Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
09-04-2020, 04:53 PM | #1 |
Question for those who installed the TRD sway bar kit
Did it come with lube? I bought the kit 2nd hand with new bushings, but no lube was included, so I installed them with no lube. Was this incorrect?
TIA |
09-04-2020, 05:41 PM | #2 |
Rust bucket enthusiast
I don't have these swaybars, so I'm sorry if I shouldn't post- but you need to lube the bushings if they're poly
09-04-2020, 06:38 PM | #3 |
The TRD 21mm front bushings look and feel identical to oem bushings though, they are super soft. But I’ve seen pictures of the kit on eBay with lube so I just wanted to double check before plucking it out again.
09-04-2020, 07:09 PM | #4 |
If it's rubber I wouldn't grease it, if it's poly you should. I guess someone who has it WILL need to answer, haha
09-04-2020, 07:27 PM | #5 |
Drives: 2020 86
Possible the person you bought it from substituted rubber bushings for the poly ones the TRD kit is supposed to come with ?
09-04-2020, 07:37 PM | #6 |
No I bought the bushings from my local dealer. Dude who sold me the bar without bushings told me they use the original bushings which I knew to be completely untrue.
09-04-2020, 07:41 PM | #7 | |
Drives: 2020 86
FWIW |
The Following User Says Thank You to WildCard600 For This Useful Post: | norcalpb (09-04-2020) |
09-04-2020, 07:43 PM | #8 | |
I’ll tackle it when I do header gaskets...sounds like I have a long date under the front of my car. |
09-04-2020, 07:49 PM | #9 | |
Drives: 2020 86
The poly bushings I did on my T/A were much harder, almost like a hockey puck. They squeaked like crazy right out of the box during a test fit. |
09-04-2020, 07:58 PM | #10 | |
These TRD bushings I feel like I could tear in half. |
09-04-2020, 11:25 PM | #11 |
Wrap bar with teflon tape where it contacts the bushings.
- Andrew |
The Following 2 Users Say Thank You to Racecomp Engineering For This Useful Post: | norcalpb (09-05-2020), WildCard600 (09-05-2020) |
09-05-2020, 01:04 AM | #12 |
09-10-2020, 06:19 AM | #13 |
Drives: MY14 86 GTS Manual Velocity Orange
just checked mine and they are rubber rather than poly. my kit came with the new bushings all new hardware and grease as well.
could be a future upgrade to swap out my rubber bushings for poly units - if i can find poly ones of the right size. |
The Following User Says Thank You to sneaky_pete For This Useful Post: | norcalpb (09-10-2020) |
09-10-2020, 02:50 PM | #14 | |
You can also buy 21mm AVO poly bushings here: https://www.ebay.com/itm/114253486051 |
Similar Threads | ||||
Installed super fat sway bars, now car is a slidey boii | Stomachbuzz | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 33 | 01-17-2020 10:11 PM |
TRD anti-sway bars installed in my FR-S | babydriver | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 12 | 10-01-2016 08:58 PM |
will be installed in the end whether sway bar can increase body strength? | kid1412lld | Scion FR-S / Toyota 86 GT86 General Forum | 9 | 08-06-2015 03:17 PM |
Help, installed Swifts, damaged F Sway Bar Link | F1fletch | DIY (Do-It-Yourself) Guides | 0 | 02-09-2014 11:49 AM |
Eibach Multipro R1 and front and rear sway bar installed | Pekingduck | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 43 | 12-30-2013 10:59 AM |
