Northwest AK, ID, OR, WA
Old 11-06-2015, 12:43 PM   #29
DoomsdayJesus
In Autobahn withdrawl
DoomsdayJesus's Avatar
Drives: 2015 BRZ Limited Man., WRB
Originally Posted by PNW FRS View Post
The matte spray paint was just some leftover stuff from Lowes that I had from another project. And for the reinstall of the brake light, I bought some 3m tape from O'Reiley's and replaced the "OEM" tape (torn during removal for tinting) -- being careful to remove as much as possible (quite a job) and then being very fastidious with how I applied the new 3m tape when it came to the "corners" (i.e., cutting the diagonal "seams". As mentioned in earlier post... I'd highly suggest doing the tint first.... then install the painted brake light (w/oem 3m tape) about 4-5 days later -- then add the HIC visor if you're so inclined. Speedzone needs an unobstructed rear window to cut the tint material to size. I was lucky that another 86'er was at the shop and we used her rear window as the "template." (Thanks again Michelle!)
I'm already tinted, think I may do it myself but right now I'm recovering from back surgery so crawling around the back seat isn't something I'm eager to do. I need to get my racing springs as well. Out of curiosity did you use the high temperature black 3M tape? I haven't seen it lately at autozone, only the high temp gray.
I saw the housings that the other guy on the forums is making with CF and fiberglass, but the price is a little steep if I can do this effectively for $50-60.
DoomsdayJesus is offline   Reply With Quote
Old 11-06-2015, 03:32 PM   #30
PNW FRS
PNW FRS's Avatar
Originally Posted by DoomsdayJesus View Post
Out of curiosity did you use the high temperature black 3M tape? I haven't seen it lately at autozone, only the high temp gray..
I used the med-dark gray 3m tape. I would have gone with a black version if I had known there was that option.
2013 Asphalt / MT
Olympia, Washington
PNW FRS is offline   Reply With Quote
Old 11-06-2015, 04:03 PM   #31
MisterSheep
Killed Scion
MisterSheep's Avatar
Drives: 2013 FR-S Whiteout
Any more pictures from the back of the car?? I was going to do a top mount brake light but afraid that the HIC roof spoiler was going to get in the way. SUPER GLAD that someone actually did it with the visor.
Instagram: trevor.parque
Old 11-06-2015, 06:47 PM   #32
PNW FRS
PNW FRS's Avatar
Here you go!
2013 Asphalt / MT
Olympia, Washington
The Following User Says Thank You to PNW FRS For This Useful Post:
Ammunition (11-07-2015)
Old 11-06-2015, 11:01 PM   #33
MisterSheep
Killed Scion
Here you go!
Nice!!!!!
Thanks so much! Car looks spot on with the CF spoiler and the roof visor!
Old 11-25-2015, 03:20 PM   #34
slyphen
slyphen's Avatar
Drives: Man
Send a message via AIM to slyphen Send a message via Yahoo to slyphen
i think i'll 3D print some plugs to fill up the hole in the deck.
slyphen is offline   Reply With Quote
Old 11-28-2015, 12:42 AM   #35
PNW FRS
PNW FRS's Avatar
Anxious to see how that works out for you...
2013 Asphalt / MT
Olympia, Washington
Third brake light...(top mount) Slide Cosmetic Modification (Interior/Exterior/Lighting) 103 02-22-2017 02:47 PM
Top mount 3rd brake light....off center? Jonesy86 Northwest 44 07-17-2015 05:52 PM
Top mount 3rd brake light Jonesy86 Northwest 1 06-12-2015 02:41 AM
Exogear Car Mount Review - INSTALLED MattQ-WP Electronics | Audio | NAV | Infotainment 10 11-30-2012 02:32 AM
NW Shop Review: Speedzone (Lakewood WA) DarrenDriven Northwest 2 10-19-2012 11:37 PM
