Scion FR-S / Toyota 86 GT86 General Forum The place to start for the Scion FR-S / Toyota 86 | GT86 |
01-20-2022, 12:02 PM | #1 |
Drives: 2014 Scion FR-S Monogram
wheels/tires and coilovers
Hey guys, Im new to the car world. I recently got a 2014 FRS and I want to change the wheels from the stock ones (215/45R17, 17x7+48) to some aftermarket ones (245/35R18, 18x8+38). the thing is, i dont want the wheels to rub because my suspension is still stock, so im thinking about going on coilovers. the thing with that is that i read somewhere online that the cv joints on this car are weak, so i would need a diff/subframe riser if im going on coils. is that true? I want to keep the stock height, maybe lower it by .25-.5 of an inch. would i need a diff riser so that the cv joint doesnt break?
01-20-2022, 12:08 PM | #2 |
Drives: Crapcan
Why 18's? They are more expensive, heavier, and tires are more expensive.
There is an entire section of the forum with tire/wheel setups with pictures. I recommend looking there. People are getting away with 245's on stock struts. The stock CV's are not an issue unless you are running stupid low, and even then it is not the issue people make it.
The Following User Says Thank You to NoHaveMSG For This Useful Post: | Spuds (01-20-2022) |
01-20-2022, 12:15 PM | #3 | |
Wes
Instagram: @gt86ws
01-20-2022, 03:11 PM | #4 | |
The Dictater
Drives: '13 Red Scion FRS
https://www.ft86club.com/forums/forumdisplay.php?f=24 |
01-20-2022, 04:04 PM | #5 | |
Drives: BRZ Limited, V10+ R8, Macan S
01-20-2022, 04:10 PM | #6 |
Drives: Crapcan
If that is your reasoning that is fine, a lot of people don't understand the negatives which is why it gets asked.
01-20-2022, 06:37 PM | #7 | |
Drives: Totaled 2013 Toyota Corolla
01-20-2022, 07:39 PM | #8 |
01-20-2022, 09:17 PM | #9 |
01-22-2022, 10:01 PM | #10 |
if i were to go on lowering springs, will i be able to use the stock struts or would i have to buy new ones?
01-22-2022, 10:47 PM | #11 |
Drives: Chevrolet Ram 250
01-23-2022, 12:45 AM | #12 |
Drives: Subs
Hello buddy
Sent from my iPhone using Tapatalk Pro |
01-23-2022, 11:29 AM | #13 | |
Drives: '23 BRZ
Lowering only 0.5", you don't have to worry about stock suspension or drive/halfshafts. Or going to coilovers or struts/shocks. RS-R Down springs will lower you ~0.5". If you go lower than RCE Yellows (0.8"), IMO you'd wanna get Bilstein B6, or go coilovers due to stock struts having limited bump travel. |
01-23-2022, 05:02 PM | #14 | |
Drives: 2013 frs base
Tags |
coilovers, wheels and tires |
Similar Threads | ||||
WTB: STX Suspension (Coilovers) and Wheels+Tires | Optimoose20 | Want-To-Buy Requests | 0 | 08-25-2020 03:56 PM |
FS: Stock 2012 FR-S wheels/tires and Enkei PF01 Winter Wheels/Tires - Lexington KY | deljaso | Wheels and Tires | 3 | 04-22-2020 08:33 PM |
Remove P4S tires from my stock BRZ PP wheels and mounting snow tires? | jredders | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 9 | 10-25-2019 11:30 PM |
BC Coilovers installed-Stock Wheels/Tires | continuecrushing | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 01-27-2016 06:32 PM |
