Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
07-24-2016, 01:58 PM | #1 |
Drives: 2013 FRS
Easiest way to prime oil system
I'm mainly looking to do a prime to get fresh oil to my new turbocharger. I want to cut fuel and spark so I can crank the engine for 15-20 sec to prime the oil system, oil cooler, etc.
I can easily enough unplug the 4 coilpacks, but I'm not sure the best plan to cut the fuel. Pull fuel pump relay? Some way in ECUTEK to do it? Anyone have any tips? |
07-24-2016, 02:09 PM | #2 |
Pretty sure if you push the gas pedal down while cranking, the car wont start.
07-24-2016, 02:20 PM | #3 |
義理チョコ
^^^ can confirm. All the way down is flood-clearing mode. I do it at every oil change because I'm one of those people.
The Following User Says Thank You to Ultramaroon For This Useful Post: | mhiscott (07-24-2016) |
07-24-2016, 02:45 PM | #4 |
Drives: 2013 FRS
Well that's easy lol. Thanks guys!!
07-24-2016, 04:03 PM | #5 |
義理チョコ
Now don't go burning up your starter.
03-15-2017, 04:23 PM | #6 |
Drives: RHD Gt86
will just swinging the engine without starting be enough to bring the oil up through the turbo feed line?
Toyota - Making Dreams A Reality
461hp on 91octane - JDL turbo GTX3076r GEN 2 - Mazworx CD009 transmission |
03-15-2017, 10:05 PM | #7 |
義理チョコ
Yes. Owner's manual warns 10 seconds max. That seems like a painfully long time to crank the engine.
The Following User Says Thank You to Ultramaroon For This Useful Post: | Kris86 (03-29-2017) |
03-15-2017, 11:18 PM | #8 |
poor man's evora
Drives: Turbod BRZ
or you can just remove the fuel pump fuse
03-15-2017, 11:38 PM | #9 |
義理チョコ
Because that's easier than pushing the gas pedal?
The Following User Says Thank You to Ultramaroon For This Useful Post: | D_Thissen (03-18-2017) |
03-16-2017, 08:33 AM | #10 |
poor man's evora
Drives: Turbod BRZ
less chance to mess something up
03-18-2017, 11:19 AM | #11 |
Drives: Late 2014 Subaru BRZ
Just a question but cant oil just be added into the block using a funnel in the oil filters barb to help prime the oil pump on a clean fresh block?
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe |
03-18-2017, 11:47 AM | #12 | |
Sometimes I'm wrong.
Drives: '13 FR-S/'96 240SX
Fresh block should have assembly lube and a full pan, so priming without starting should be enough. Pouring oil through the filter hole wont really get it in the pump, since it's a positive displacement pump and nothing will flow through it without it moving. At least that's what I think. |
The Following User Says Thank You to murdoc For This Useful Post: | Ultramaroon (03-18-2017) |
03-18-2017, 01:52 PM | #13 |
義理チョコ
I've never bothered but murdoc's almost there.
1. Fresh build has assembly lube. 2. Pouring downstream of a positive displacement pump. Now, if one were so inclined, one could pump/pour some oil down the center. That's the output of the filter. Is it worth it? Meh. That part drains down anyhow. Think about when you change your filter. Bone dry in there. Lubrication system: General, System Diagram, Details
Similar Threads | ||||
Which SC kit is easiest to install? | tzbang | Forced Induction | 51 | 11-10-2015 12:25 PM |
Easiest oil change | tzhu07 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 51 | 04-18-2014 10:27 AM |
easiest color to keep looking clean? | fatoni | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 25 | 10-10-2013 07:21 PM |
Easiest way to get to the over-pipe? Doing an install... | seven | Engine, Exhaust, Transmission | 7 | 02-03-2013 07:38 AM |
Colors easiest to keep clean yet looks good | fitcious | Scion FR-S / Toyota 86 GT86 General Forum | 31 | 01-16-2013 02:22 PM |
