02-18-2013, 12:21 PM | #477 |
Drives: Toyota 86 ZN6
because tofu
02-19-2013, 05:46 AM | #478 |
Drives: Red 86
Does your 86 too does not have auto lock door features? (it automatically locks the doors on a certain speed) first time to own a car like this, my ignorance.
02-19-2013, 05:56 AM | #479 |
Drives: Toyota 86
Yes. I don't know if it could be programmed but it would be nice to have that feature. It doesn't bother me as it is a habit of mine to lock the doors before setting off
02-19-2013, 05:57 AM | #480 |
yup... wala po papa booch.. pero ganda rin sana kung meron
02-19-2013, 06:12 AM | #482 |
02-19-2013, 07:38 AM | #483 |
Drives: Toyota 86
No autolock function for the 86 even with techstream. Hassle nga eh. Our 2008 Camry had autolocking door locks when you reach a certain speed. Pero our LC200 doesn't have it also
02-19-2013, 07:45 AM | #484 |
papa HRTROB.. dun sa fuse/relay box sa engine.. ano kaya meaning nung DIM na relay? kase i saw ur "how to" dun sa DRL, just wondering if alam mo ano meaning nung DIM...
chineck ko kase manual natin hindi ko mahanap ano meaning nung DIM.. baka alam nyo po.. tnx |
02-19-2013, 09:00 AM | #485 |
Drives: Red 86
thanks sir, kasi nasanay na ako na may auto lock now i dapat tandaan ko lagi na ilock ang pinto.....mahirap na rare ang kotse natin baka masalihan
02-19-2013, 09:28 AM | #486 |
Drives: Toyota T86
where can we place our parking sensor (back)? if there is...
02-19-2013, 11:20 AM | #487 | |
Drives: Toyota 86
Yung DIM relay is for the bixenon shutter. When I disconnected the DIM relay, di na gumana yung high beam mode ng projector. Bixenon kasi yung projectors ng 86, meaning there is a solenoid that controls the shield/shutter. When you switch to high beam, bumababa yung shield to allow all light to pass through |
The Following User Says Thank You to HRTROB For This Useful Post: | jdmasfcuk (02-19-2013) |
02-19-2013, 11:22 AM | #488 |
Drives: Toyota 86
02-19-2013, 01:34 PM | #489 | |
pumunta ako sa Subaru dealer dito samen to check if they have the relay pero wala pa raw.. will just try checking my nearest auto supply Last edited by jdmasfcuk; 02-19-2013 at 01:52 PM. Reason: ♥86 |
02-19-2013, 06:24 PM | #490 |
Drives: Lightning Red BRZ MT Limited
HRTROB I have a USA version BRZ, alam mo ba kung pano gawing independent from the headlights ung fog lamp?
I can't turn the fog lamp ON when the Headlights' Low beam is turned off Ung PH version kc need lang park light na naka ON tapos pwede na mag ON ung FOG lamps. |
