Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) -- General Topics
BRZ Second-Gen (2022+) -- General Topics General topics for the second-gen BRZ
View Poll Results: How would you rate the design of the 2nd gen? 1 lowest & 5 highest
1 19 7.20%
2 25 9.47%
3 62 23.48%
4 104 39.39%
5 54 20.45%
Voters: 264. You may not vote on this poll
Old 01-16-2021, 01:57 PM   #1331
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
A image gallery of the silver '22 car.
https://www.facebook.com/media/set/?...79545922086393
The Following 5 Users Say Thank You to Kiske For This Useful Post:
Ash_89 (01-16-2021), beltax90 (01-16-2021), Bristecom (01-16-2021), Sport-Tech (01-17-2021), ZDan (01-16-2021)
Old 01-16-2021, 02:43 PM   #1332
ZDan
ZDan's Avatar
Drives: '23 BRZ
noice...
Old 01-16-2021, 05:48 PM   #1333
LancePower
Drives: 2020 BRZ tS
Originally Posted by beltax90 View Post
awwww shit!
Passin' Me By is my fav all-time song.
LancePower is offline   Reply With Quote
The Following User Says Thank You to LancePower For This Useful Post:
Old 01-16-2021, 09:50 PM   #1334
Bristecom
Bristecom's Avatar
Drives: 2017 Subaru BRZ PP
Originally Posted by HKz View Post
1st world problems
Yes, we are still in the first world... for now. I have a designer's mind so I always think about ways to make things better. We could just walk to work every day on our bare feet but it's not about that. It's about going from A to B with as much fun, speed, stability, and comfort that you can afford.
Toyota + Subaru =
Bristecom is offline   Reply With Quote
Old 01-19-2021, 10:47 AM   #1335
beltax90
beltax90's Avatar
Drives: 2010 corolla
https://www.caradvice.com.au/915534/...-draws-closer/
beltax90 is offline   Reply With Quote
Old 01-19-2021, 10:39 PM   #1336
JusTheG
JusTheG's Avatar
Drives: 2017 Subaru Forester 2.5L Premium
This is a very interesting design. I like the Side AC Vents for being angled at the Driver and Passenger Seats so should have good ergonomics/AC feel. What impresses me is the Instrument Cluster area. The digital display seems to a be part of the entire cluster assembly, so that in terms of dimensions should allow the Aftermarket to possibly replace that whole section for own implementations of the cluster. Wiring harnesses might be the only thing that will probably different connectors/pairings for the digital display but let's see when the car is manufactured.
The headunit does protrude out a bit but I don't mind for it's placement. It contrasts the angle of the plastic molding for the glovebox and the steering column but it is oriented towards the driver for hopefully better viewing angle. I wonder how the Audio Quality will be compared to the First Gen.
JusTheG is offline   Reply With Quote
Old 01-19-2021, 10:59 PM   #1337
soundman98
ProCrastinationConsultant
soundman98's Avatar
We're not going to see much for display changes.
1 word.
Odometer
Old 01-19-2021, 11:17 PM   #1338
JusTheG
JusTheG's Avatar
1 word.
Odometer
Ah, you are correct in that department for how difficult to swap the Display. The only way to modify it would be to use Subaru's tech to pull Odometer data from the Controller connected to the Display. I would reckon that PCB assembly/set of chips will be the biggest cost for integration into a Custom display.
At that cost, might as well just run custom scripts/programs compatible for that display to get additional information or keep certain meters like the G-Meter active while driving. I like the Boxer design for the display but am a bit off about the Track Mode Ramp design for the Tachometer. Maybe a curved Tach display to emulate the S2000's display would be more useful for Rev ranges but maybe I just need to get used to it.
Old 01-20-2021, 07:25 AM   #1339
1st86 Driver!
The odometer settings on a swap aren't that complicated in my experience. I replaced the instrument cluster in my 2004 Suburban earlier this year when chasing an electrical problem. I bought a Dorman refurbished one through Summit Auto. They required the VIN, a photo and self-certification of the mileage which they programmed into the new cluster as a start.
Are the ones in the 86 more complicated than that?
Old 01-20-2021, 10:28 PM   #1340
JusTheG
JusTheG's Avatar
Anything analog or for a typical instrument cluster has been straightforward to replace the panel and find the IC for the Odometer data. To convert an analog to digital display, the wiring harness just needs to have compatible connectors. I like how Ford had compatibility with their SYNC digital displays for the 2015-2018 Mustang so it may be possible with the Second Gen.
Biggest thing is what firmware/software on the instrument cluster would be compatible. For example, the E99 ECU's for the Corvette definitely have more restricting scripts for what data can be processed or acquired on CANBus. It's possible to learn the programming and code for it, but you got to work with what the OEM programmed with the lC for logic.
Old 01-24-2021, 12:16 PM   #1341
beltax90
beltax90's Avatar
The Following 9 Users Say Thank You to beltax90 For This Useful Post:
AnalogMan (01-24-2021), Ash_89 (01-25-2021), JesseG (02-23-2021), joro2 (01-25-2021), Kiske (01-24-2021), Lantanafrs2 (02-01-2021), mazeroni (01-26-2021), spike021 (01-26-2021), StE92ve (01-24-2021)
Old 01-24-2021, 12:50 PM   #1342
jflogerzi
jflogerzi's Avatar
Do we know when journalist will get there hands on one to drive
2013 Series 10 FRS #553
Old 01-24-2021, 12:58 PM   #1343
AnalogMan
AnalogMan's Avatar
Drives: 2019 BRZ Limited 6 speed Red
What's the story behind this?
AnalogMan is offline   Reply With Quote
Old 01-24-2021, 01:16 PM   #1344
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
Originally Posted by ermax View Post
Wow that sounds amazing!! Are there any details on that engine?
https://www.racecar-engineering.com/...aru-brz-gt300/
The Following 3 Users Say Thank You to Kiske For This Useful Post:
Capt Spaulding (01-24-2021), ermax (01-24-2021), JesseG (02-23-2021)
2022 Subaru WRX Spy Shots via Car and Driver R_E_L Other Vehicles & General Automotive Discussions 232 01-03-2023 01:23 PM
2017 BRZ Hig Res - Courtesy Subaru Global Media Trap63 BRZ First-Gen (2012+) -- General Topics 10 07-11-2016 09:53 AM
Subaru global brz web page Gaen BRZ First-Gen (2012+) -- General Topics 4 06-15-2012 01:32 AM
Subaru FT-86/216a news: Subaru Confirms Rear-Drive Coupe Debut for Geneva Motor Show C-Bone BRZ First-Gen (2012+) -- General Topics 39 03-24-2011 09:22 AM
FT-86 makes UK debut at Goodwood Moving Motor Show Hachiroku FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 28 07-09-2010 02:57 PM
