Forced Induction Turbo, Supercharger, Methanol, Nitrous |
03-27-2016, 12:42 AM | #1 |
Drives: 2015 Scion FRS RS 1.0
HELP! CEL after trip from WORKS.
So, if you guys already read my last post, I got my WORKS Stage 2 Turbo kit installed at WORKS about a month ago. I took my car back for the DT Flex fuel kit, dw fuel pump and injectors, WORKS oil regulator/cooler, and also had them put in a boost gauge for me, all installed at WORKS.
The car was driving fine on the way home for about 30 miles then suddenly threw a CEL. The car seems to be running with no problems but the CEL worries me. Should I worry and not drive the car until I talk to WORKS or have someone look at? Anyways, the car made over 280 whp on the e85 flex fuel tune. Will put up the dyno chart tomorrow. Can it be the new pump and/or injectors or oil cooler, or maybe tune? Well any tips will be useful for now, until I talk to them on Monday. |
03-27-2016, 12:53 AM | #2 |
Drives: FT86
read out cel code could be anything.
talk to your tuner drive car as little as possible and slowly till you find out what problem is. |
The Following User Says Thank You to steve99 For This Useful Post: | Sportsguy83 (04-20-2016) |
03-27-2016, 01:08 AM | #3 |
I tried resetting ecu by removing the negative on the battery, thinking it might be a hiccup but, the CEL came back again after about 20 miles of driving. Car idles fine, no stalls, nothing unusual, blue tooth app reads 42% ethanol. Will have a nearby auto shop do a CEL read tomorrow.
03-27-2016, 01:28 AM | #4 |
sleep, drive, eat, repeat
Drives: '13 BRZ, '12 Outback
Since you now have a modded car, it would be a good investment to buy an obd2 reader to be able to read and clear and codes. I keep a Bluetooth obd2 reader around along with the torque app for Android on my phone for times like these.
03-27-2016, 01:36 AM | #5 |
Where can I buy these? I need it!
03-27-2016, 01:42 AM | #6 |
Any auto parts store should have an obd2 reader, maybe even the BT ones. I got mine from Amazon
Veepeak Mini Bluetooth OBD2 OBDII Scan Tool Scanner Adapter Check Engine Light Diagnostic Code Reader for Android Windows https://www.amazon.com/dp/B011NSX27A..._hj39wbSG29SEF |
03-27-2016, 10:09 AM | #7 |
Drives: 2013 Subaru BRZ
havent read any of your past posts, but do you have aftermarket headers or cats? might just be throwing codes for your catalytic converter. had that happen to me once, nothing bad.
03-27-2016, 11:42 AM | #8 |
I do have a private label front pipe with high flow cat. Header is stock. There was no cel before when I had only fp and turbo kit with stage 2 carb tune.
03-27-2016, 12:03 PM | #9 |
Drives: Full race 4cyl boxer
Spends thousands on FI upgrade.
Cant afford $12 for a OBDII dongle. Priceless |
The Following User Says Thank You to justatroll For This Useful Post: | Wayno (03-27-2016) |
03-27-2016, 12:44 PM | #10 |
The Following 3 Users Say Thank You to Mr_YUzU_FRS For This Useful Post: |
03-27-2016, 01:00 PM | #11 |
Drives: Sterling BRZ Ltd
Auto Zone will read a code for free. Cheap code reader is a must.
03-27-2016, 01:23 PM | #12 |
03-27-2016, 02:00 PM | #13 | |
Spends thousands on a FI upgrade, not smart enough to buy a datalogger/CEL reader in advance. Less useless? You DO realize that it is imperative to log data on a FI setup, ESPECIALLY right after a new tune? It cost me a whole $18 for a OBDII reader and the torque app. And I use the OBDII reader to read & clear codes on all of my other cars. |
The Following 4 Users Say Thank You to justatroll For This Useful Post: |
03-27-2016, 03:25 PM | #14 | |
Drives: FRS,09 370z, 00 CelicaGT-S, 85 300Z
He is obviously made a oversight on getting a reader and is a little panicked. No need to diss. |
The Following 2 Users Say Thank You to clayrush For This Useful Post: | Harvie1031 (03-28-2016), weederr33 (03-27-2016) |
Similar Threads | ||||
Works Axle Back Muffler Review (Works ABM) | ButeraFRS | Engine, Exhaust, Transmission | 16 | 03-15-2018 06:23 PM |
TJ trip | echo2lv | Southern California | 13 | 07-16-2015 04:17 AM |
The weather for a trip | thebus | Southeast | 4 | 01-30-2014 03:02 PM |
Trip to LA! | 1086 | Northern California | 3 | 11-28-2013 07:57 PM |
What would you consider an adventure trip in your FRS/BRZ? | Tanuki | Scion FR-S / Toyota 86 GT86 General Forum | 47 | 04-07-2013 05:54 PM |
