Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
07-01-2022, 08:37 AM | #1 |
Drives: BMW 135i
New wheels - colour choices and spacers
Just picked up a new set of wheels. Keep them gold or go silver ?
Also due to the size and offset and the PP front suspension I will need to run 8mm spacers up front. Should I run spacers on all 4 corners or just the fronts. Thanks |
07-02-2022, 12:25 PM | #2 |
LMGTFY
Drives: 13 FRS, 91 Miata
Pink... with that color.
The Following 2 Users Say Thank You to x808drifter For This Useful Post: | Mtl135i (07-04-2022), soundman98 (07-02-2022) |
07-02-2022, 12:59 PM | #3 |
ProCrastinationConsultant
fyi, that getcoloreffects.com site got blocked by my browser addon:
" Title: uBlock filters – Badware risks ! Description: For sites documented to put users at risk of installing adware/crapware etc. ! The purpose is to at least ensure a user is warned of the risks ahead." i vote pink as well. or lime green. silver is boring. silver is average. silver is typical. silver is a camry, it's the safe option. be a shining star of color.
The Following User Says Thank You to soundman98 For This Useful Post: | Mtl135i (07-04-2022) |
07-03-2022, 01:12 AM | #4 |
Drives: 2017 subaru brz
Silver goes well with your paint color. If it was my car, I would choose silver, but I think it needs to be accompanied by a 1" drop.
Btw, how did you change the color of your wheels like that? I'd like to do the same to my own to help myself make decisions lol. |
The Following User Says Thank You to ItsReiko For This Useful Post: | Mtl135i (07-04-2022) |
07-03-2022, 03:56 AM | #5 |
Drives: Toyota 86 GTS
Black would look cool
Check your wheels can run spacers, I had 2 sets of wheels that wouldn’t fit spacers under 20mm as the recess for the studs were further out than where they needed to be, and so the stud would hit and prevent the wheel being bolted on. You should definitely run spacers on the rear, and a larger spacer at that as the wheel doesn’t poke out of the guard as much as the front |
The Following User Says Thank You to Sam86 For This Useful Post: | Mtl135i (07-04-2022) |
07-09-2022, 01:08 PM | #6 |
Silver, because I'm old. Nice wheels btw.
And yes spacers all around with appropriate studs. - Andrew |
07-11-2022, 05:23 AM | #7 |
Wheels for Brains
For spacers, you can use a slip-on up to 3mm the way the car sits. Any slip-on spacer thicker than 3mm and under 10mm, you need extended wheel studs.
Spacers 10mm or thicker, you should get bolt-on spacers. |
07-11-2022, 05:43 AM | #8 |
Drives: 17 Asphalt 86
I prefer silver, all though a bronze or gunmetal could work.. I like darker color wheels.
ARP extended wheel studs will give you room for slip on spacers. 2.5" is perfect for what you are after, I run 8mm spacers with plenty of threads. You should be removing the rear hub to install studs but it's possible to install them without removing if you are willing to do some trimming, by cutting the nipple off at the end of the stud. |
07-14-2022, 07:32 PM | #9 |
Run spacers all around with proper stud length. Either color looks okay but I'd probably just keep them gold if the wheels are already gold.
Similar Threads | ||||
OEM STI wheels + Spacers | spicyricecake | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 18 | 07-14-2016 12:17 PM |
Opinion on tire/wheels choices for tail of the dragon | BobWhite | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 3 | 02-23-2016 07:30 AM |
Do spacers fit OEM Wheels ? | Wil | Scion FR-S / Toyota 86 GT86 General Forum | 3 | 09-19-2015 10:33 PM |
Spacers on OEM wheels? | BRZlimited | BRZ First-Gen (2012+) -- General Topics | 13 | 04-11-2014 07:47 PM |
Stock Wheels Need Spacers? | theom | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 3 | 08-17-2013 11:49 AM |
