Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
12-12-2021, 11:23 AM | #1 |
Drives: SSM BRZ
Small Leak?
Hello,
I've been experiencing a potential small leak in my 13 brz with 180K kms and was wondering if anyone has any advice. Its not large enough to the point where it pours under my car and only happens when the car is warmed up and after driving for 10-15 mins. It smells like a mixture of gasoline and something sweet and I can smell it through my vents only when I have the A/C turned on. When in re-circulation mode, I don't smell anything at all. I can sometimes smell it outside the car but the smell fades away very quickly. Now, I recently got my tranny and coolant changed. I was thinking maybe it was tranny leaking somewhere since most people online have said a leaking tranny smells sweet. No gear slipping or overheating issues that I can tell from from the tranny. Sadly, most the shops around my area are flooded with winter season tire changes so next available appointment won't be until end of January. Friend said to pour some stop leak in the transmission and hope it stops. Apparently that worked for his old civic. Has anyone tried using stop leak products(lucas, bars, etc) in the 86 platform and recommend using it?
12-12-2021, 11:37 AM | #2 |
What does the fluid look like? That's your answer. Your coolant is blue and will have a water like consistency and smell kinda like maple syrup. Transmission fluid is an oil and will feel like oil. I don't remember the color but it won't be blue. A previous owner could have used Royal purple, which will be purple, but usually transmission fluids are red or brown. Should smell bitter or acrid
Sent from my ONEPLUS A5010 using Tapatalk |
The Following User Says Thank You to Ashikabi For This Useful Post: | congee (12-12-2021) |
12-12-2021, 11:39 AM | #3 |
ProCrastinationConsultant
where is it leaking from?
my experience is that stopleak products delay and sometimes inhibit the proper repair procedures later. they usually end up costing more money than less, because a full flush/fill is now required once you go for the proper repair. fix it right, fix it once.
The Following User Says Thank You to soundman98 For This Useful Post: | congee (12-12-2021) |
12-12-2021, 12:10 PM | #4 | ||
Drives: SSM BRZ
12-12-2021, 12:54 PM | #5 | |
Similar Threads | ||||
Someone has a small..... | PetrolioBenzina | Scion FR-S / Toyota 86 GT86 General Forum | 12 | 03-09-2019 01:07 AM |
Small Leak, need advice. | AbductedCasper | Engine, Exhaust, Transmission | 5 | 10-03-2018 09:49 PM |
Small Oil Leak under center of engine? | brillo | Issues | Warranty | Recalls / TSB | 6 | 11-09-2013 09:52 PM |
What the best way to fix a small rip in my set? | speedy racer | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 06-22-2013 06:08 PM |
small oil leak sealant? | 7thgear | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 6 | 05-09-2013 04:36 PM |
