Old 04-09-2021, 02:37 AM   #15
kev0
Drives: '14
What the hell. Either I am super unlucky with Ethanol or the sensor is bad. Either way, i'm fucked. I topped off with the E85. I mean, it still drove fine though. Fuel trims were a bit lean though as soon as the 'E85' started going through the lines. Even if it was bad E85, wouldn't my sensor reading something other than 10%?! It has to go up a few numbers at least.
kev0 is offline   Reply With Quote
Old 04-09-2021, 02:42 AM   #16
kev0
Drives: '14
Originally Posted by tomm.brz View Post
i m not in your tuner's head and need a log to look at possibily with a cold start and all the Flex values ticked in in ecutek for logging
would be very stupid to put fix 11% for flex, even if you put e85
so no i do not think so
the fixed value i was talking about is forced by ecutek if the flex sensor gets faulty basically
https://datazap.me/u/kev0/bad-gas?log=0&data=18
Here's a small log. Not a cold start log but a small driving one. Do you see anything out of place while I wait for my tuner to wake up and reply to my email.
Old 04-09-2021, 05:21 AM   #17
tomm.brz
Drives: brz 2017 hksv2
yes, i can see you have ethanol, BE VERY CAREFUL going to open loop .. do not WOT your car at the moment as i don t think the "cl fuel correction %" will keep up with the fuel demand on hard pulls, timing will be low but will go very lean
unless tuner did something superwrong in the sensor scaling (very unlikely) i think sensor went bad and it's keeping the minimum scaled amount
kev0 (04-09-2021)
Old 04-09-2021, 05:51 AM   #18
kev0
Drives: '14
thx for your time Tomm.brz. Think im going to go ahead and order a new sensor. Pretty much every flex fuel kit for our platform uses the same sensor right?
https://www.amazon.com/ACDelco-13577.../dp/B01GQR9C5O
Thinking about just swapping it out with this one
Old 04-09-2021, 06:14 AM   #19
tomm.brz
can' t help you in that
kev0 (04-09-2021)
Old 04-09-2021, 11:22 AM   #20
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
Before you change sensors out, test your fuel. If the results are significantly more ethanol content than what your gauge reads and what your ECU is reading, then there's still the possibility that water is affecting the sensor and replacing it will not fix the problem. However, if the sensor IS bad or there is water present and you actually have E85 in your tank, then your engine would not be running properly if at all.
All of your evidence is pointing to the probability that there is only 11% ethanol content in your fuel.
TEST YOUR FUEL.
My pubes are shaped like the number 86. There for I’m car. Derp
Count to muffens and call again.
I’m 40. So....... say hi to your sisters or daughters.
FR-S2GT86 is offline   Reply With Quote
Old 04-09-2021, 12:34 PM   #21
kev0
Drives: '14
TEST YOUR FUEL.
Attachment 199083
Ethanol test kit arriving by Sunday. Car will be down until then, but like Tomm said, there is definitely ethanol in there. Just weird how my Zeitronix gauge is not reflecting it.
Old 04-09-2021, 12:52 PM   #22
tomm.brz
TEST YOUR FUEL.
Attachment 199083
where are "all" those evidence?
his tune was good before, and now he has 35+% of LTFT and a super lean open loop state
Change ethanol sensor
Old 04-09-2021, 09:53 PM   #23
kev0
Drives: '14
Welp, it's not the tune and the gas is definitely ethanol. I'm all out of ideas. It's just problem after problem with this car.
Really hoping it's just a bad flex fuel sensor.
The Following User Says Thank You to kev0 For This Useful Post:
tomm.brz (04-10-2021)
Old 04-11-2021, 02:42 PM   #24
kev0
Drives: '14
Fixed it guys. It was a bad flex fuel sensor. Strange.. I thought these things never failed. As soon as I replaced it, the sensor started reading ~E65 which is what the mix was.
The Following 2 Users Say Thank You to kev0 For This Useful Post:
tomm.brz (04-11-2021), Wally86 (04-13-2021)
Old 04-11-2021, 04:12 PM   #25
churchx
churchx's Avatar
Drives: 2014 GT86
Old sensor got drunk / became alcoholic from ethanol. You could no more believe to what he said
kev0 (04-11-2021), Wally86 (04-13-2021)
Old 04-18-2021, 02:32 AM   #26
jflogerzi
jflogerzi's Avatar
Yea Zach knows his shit. He tuned my car when I had your kit the car drove fantastic. As other mentioned Zach won't got to E till the car's tune is dialed in on pump
2013 Series 10 FRS #553
Delicious tune OFT flex fuel kit vin08 Engine, Exhaust, Transmission 9 02-11-2021 05:13 AM
Ecutek E85 Flex Fuel Tune airrick Software Tuning 6 04-15-2020 04:38 AM
thinking of getting DT stage 2 flex fuel tune, do I need a flex fuel kit? stlgrym3 Engine, Exhaust, Transmission 4 03-23-2018 02:51 AM
ECUTek Flex Fuel iketiak Engine, Exhaust, Transmission 1 10-24-2013 06:15 PM
ECUtek Flex Fuel REVOLUTION: World's First Flex Fuel Factory ECU GTR - BRZ soon! Visconti Engine, Exhaust, Transmission 356 05-20-2013 09:36 AM
