Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum - FT86CLUB > FT86CLUB Shared Forum > Member's Car Journals
Old 02-19-2021, 11:49 AM   #337
Goingnowherefast
Drives: AP2 S2000, 91 Miata 1.8L Rotrex 5MT
Originally Posted by 949 Racing View Post
Taking guesses based on supposition and conjecture is fine as long as it's framed as such. Too often however, that is misinterpreted as fact on the internet. I will stick with data collected under controlled conditions.
This is what we're waiting for! That plus any more optimizations Bill might be able to pull out of the car.
2017 Subaru BRZ w/ PP - Delicious Tuning S2+ Flex Fuel/Tomei UEL/HKS Single/RCE Tarmac II's 9K/9K - (SCCA TT T4)
Goingnowherefast is offline   Reply With Quote
Old 02-19-2021, 12:13 PM   #338
949 Racing
949 Racing's Avatar
Drives: Miata, GT350, FR-S
Originally Posted by Mike_ZN6 View Post
I don't think there has been a consensus on the power blocks. Here is a post from Delicious from a while back where they claim the BPBs cause heat soak and power loss: https://www.ft86club.com/forums/show...86&postcount=7
That post was from Zach, 6 years ago. No data shared. I would want to see IAT logs from both before accepting that data point as it runs counter to everything I have ever tested and collected data on here.
949 Racing is offline   Reply With Quote
The Following User Says Thank You to 949 Racing For This Useful Post:
Mike_ZN6 (02-19-2021)
Old 02-19-2021, 04:35 PM   #339
Lantanafrs2
Drives: 2013 frs red
I use the blocks with e85 daily. I think there was some bias against Crawford just as shiv was trolled by the ecutek guys.
Lantanafrs2 is offline   Reply With Quote
Old 02-22-2021, 09:43 PM   #340
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
I had been considering the blocks. I don't track the car and surrendering a few horses up top for more area under the curve is an attractive trade-off. But I have to admit, the price is pretty breathtaking considering what it buys. Then I ran across some knockoffs on Amazon. $75 shipped. $75 v $360. I am very reluctant to buy knock-off/copied products, but I have to say the 80% discount reinforces my skepticism about Crawford's pricing.
My conclusion? Buy neither and put the money toward a Flex-fuel kit and a tune.
/[threadjack]
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
Old 02-28-2021, 11:01 AM   #341
949 Racing
949 Racing's Avatar
For those that would consider a cheap Chinese knock-off of the Crawford BPB, I would recommend against it for a number of reasons.
1. Crawford had the idea, made prototypes, spent a lot of time on the on the design and did all the production engineering. They deserve your business and to be supported so they can make more cool stuff. Buying cheap copies of their designs, makes it harder for them to stay in business and forces them to raise the price on everything else they sell.
2. The average person is blissfully unaware of the myriad of production engineering challenges that generate a functional durable and reliable product. Simple things like using wrong material in the O-ring so it shrinks over time and creates a leak/ is not solvent (fuel) resistant, or making the O-ring the wrong cross sectional diameter so it doesn't seal. Specifying the wrong finish on the mating surface, creating and sticking to a tolerance for the parallelness of the two mating surfaces, low quality hardware that stretches and loses torque. The list goes on and on.
Even with such a seemingly simple product, there is more than meets the eye.
Support the shops that do the homework to bring new tech to the platform.
The Following 3 Users Say Thank You to 949 Racing For This Useful Post:
churchx (02-28-2021), Lantanafrs2 (02-28-2021), PulsarBeeerz (02-28-2021)
Old 02-28-2021, 11:21 AM   #342
Pat
Pat's Avatar
Drives: 2014 BRZ
Good point. A friend of mine purchased a cheap Chinese oil cooler and the o-rings failed in that. Which he believes in turn led to a failed engine.
Old 03-04-2021, 10:01 AM   #343
PulsarBeeerz
Found this on the FB FA20 pages..
OFT OTS E85 Stage 2+
4-2-1 Tomei header
HKS 3 single exit
Plastic IM ported for a 76mm Tundra TB
w/t BPB
Falls pretty hard after 7000rpms but we knew that.. The TQ in the mid range is hard to ignore.
PulsarBeeerz is offline   Reply With Quote
The Following User Says Thank You to PulsarBeeerz For This Useful Post:
Mike_ZN6 (03-04-2021)
Old 03-04-2021, 10:07 AM   #344
Dzmitry
Dzmitry's Avatar
Drives: 2018 Subaru BRZ Limited with PP
4-2-1 Tomei header
HKS 3” single exit
w/t BPB
Wonder why the dip increased or is still so significant after all those mods?
EDIT: I guess it could look more like a dip due to the heavy increase in torque at that mid range.
