Old 10-18-2022, 10:37 PM   #1373
captain awesome
Wears Pants
Drives: 14 FRS K24 swap - SOLD
Originally Posted by Four_wheel_drifts View Post
Is anyone running a 3 exhaust option that actually sounds good without terrible drone?
My buddys kpower conversion with the Perrin 3 sounds good at high RPMs on track.
It is HORRIBLE driving to and from the track.
I absolutely needed hearing protection or noise canceling ear buds for the 135 mile trip.
Hes a decade older with much worse heating than mine; so fine for him. Absolute no go for me.
Xforce 3 is pretty awesome so far sound wise. I posted up some videos in this thread a while back. Super mellow until you start giving it the beans but no drone. Even better it has the recommended flex joint.
Part number is XFO ES-T86-02-CBS
captain awesome is offline   Reply With Quote
The Following 2 Users Say Thank You to captain awesome For This Useful Post:
DocWalt (11-10-2022), Four_wheel_drifts (10-19-2022)
Old 10-19-2022, 09:21 PM   #1374
Four_wheel_drifts
Drives: Whiteout track car; lava donor
Looks very similar to the 2.5 TRD exhaust I have now. The Xforce website has a typo saying the piping is 2.5 diameter.
Ill listen to you videos. Thanks.
Four_wheel_drifts is offline   Reply With Quote
Old 10-19-2022, 10:16 PM   #1375
captain awesome
Wears Pants
TRD and the Perrin are different in that they both enter the center. Xforce is laid out like stock with side entrance, so its considerably quieter.
Old 10-21-2022, 12:32 AM   #1376
funkjaw
Drives: 16' WWB
I also have the Xforce and I love it. Almost 10,000 miles on the swap and the exhaust is holding up perfectly. Couldn't ask for more out of a 500 dollar catback.
https://youtube.com/shorts/1tjq3-VA1-I?
funkjaw is offline   Reply With Quote
The Following 2 Users Say Thank You to funkjaw For This Useful Post:
captain awesome (10-21-2022), Four_wheel_drifts (10-23-2022)
Old 10-21-2022, 09:15 AM   #1377
captain awesome
Wears Pants
Dang you only paid $500? Mine was $600 before tax through MAP.
The Following User Says Thank You to captain awesome For This Useful Post:
funkjaw (10-21-2022)
Old 10-21-2022, 01:16 PM   #1378
all4spl
So is the X-force 3" or 2.5"?
all4spl is offline   Reply With Quote
Old 10-21-2022, 01:21 PM   #1379
captain awesome
Wears Pants
They sell both sizes but the part number listed above is correct for 3.
Old 10-21-2022, 05:04 PM   #1380
funkjaw
Drives: 16' WWB
I used "Honey" chrome extension to clip a 10% off coupon, bringing it from ~$600 to $538.65. Whenever I buy stuff online I always check Honey or Rakuten for savings. On Rakuten alone I've redeemed $867.32 in real cash back so far since using it the last 3 years. Highly recommend both of those extensions!
The Following User Says Thank You to funkjaw For This Useful Post:
Old 10-26-2022, 03:10 PM   #1381
RedReplicant
Drives: None
Another KSwap guy had some smoke issues, turned out the header heated the passenger floor area enough to burn the insulation.
I went out and checked, mine is yellowed in the same area.
Probably worth pulling back the carpet and taking a peek for you full interior people. Both of our cars have ceramic coated headers.
Another thing I have noticed is that my car drops oil pressure to the low-mid 20s when on the brakes off throttle. I kind of want to ignore this since the same thing happened with my Miata, but at the same time it is kind of an issue.
I have seen this in all of the other K86 track data logs as well.
RedReplicant is offline   Reply With Quote
The Following 6 Users Say Thank You to RedReplicant For This Useful Post:
captain awesome (10-28-2022), DarkPira7e (10-26-2022), endless_pain (10-28-2022), funkjaw (10-26-2022), Kelse92 (11-01-2022), ML (10-26-2022)
Old 10-26-2022, 04:14 PM   #1382
ML
ML's Avatar
Drives: 13 White MT FR-S
My floor is the same in that same spot but I thought it was because an exhaust bolt backed out and I had a exhaust leak right on the body in that spot. I added some dimpled aluminum/fiberglass heat shielding to the exhaust in that spot.
Old 10-26-2022, 04:23 PM   #1383
RedReplicant
Drives: None
That could be the case, but I don't think it is the complete cause.
That three bolt flange was a poor idea - you can't reasonably get to the top bolt in car, the welds for the flange to tube run up onto where locking bolts sit, and it hits the body because it is so large.
Next time I have the header out I'm cutting the thing out and making it a slip joint or vband.
Old 11-01-2022, 04:07 PM   #1384
RedReplicant
Drives: None
Few notes from the weekend:
1. My shift knob shift pattern roundel thing came off in my hand during a session so I threw it on the passenger floor, it now has yellow/brown marks where it was burned by the floor. I don't think that heat thing is an exhaust leak only thing.
2. KPower header / no cat / Perrin 3" passes a 96dB sound limit without turns
3. KPower says we should be running a quart over the full mark on the dipstick to not drop pressure, we will see if that is legit in two weeks
4. My car is still an oversteer murder machine and I need to fix it, exiting 2nd gear corners is yay dorifto (super slow). Car immediately goes to 100% steer by throttle in 3rd/4th gear sweeper type corners once the power is on. This has been an issue with it since I bought it, the journey continues.
Either way, car ran another 8 full sessions over the weekend without a hiccup.
The Following 2 Users Say Thank You to RedReplicant For This Useful Post:
captain awesome (11-01-2022), funkjaw (11-01-2022)
Old 11-01-2022, 04:54 PM   #1385
funkjaw
Drives: 16' WWB
Thanks for all the feedback! Keep us updated.
RedReplicant (11-01-2022)
Old 11-02-2022, 08:17 AM   #1386
ML
ML's Avatar
Try to take some sway bar out of the rear, or soften the rear dampers a bit
The Following User Says Thank You to ML For This Useful Post:
RedReplicant (11-02-2022)
Search this Thread:
Advanced Search
Rigid Industries SR-Series Pro Light Bar on my BRZ Stang70Fastback Cosmetic Modification (Interior/Exterior/Lighting) 3 12-29-2019 03:13 PM
Airlift from industries finest J_Nasty Member's Car Journals 0 02-04-2017 01:59 PM
Carbox Industries - Introduction CarBox CANADIAN Sales 5 04-22-2014 01:22 PM
86 industries Duthebarber Northern California 70 03-28-2014 04:10 PM
Another 86 Industries another bad experience sikest User/Vendor/Sponsor Reviews, Feedback, Comments 3 03-13-2014 01:00 AM
