06-27-2017, 04:21 PM | #785 |
06-28-2017, 07:37 AM | #786 |
Drives: None
06-28-2017, 07:44 AM | #787 |
07-15-2017, 11:11 AM | #788 |
poor man's evora
Drives: Turbod BRZ
Need some advice. I have a turbo brz with a full blown radiator, mishimoto slim fans and shroud, a 15 row oil cooler w/mocal thermostatic plate, vented hood. Turbo has a blanket and all exhaust parts are heat wrapped. In texas, temps have been about 100 degrees. My car runs hot in traffic after 30 mins, and driving over long time on just local roads in this heat. Coolant temps run 230-235, oil temps 230-240 with the a/c on. Running 5w20 oil. I have to turn on the heat to keep the coolant temps stable or untill I pickup some speed. What else can I do to help? Vent the fenders? Cut open the skid pan? Thicker oil? Coolant was replaced earlier this year with OEM Subaru Blue.
07-15-2017, 11:15 AM | #789 | |
07-15-2017, 11:18 AM | #790 |
poor man's evora
Drives: Turbod BRZ
even though everything is already wrapped? i know the engine bay is like an oven, and the fans are definitely pulling in alot of air. i wonder if just all the hot air can really escape
07-15-2017, 11:57 AM | #791 |
-Phil's BIGGEST FAN BOI
Drives: 2014 Greddy Turbo BRZ
hot air rises and cold air falls...at least that's what I remember from middle school, haha. Using that knowledge, I would assume vents would help dissipate some hot air that's just effectively sitting inside the bay by giving it a place to go.
2014 Subaru BRZ
Don't follow your dreams, follow my instagram www.instagram.com/soloside |
07-15-2017, 02:28 PM | #792 |
He's already vented though. Hot air rises but not fast enough to escape his engine bay
07-15-2017, 04:00 PM | #793 |
Drives: 2014 BRZ
I’d check the cooling system (no air, thermostat, water pump ...). turbo or not, in those driving conditions, there should not be excessive heat generated
07-15-2017, 09:18 PM | #794 | |
Drives: 2015 Raven FRS
07-16-2017, 09:39 AM | #795 |
Drives: 2013 FRS / 2013 427 Vert
We are pushing 100 here in Central Florida and I have a similar setup except for a Jackson supercharger rather than turbo. I can do a slow crawl for an hour on I4 and coolant stays 191-195 regardless. Oil temps creep up over 200 in slow traffic and back to the 190's as soon as I'm moving. I am thoroughly impressed with the FB radiator and JR oil cooler.
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor 2016 Audi TTS APR Tuned |
07-16-2017, 10:24 AM | #796 |
Sounds like it's probably your thermostat if these guys aren't having heat problems
07-16-2017, 03:50 PM | #797 | |
Driving Coach
You probably have air in your system. I know I did. Runs at 210 F in slow moving traffic now in 95F ambient with the AC blasting. |
07-16-2017, 08:15 PM | #798 |
poor man's evora
Drives: Turbod BRZ
Thanks man I have the funnel and bleed my system for 15 mins. Gonna bleed it now for another 30 mins and see what happens
Similar Threads | ||||
any serious benefit Heat Tapes? | Djen | Engine, Exhaust, Transmission | 22 | 02-18-2014 03:20 PM |
Heat bad for your car? Ways to cool it? | BushMan | Scion FR-S / Toyota 86 GT86 General Forum | 35 | 08-01-2013 10:15 PM |
Misfire with heat? | bigjake | Issues | Warranty | Recalls / TSB | 2 | 04-28-2013 09:02 PM |
Do I Need a Heat Shield? | arleewa | Engine, Exhaust, Transmission | 1 | 01-08-2013 06:37 AM |
Overpipe Heat question | Amadeus | Engine, Exhaust, Transmission | 5 | 12-19-2012 01:18 AM |
