Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
04-19-2020, 02:00 PM | #15 | |
Drives: 2014 Subaru Forester
I thought about replacing my Corsa with the Greddy, but went with the Fujitsubo axle back instead. |
04-19-2020, 02:06 PM | #16 |
Go V8
The Following 2 Users Say Thank You to ls1ac For This Useful Post: | BrahmaBull1990 (04-11-2021), soundman98 (04-20-2020) |
04-19-2020, 02:13 PM | #17 | |
TRACKBREAD
04-19-2020, 02:19 PM | #18 |
Airborne at your service
Drives: '17 BRZ Series.Yellow
I have the axelback version from Japan so I can either keep the oem midpipe or get an aftermarket from Works.
The Following User Says Thank You to weederr33 For This Useful Post: | Yoshoobaroo (04-19-2020) |
04-19-2020, 04:24 PM | #19 |
04-19-2020, 05:19 PM | #20 | |
Drives: RX-7 / BRZ
Just remember a resonated front pipe to match.
//2018 Crystal White Pearl BRZ Ts 2.2l Harrop Supercharged |
04-19-2020, 07:07 PM | #21 |
TRACKBREAD
Honestly for a daily I wouldn’t touch the front pipe. Do the catback first and break it in, most get a bit louder after a few heat cycles.
The Following User Says Thank You to Yoshoobaroo For This Useful Post: | Plumbus (04-16-2021) |
04-19-2020, 09:27 PM | #22 |
Sleep Chomper
Corsa has a really deep and gentlemanly rumble
Sent from my H8314 using Tapatalk |
04-20-2020, 01:17 AM | #23 |
Drives: 17 Asphalt 86
Corsa Has a very livable setup with the rest of the exhaust system stock.
Loud enough on throttle, hardly noticeable near stock at cruise. No drone, plus a lifetime warranty. Sound profile should never change which isn't the case for many fiberglass packed muffler setups. It's not a Base-y setup, more of a growl. Perrin 2.5" is a subtle deep tone. Good future proof option should you decide to go catless later. It doesn't really rumble though with factory headers. |
04-09-2021, 09:18 PM | #24 |
Drives: 2019 GT86 TRD
I know long over
This is the PLM UEL, stock overripe, HKS dual Res Front pipe and my stock TRD singletip axleback exhaust. Drones less than the stock front pipe did, still drones. It's bearable and quiet at idle but really opens up when I lay into it. Stays deep sounding below 3k RPMs cruising. I only know that because I like tunnels |
04-10-2021, 08:24 PM | #25 |
Drives: BRZ 2013
I wanted something with a mature sound yet civil for daily driving and without any drone for long trips. I have the Lachute Performance catback (and full line) with the long resonator version, and it is perfect for my needs. I can drive it for hours even with the backseat down without any fatigue, and has a nice deep sound. Not sure it would be readily available in your area, but I thought I’d mention it, its a very high quality hand made exhaust, warranteed for life. I’ll see if I can get a sound clip.
Cheers |
04-11-2021, 11:07 PM | #26 | |
Drives: 2017 PP BRZ
04-12-2021, 08:29 AM | #27 |
The very best solution would be to find the most respected exhaust fabricator (not fitter) in town, the older the better, and ask him what he could make for you that can get close to exactly what you want.
With the right expertise ,it won't be the cheapest option, but it will be much better than anything bought off the shelf. I should have done it from square one: https://www.ft86club.com/forums/showthread.php?t=144604 |
04-14-2021, 10:06 PM | #28 |
Howdy
Drives: 2020 BRZ PP
Here is my exhaust: Tomei UEL, Tomei overpipe, stock FP, Corsa catback Cabin (window down halfway through)
There's a point at 7,000 RPM... where everything fades. The machine becomes weightless. Just disappears. And all that's left is a body moving through space and time. 7,000 RPM. That's where you meet it. You feel it coming. It creeps up on you, close in your ear. Asks you a question. The only question that matters. Who are you?
Similar Threads | ||||
Anyone out there with catless headers and a deep rumble exhaust note? | Lakitu | Engine, Exhaust, Transmission | 2 | 09-08-2019 06:39 PM |
Exhaust too loud need advice | flippy | Engine, Exhaust, Transmission | 7 | 05-16-2017 02:36 AM |
I want rumble but need advice | Golevka | Engine, Exhaust, Transmission | 40 | 04-23-2017 11:30 PM |
Exhaust Advice. I want a loud exhaust system please help | Rambo2469 | Engine, Exhaust, Transmission | 28 | 04-21-2017 02:41 PM |
deep low rumble | subiestyle | Engine, Exhaust, Transmission | 9 | 03-19-2014 12:13 PM |
