GT86 headlamps, and likely you will need to remove the resistor as well (although I do not know for sure since I didn't do it this way). http://www.ft86club.com/forums/showthread.php?p=1012406
I however, already had LED DRLs that I installed (see this thread http://www.ft86club.com/forums/showthread.php?t=27813). So I simply tapped the power wires to each DRL.
And the result:
Chaetagnath is offline   Reply With Quote
The Following 14 Users Say Thank You to Chaetagnath For This Useful Post:
Ammunition (09-22-2015), Bach415 (04-20-2014), driftking96 (05-03-2016), Gilwith1l (04-20-2014), hmong337 (04-05-2015), Moto-P (10-01-2020), OmarGC (01-24-2015), P86RAVES (05-14-2014), R2RO (10-26-2016), scottman (08-04-2019), Silky (08-21-2019), SkAsphalt (04-20-2014), van_fc3s (04-21-2014), wtrxprs007 (05-22-2015)
Old 04-20-2014, 01:01 AM   #20
soundman98
ProCrastinationConsultant
soundman98's Avatar
huh. it looks.... different.. not really bad, but not great to me either... i guess i'm so used to the boomerangs with the mustache, it looks odd without the mustache...
Old 04-20-2014, 09:00 AM   #21
illest86
What looks different, are those LED DRL strips in the bottom. Never been a fan.
GJ on the headlight install though, looks flawless.
illest86 is offline   Reply With Quote
Old 05-13-2014, 11:21 PM   #22
AVodka14
AVodka14's Avatar
Where did you guys purchase your BRZ headlights?
Old 05-13-2014, 11:24 PM   #23
Chaetagnath
Got mine off of eBay.
Old 05-14-2014, 11:28 AM   #24
AVodka14
AVodka14's Avatar
Gotcha. New or used. If used...were they in good shape?
Old 05-14-2014, 01:41 PM   #25
Chaetagnath
Mine were new.
Old 05-14-2014, 01:44 PM   #26
AVodka14
AVodka14's Avatar
Mine were new.
Do you mind letting me know the source and price of the lights? If so, no worries. Just wanting to check the price on ebay vs Suby sites.
Old 05-14-2014, 01:56 PM   #27
Chaetagnath
Got mine from a ebay vendor called Max Subaru. $500 a piece.
Old 05-14-2014, 02:32 PM   #28
AVodka14
AVodka14's Avatar
Nice! One more question, haha. Did that include bulbs, ballasts, and wires? Thanks, man.
Jdm headlights 86ing Cosmetic Modification (Interior/Exterior/Lighting) 2 12-12-2013 11:15 PM
Trade FRS headlights for BRZ headlights? Teknian_Culprate13 Exterior Parts (Aero, Lighting, Etc.) 10 07-14-2013 08:11 PM
WTB: Headlights FR-S/BR-Z official_george Exterior Parts (Aero, Lighting, Etc.) 1 06-03-2013 01:03 AM
WTB Headlights FR-S andyone Exterior Parts (Aero, Lighting, Etc.) 0 02-04-2013 08:19 AM
