Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
04-19-2020, 08:21 AM | #15 |
PFC has a part number for 2 piece stock sized rotors. I've been meaning to look into that.
We've been working with them a lot lately...their 2 piece rotors are extremely good. - Andrew |
The Following User Says Thank You to Racecomp Engineering For This Useful Post: | RuyGuy2 (04-19-2020) |
04-19-2020, 09:46 PM | #16 |
Dysentery Enthusiast
Drives: 2017 toyota 86
There web page is a bit confusing doesn't list anything for the BRZ but it does for the WRX you wouldn't happen to have part numbers?
04-19-2020, 10:30 PM | #17 |
Drives: C5 Corvette, '17 Toyota 86, Jeep XJ
Like the creativity and saving weight is extremely important on an underpowered vehicle.
Did you know this kit is available. Ive had it for a few years and its great, Although it was like ~$900 bucks back then. But you get 30 lbs total off the front and most comes from the 2pc rotors. https://www.ft86speedfactory.com/wil...l#.Xp0Ir25Fw2w |
04-20-2020, 01:18 AM | #18 | |
04-20-2020, 11:22 AM | #19 | |
Drives: Crapcan
04-20-2020, 11:38 AM | #21 |
Drives: 2014 GT86
for if same, i guess also worth checking compatible pad shapes & area, fact that those are for 350z while wrx 4pot is, well, for wrx, would make me double check things, if they really are same.
He should have stated earlier that he plans to install also biasing valve, that should allow to make any needed adjustments. Though that rises total cost and installation simplicity imho way past "low dollar", especially if further rising budget via pairing with two piece rotors. So it all turns back that it makes more sense to get BBK right away, possibly subbie 4pot one. No custom mounting bracket required, already two-piece rotors, lot of weight saved (which was stated among prioritized goals). |
04-20-2020, 11:44 AM | #22 | |
Drives: Crapcan
The bias change is minimal. We are talking .697 vs .698
04-20-2020, 12:12 PM | #23 | |
Here is what I was looking at doing. These Hats, https://www.wilwood.com/Hats/HatProd?itemno=170-9206 These Rotors, https://www.wilwood.com/Rotors/Rotor...%20%20&appid=0 I will have to space out my calipers to go from 11.44" rotor to the 11.75" The inside offset is the same with these rotors and hats as it is with the wilwood kit that has the .8" rotors. With that being constant these hats with these rotors will work. Probably have about $265 into each Rotor. |
04-20-2020, 12:14 PM | #24 |
Drives: 2014 GT86
NoHaveMSG: but are stock rotors & willwood 4pot ones of same diameter? Is caliper at same distance from rotational axle? After all, by simple principle of lever, depending on distance even with same torque/friction at caliper/pad, brake torque at wheel may differ. That, and pad shape/area. Several things making up actual torque. Of course, again, with adjuster valve in picture it doesn't matter much.
RuyGuy2: btw, what is part number of those 350z calipers? I'm curious to compare with subbie 4pots. |
04-20-2020, 12:17 PM | #25 | |
Drives: Crapcan
04-20-2020, 12:33 PM | #26 |
04-20-2020, 12:38 PM | #27 |
Drives: 2014 GT86
Ouch. Indeed, somehow meshed up, in OP brake lines were ones from 350z. On calipers, only that it's 1.62" willwood 4pot from speedwaymotors.
04-20-2020, 01:01 PM | #28 |
Drives: 16 Silver BRZ, 04 Silver WRX wagon
Doesn’t rrracing have a good deal using Wilwoods. My only reason for not going wilwoods is they do not have dust boots. I get plenty of bad weather and snow in NY and not sure if I would have to rebuild sooner.
The Following User Says Thank You to Ernest72 For This Useful Post: | RuyGuy2 (04-20-2020) |
Similar Threads | ||||
Track car weight reduction | Irace86 | BRZ First-Gen (2012+) -- General Topics | 17 | 06-11-2016 05:21 PM |
Weight Reduction vs. Weight Distribution (for track use not for drag..etc) | glamcem | Tracking / Autocross / HPDE / Drifting | 21 | 07-01-2014 11:38 AM |
Weight reduction in the front only | KevinBRZ | Scion FR-S / Toyota 86 GT86 General Forum | 16 | 04-12-2013 12:25 AM |
the weight reduction of FR - S? | raiden8383 | Scion FR-S / Toyota 86 GT86 General Forum | 22 | 11-30-2012 06:10 PM |
Official Weight Reduction Thread - Sort of... | merlin2111 | Off-Topic Lounge [WARNING: NO POLITICS] | 77 | 10-07-2012 05:09 PM |
