Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
11-20-2016, 01:33 AM | #1 |
Drives: 2013 Scion FR-S (Firestorm)
Torque wrench necessary for putting on wheels?
Just wondering what common practice is on this forum. Hand tighten or torque wrench?
11-20-2016, 01:47 AM | #2 |
hand tighten while in the air (with a tire iron) and then torque wrench on the floor
11-20-2016, 01:51 AM | #3 |
義理チョコ
+1
11-20-2016, 01:57 AM | #4 |
Destroyer of Tires
Drives: 2001 Honda Accord, 1997 Lexus ES300
People get by without torque wrenches every day. If you use common sense when tightening your lug nuts you'll be fine. If you want to have peace of mind when you drive though, invest in a torque wrench.
The Following User Says Thank You to Redstar For This Useful Post: | Tcoat (11-20-2016) |
11-20-2016, 02:10 AM | #5 | |
Using a "cross" type lug wrench, cross rotating the tightening down of the DRY lug nuts, with the last tightening being two squeaks, worked for me up through the age of 60. After 60, it was two squeaks and a grunt. (disclaimer - works for DRY lug nuts only) If you wish to put that anti-seize stuff on the studs, it might be best to use a torque wrench. humfrz |
The Following User Says Thank You to humfrz For This Useful Post: | Cole (11-20-2016) |
11-20-2016, 02:16 AM | #6 |
Drives: Full race 4cyl boxer
Ask to borrow a buddies torque wrench one time.
Torque your wheels with both the TR and you own personal breaker bar, star wrench , etc. You will be able to feel what is right after that.
Arguing with an engineer is like wrestling with a Pig in the mud. You are never going to win and after a couple of hours you realize that he likes it.
The Following User Says Thank You to justatroll For This Useful Post: | humfrz (11-20-2016) |
11-20-2016, 07:24 AM | #7 |
The TQ wrench is the right thing to do. You might be successful hand tightening... might being the operative word. Remember the bigger risk is almost always being too tight and breaking something. (Although too loose can be bad too)
Sent from my SM-G920P using Tapatalk |
11-20-2016, 08:09 AM | #8 |
Huge E85 fan!
Drives: 2016 Scion FRS
You can get a torque wrench and a socket and it's not all that expensive. If you under-torque, obviously that's bad. But over-torquing can stretch threads and if you REALLY over-do it, warp your rotors.
That said, people tighten lugnuts using the German torque spec everyday and do fine. |
The Following User Says Thank You to guybo For This Useful Post: | p1l0t (11-20-2016) |
11-20-2016, 08:55 AM | #9 | |
11-20-2016, 09:23 AM | #10 | |
http://www.harborfreight.com/1-2-hal...rench-239.html
11-20-2016, 10:00 AM | #11 | |
Drives: 2019 Mazda Miata RF
I use this one, watch for sales: https://m.lowes.com/pd/Kobalt-1-2-in...Wrench/3381202 |
11-20-2016, 10:17 AM | #12 | |
Where I work we make 4 million rotors a year. Every year we get about 6 warranty returns for heat warping (why not 4 or 8 I will never understand) we have never once received a cold warped rotor back.
The Following 2 Users Say Thank You to Tcoat For This Useful Post: | JazzleSAURUS (11-21-2016), strat61caster (11-20-2016) |
11-20-2016, 10:28 AM | #13 | ||
Huge E85 fan!
11-20-2016, 10:41 AM | #14 |
Still tightening a flat surface against a flat surface. You will snap a lug bolt before you will warp a rotor. People may think they warped one tightening it but it is just not realistic. Unless of course you are using some flimsy ass bargain basement ones I guess.
The Following 2 Users Say Thank You to Tcoat For This Useful Post: | Qadthane (11-20-2016), strat61caster (11-20-2016) |
Similar Threads | ||||
Recomend torque wrench | jflogerzi | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 29 | 06-08-2017 06:38 AM |
Calculate torque when using a crows foot on torque wrench | BirdTRD | DIY (Do-It-Yourself) Guides | 0 | 10-11-2015 04:02 PM |
torque wrench | dcfr | CANADA | 13 | 05-15-2014 01:28 PM |
Socket set and torque wrench | Ty89m | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 10 | 07-29-2013 12:46 AM |
Torque wrench... Vendors welcome | Freeman | Off-Topic Lounge [WARNING: NO POLITICS] | 8 | 01-23-2013 05:30 AM |
