Issues | Warranty | Recalls / TSB Problems, issues, recalls, TSBs |
09-16-2012, 10:41 PM | #1 |
Drives: Whiteout FR-S
Trunk won't pop open
The trunk of my FR-S no longer opens electronically which means I have to use the key to open it manually from the back. It's quite a hassle since I would have to turn off my car to open the trunk if I was dropping someone off and they had stuff in my trunk. It doesn't open from the key or from the button on the driver's side. I'm assuming this is an electrical malfunction. Has this happened to anyone else before? I'm probably going to bring it into the dealership sometime soon to get it checked out.
09-16-2012, 10:49 PM | #2 |
Drives: 2013 Subaru BRZ - DGM
Hit the little override button in the left side of the trunk area. It disables the front button and the Remote Trunk button as well.
EDIT: At least, there is one in the BRZ... I don't know for sure about the FR-S. |
09-16-2012, 10:50 PM | #3 |
Drives: '13 DGM BRZ Limited
Did you hit the trunk deactivation button on the driver's side interior of the trunk by accident? It's used so that when you valet the car no one can open the trunk without the mechanical key.
09-16-2012, 10:51 PM | #4 |
09-16-2012, 10:52 PM | #5 |
Drives: 1994 Toyota Tercel
This Button in the trunk |
09-17-2012, 08:31 AM | #6 |
Thanks for the help, I'll check it out after class. Didn't know this button existed.
09-17-2012, 09:16 AM | #7 |
03-18-2013, 05:14 AM | #8 |
The trunk remote cancel toggle button is at the perfect height for a sixpack of beer in bottles to fall on its side and a bottle on the top to slide out and tap the button.
The key slot is non-obvious, tucked up horizontally on the underside of the little ledge above the license plate. It's even more non-obvious when you've got a brand new FR-S and beer in the trunk and you can't get the trunk open. |
The Following 3 Users Say Thank You to andreas For This Useful Post: |
03-18-2013, 10:16 AM | #9 |
I Void Warranties
Drives: Asphalt 86
I didn't either until I had some groceries bump it. After unlocking it with my key and moving the groceries I saw the button. Such an odd location to put it imo.
03-18-2013, 10:40 AM | #10 |
Drives: dirty er'ryday
This button exists on the FR-S; check the driver's side of your trunk and you should see a little button on the wall of the trunk as shown in the picture above.
I found it when I was putting some things in the trunk and noticed the button. Boggled the hell out of me why you'd want to cancel the remote feature until someone explained it for me. |
03-18-2013, 11:06 AM | #11 | |
Drives: 13 DGM BRZ Ltd
03-21-2013, 09:45 AM | #12 |
Drives: 2013 BRZ Limited - WRB, MT
i just thought of something... what happens with the brz limited that doesn't have a key? If you hit that button by accident, how would you get the trunk open?
03-21-2013, 09:48 AM | #13 |
Drives: Scion FRS
Had the same thing happen to me till i noticed the small button, derp herp i was going to take it to the dealer over the weekend.
Ive never had a car with a button like that so i guess it was unexpected. |
03-21-2013, 09:49 AM | #14 |
Drives: Scion FRS
I think you can lower the rear seats from the back seat, then you struggle and fight your way through whatever you have in the trunk :P
Similar Threads | ||||
Stock Nav swap from BRZ to FR-S & Five Axis trunk spoiler install on BRZ trunk? | 07stealth350z | DIY (Do-It-Yourself) Guides | 8 | 08-27-2020 03:27 PM |
Trunk will not open | Hbomb | Issues | Warranty | Recalls / TSB | 33 | 06-12-2017 06:56 AM |
Open ECU? | jedibow | Software Tuning | 302 | 10-09-2013 07:24 PM |
anyone know of an open parking lot in southern cal? | SuperDave | Southern California | 23 | 08-29-2012 02:59 AM |
Open Air FR-S Concept | Rampant | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 22 | 02-01-2012 11:01 PM |
