Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
06-05-2022, 09:29 AM | #29 |
Drives: 2013 frs base
Which 2 pipes would you lengthen to get the Subbie rumble? A couple of years ago, I tried to modify a header on my 2000 Impreza to fit around a extra capacity oil pan. After cutting the header up and a couple of hours of fiddling, I gave up and went with the stock pipe.
06-05-2022, 12:11 PM | #30 | |
Drives: Crapcan
Lengthen two of the primaries.
The Following User Says Thank You to NoHaveMSG For This Useful Post: | blsfrs (06-05-2022) |
06-05-2022, 02:49 PM | #31 | |
Drives: 2013 FRS
06-05-2022, 04:09 PM | #32 |
Drives: 2018 BRZ
The 4 portion was increased from 42.7mm to 45mm and the 2 portion from 45mm to 48.6mm. Also claims to have "optimized collector shape".
The Following User Says Thank You to Ohio Enthusiast For This Useful Post: | SpeBud07 (06-05-2022) |
06-05-2022, 05:48 PM | #33 |
Drives: English, French, Swedish & Japanese
06-05-2022, 06:02 PM | #34 | |
Drives: Crapcan
Not that I am aware of. It would be a ton of work just to change the way the car sounds. Not sure how the stock cat would effect the sound.
06-09-2022, 02:01 AM | #35 |
Drives: 2013 BRZ Satin White Pearl
I’m looking at HKS GT-Spec headers, they would get my vote.
I was literally about to pull the trigger on these but the price jumped from $1985.50 (which was already on the expensive side for me) to the ridiculous $2660, all within 48 hours of me starting to look. Obviously I was devastated . I’m assuming this is a supply, COVID tax, inflation issue? I’ve been looking at Japan Parts and they’re around $1900 including shipping. But anything over $1000 includes duties and taxes here and I have no clue in navigating that minefield, so I’ve been reluctant to pull the trigger. Anyone else import reasonably expensive parts from Japan Parts and what’s involved? Last edited by Dirty Harry; 06-09-2022 at 06:14 AM. |
06-10-2022, 02:58 PM | #36 |
Honestly if you want a catted header stay stock get Tune+Flex Fuel for Corn if you have it around you.
2013 Series 10 FRS #553
06-11-2022, 10:39 AM | #37 |
It's getting crazy when the cost of a header exceeds the cost of a short block.
06-11-2022, 04:06 PM | #38 |
Drives: 17 BRZ
06-15-2022, 10:48 PM | #39 |
Drives: 2020 BRZ Sport Tech RS
As I mentioned before, with the overall design (I.E. where the merges are) being so similar to OEM and the primary / secondary / collector tubing sizes, it's unlikely the HKS GT-Spec header would make much more power (if any) vs. an OEM 2017+ header.
Sure, it's not as pretty, but if you can pick one of those up from a local wrecker you'll probably save yourself a bundle and get similar results.
The Following User Says Thank You to Tatsu333 For This Useful Post: | Dirty Harry (06-16-2022) |
06-16-2022, 09:56 AM | #40 |
I think they use better materials in the catalytic converter so it might be more efficient. But good points you make, the HKS headers do sound good though.
The Following User Says Thank You to Dirty Harry For This Useful Post: | Tatsu333 (06-16-2022) |
Similar Threads | ||||
JDL UEL Catted Header vs FT86 SpeedFactory UEL Catted Header | Thomas K | BRZ First-Gen (2012+) -- General Topics | 9 | 03-08-2021 08:39 AM |
JDL UEL Catted Header vs FT86 SpeedFactory UEL Catted Header | Thomas K | Scion FR-S / Toyota 86 GT86 General Forum | 0 | 03-06-2021 06:58 PM |
WTB: OFT V2 and ft86 speedfactory catted header/ or any other catted header | Control_Dopamine | Want-To-Buy Requests | 0 | 05-14-2020 03:31 PM |
FS: P&L catted & coated EL header, Perrin catted front pipe and res 2.5" catback | Turbowned | Engine, Exhaust, Bolt-Ons | 13 | 08-11-2019 11:54 PM |
Sound question : Catless header + HFC Fp and Catted headr + catted Fp ? | l3ooml3al2al3a | Engine, Exhaust, Transmission | 12 | 03-22-2019 10:22 AM |
