Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
08-06-2021, 05:46 AM | #15 | |
FT8Syg
Drives: `12 FRS & `17 BRZ Inazuma
For our climate in Vancouver wherein we can see snow, slush, & rain within a day, I run on UHP winters 225-40-18 Michelin Alpin PA4 that's really meant for sports cars. It's like the PS4S for winter conditions. You can check out the latest winter tires & their performance reviews on YouTube especially by Tyrereviews.com.
Modding for daily fun & efficiency: Gruppe-S UEL, HKS dual res. FP, STi Per. Muffler, Delicious T. Ecutek tune, Crawford BPB, Grimmspeed CAI, STi Flex T. Bar, TRD Door Stabilizer, DSS aluminum propeller shaft, Verus diffuser & underbody covers, Verus LCA, Perrin bushings, Bilstein B6+RCE Yellows, Michelin PS4S + 18" WedsSport TC105X-summer, Michelin Alpin PA4 +18" Motegi MR140-winter
08-06-2021, 11:19 AM | #16 |
With stock wheels, just stick with stock size tires IMO.
I did enjoy my 16x7 RPF1s with 205/55/16 Blizzak WS80 in a "wow there's even less grip than expected way" in the dry. The Blizzaks were a big part of that though, other winters will be a little bit better in the dry. Good in the snow though. - Andrew |
08-06-2021, 11:51 AM | #17 |
Drives: 2014 GT86
Even less grip in the dry still is sufficient for normal DD turning/braking/accelerating. But if on wrong tires one stops on ice/snow 2x-3x further distance vs car on right season tires .. it should worry a bit.
The Following User Says Thank You to churchx For This Useful Post: | Racecomp Engineering (08-06-2021) |
08-06-2021, 06:25 PM | #18 | |
Drives: 2020 Toyota 86 GT 6M
09-03-2021, 05:30 PM | #19 |
Pavement Grey
Drives: 2020 Toyota 86 GT, 2017 BMW X1
Thoguht i'd bump this as its related.
My 18" OEM tires are 215/40/18. I have winters from a Scion iM which are 205/55/16 and thats what im going to be using (its 2 sizes down but..not equipped with brembos or sachs. So fitment shouldnt be a problem) I just need to get a new set of steel wheels for it as the scion im has a different bolt pattern, so i cant use them until they're swapped out. This brings me to another question. Steel wheels or Alloys for winter? Im finding the steel wheels are a bit more pricey than i expected. If they're close enough to some cheap alloys i might just get cheap alloys instead of steelies. |
09-03-2021, 06:23 PM | #20 |
Drives: 2020 Toyota GT86
Normally when talking performance, un-sprung weight is considered to be bad, but with winter tires/wheels it is actually a positive. So if you don't mind the look, steel wheels are a really good option for winter use.
This post sent using 100% recycled electrons.
09-03-2021, 09:32 PM | #21 |
Drives: 2014 GT86
Sasquachulator: or .. used alloys. For example, OE wheels from more common subbies. Cheap (vs new steelies cost), very common, better looking then steelies and probably lighter, strong as f****.
Similar Threads | ||||
Tire Size Help!!!!! | adrianser | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 9 | 04-06-2018 05:52 PM |
Tire rack giving me a hard time on tire size, so please help! | NOI | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 09-03-2017 06:27 PM |
Tire compound vs Tire size | Dihudaxia | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 5 | 06-22-2015 10:55 AM |
Tire size for 8.75 | brz23 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 3 | 03-08-2015 04:30 PM |