Dzmitry is offline   Reply With Quote
Old 03-04-2021, 08:02 PM   #345
949 Racing
949 Racing's Avatar
Renderos Racing 4 pt roll bar
Got Blub back yesterday. Big Thanks to Alex. He's really busy these days and squeezed us in to get the bar designed, built and installed.
For info on the bar ( pricing, lead time, shipping, etc) hit him up directly https://renderosracing.com/
Weight is 44 lbs. We painted ours body color. I think he TIG welds everything.
The stub on the main hoops is to both make it easier to install and ship. Ours allows the OMP HTE-R 400's to go all the way back on stock rails.
We have been driving it with the stock 3pt belts and frankly, the car is a bit too fast to run without a roll bar and 6 pts. Beyond that, it's tiring to be flopping around. Really looking forward to being locked in to the seats and not being tossed around by the G forces.
Sonny has to align it. APR is backordered on the wing mounts so not GT250 yet. We'll build the 5" 10mm alumalite splitter once teh wing gets here. Also eager to see what it'll do on the 18x10's and 255/35's.
The Following 6 Users Say Thank You to 949 Racing For This Useful Post:
Capt Spaulding (03-05-2021), Code Monkey (03-05-2021), CSG Mike (03-05-2021), DarkSunrise (03-05-2021), Dzmitry (03-05-2021), phm14 (06-02-2021)
Old 03-05-2021, 09:03 AM   #346
Capt Spaulding
Persona Non Grata
THAT is sweeet. Sculpture.
Old 03-05-2021, 12:19 PM   #347
949 Racing
949 Racing's Avatar
RE: Renderos roll bar
We chose a simple config for our car but he'll build whatever you want. For example, you could do an X brace in the main hoop instead of single diagonal. Or X brace in rear stays. Or rear lateral brace across rear stay mounting points. Camera mounts, harness tabs, etc. The harness bar on ours is the optimum angle for the seat we are using. If he ships you a bar, give him the measurement from floor to harness port so he can place the harness bar to get you the correct harness angle. If you drop off you car at his shop in Victorville, have the seat installed.
I had him push the main hoop really far back to clear our seat when adjusted all the way back. If you're a much shorter driver and want the bar closer, let him know.
Old 04-29-2021, 11:31 PM   #348
949 Racing
949 Racing's Avatar
Update on the Blubster
It's been a while since we ran it last. Busy with other development projects so it took us a while to get it ready for the track again with the new mods.
5" splitter of 10mm Alumalite replaces our ebay lip
GT250 2D wing replaces the duck tail spoiler
Singular Motorsports endplates
18x10 +35 XXR 527F (forged CNC) wheels to replace the Forgestars. We terminally bent all 4 Forgestars on the first day we ran them.
Crawford BPB manifold spacers
Delicious tune for the BPB
949 Racing Billet Camber Plates
Whiteline rear camber bushings
Safequip FIA 6 pt harnesses
Element fire suppression stick
Production style Xidas and our camber plates give us -5 front camber. We were stuck at around -3.5 before. Won't know until we get it on track but we think all the updates should make it about 1.5~2s faster. Going to be hot at CVR this weekend so we might not see its full potential. Fingers crossed it all works as I hope it will.
Running at Chuckwalla this weekend. If you're there, come by and ask for a ride if you have been jabbed. Our crew is all jabbed now.
Capt Spaulding (04-30-2021), Code Monkey (04-30-2021), phm14 (06-02-2021), PulsarBeeerz (04-29-2021), RayRay88 (04-30-2021), TMF (05-04-2021)
Old 04-30-2021, 07:49 PM   #349
darthwong1138
Drives: Raven FR-S
Was there any particular reason for switching from the ACE header to the JDL header?
darthwong1138 is offline   Reply With Quote
Old 04-30-2021, 08:36 PM   #350
949 Racing
949 Racing's Avatar
We prefer the fabrication methods on the JDL over the methods used to build the Ace. Sorry, not more detail.
Code Monkey (04-30-2021), darthwong1138 (04-30-2021), JBezugs (05-04-2021)
6ul, 949 racing, blub, xida
LED Blub Diffuser? Chimera Cosmetic Modification (Interior/Exterior/Lighting) 5 07-07-2016 12:24 PM
Project Mu Racing 999 brake pads CSG Mike Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 11-15-2013 03:55 PM
Project Kics R40 racing lug nuts HighbreadEH3 Wheels and Tires 0 09-03-2013 01:49 PM
The Enjuku Racing Project FR-S! Enjuku Racing Announcements, Contests, Giveaways 12 07-19-2012 11:54 AM
Copyright ©2000 - 2021, vBulletin Solutions Inc.
User Alert System provided by Advanced User Tagging v3.3.0 (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
