Old 07-25-2017, 08:30 AM   #1
Silver Ignition
APEXHNTR
Silver Ignition's Avatar
Drives: 10 Series FR-S #1867
How high can I safely push my rev limit?
I'm an avid autocrosser so to push my rev limit from 7600 to say 7800 or 8000 would also push my 2nd gear top speed from 62 to possibly 65 or 66.
How high can I safely set my rev limit?
2013 Sc10n FR-S 10 Series
#1867 of 2500
in the garage...2001 Toyota 4Runner [Solid Axle Rock Toy], 1987 Pontiac Fiero GT [Shitwagon], 2004 Honda Interceptor VFR800 [daily rider], 1978 Suzuki GS750 [Café Racer]
Silver Ignition is offline   Reply With Quote
Old 07-25-2017, 09:56 AM   #2
Dakines
I set it in 8000
Dakines is offline   Reply With Quote
Old 07-25-2017, 10:22 AM   #3
majixmatrix
BRZ Wannabee
majixmatrix's Avatar
Drives: 2013 Limited BRZ
There are numerous forum posts about this. After a lot of reading, many users said that with our engines there is really no power to be had above 7500 RPM like with an STI or most other cars. I would set it at 7600 RPM like most tunes and call it a day and not risk premature engine failure.
majixmatrix is offline   Reply With Quote
Old 07-25-2017, 10:35 AM   #4
Silver Ignition
APEXHNTR
I'm not looking for power as much as I'm looking to NOT hit that 7600 wall...theres times on course when I'm on the soft limit at 7600 for a good 3-5 seconds...3-5 seconds on a 62mph wall
#1867 of 2500
Old 07-25-2017, 01:03 PM   #5
majixmatrix
BRZ Wannabee
Ah I gotcha. A couple people on the previous threads said they didn't want to go higher than 7800 RPM
Old 07-25-2017, 02:00 PM   #6
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
i downshifted into 8200, didn't total my brz....... oh wait wrong thread.
Old 07-25-2017, 02:15 PM   #7
OND
OND's Avatar
Drives: 2023 BRZ
If you are on redline for long enough to cause significant time loss, you probably have time to shift up and down (even tho shifting down to 2nd is a b.tch sometimes). Otherwise, you arent losing much anyway
You could also try a taller tire like 235/45/17 if it suits your track better?
OND is offline   Reply With Quote
Old 07-26-2017, 05:51 PM   #8
Freude am Fahren
Drives: '13 DGM BRZ Limited/'14 Yamaha R6
If you want a couple MPH, you can try slightly larger tires.
-XXR 527 18x8.75 +35
-Nameless 2.5" OP/FP Combo (Coming soon) & Axleback
-SBD 500X (Waiting on coating to install)
-Southbend SBD500X Clutch
Freude am Fahren is offline   Reply With Quote
Old 07-26-2017, 07:07 PM   #9
dutchman1
Drives: 2017 86 6-Speed
Like others have said, tires.
That being said, I'm considering doing the opposite for my car. I'm thinking about trying a 215/45r17 Rival S 1.5 on a 16x7.5 (the 2017s can run 7.5" in street class) next year. With the 2017's gearing I can only go 57 in 2nd, so on fast courses I have to shift anyway. With the smaller tires that'd drop to 54.5, but I'd have a 5% gearing advantage, be 2lbs lighter a corner, and sit .7" lower than a 225/45r17. I think the good would outweigh the bad, as long as I don't blow too many shifts.
Not a direct answer to your question, but food for thought.
2017 86 set up for CS STX autocross
dutchman1 is offline   Reply With Quote
Safely raising rev limit? Keenercarguy Engine, Exhaust, Transmission 22 12-16-2017 08:23 PM
2017 Push It to The Limit Autocross Series Frost CANADA 45 09-27-2017 11:18 PM
[Ontario - Toronto Area] 2015 Push It To The Limit Autocross Series Frost Tracking / Autocross / HPDE / Drifting 0 05-18-2015 10:56 PM
Transporting e85 safely Sonolin Tracking / Autocross / HPDE / Drifting 5 05-21-2013 03:33 PM
How to Safely Wash Your Car in the Winter Veloist Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 1 12-05-2012 12:31 PM
