11-19-2020, 11:59 AM | #43 |
You want torque?
here is the swap for you. Cummins R2.8 Turbo Diesel Specifications:
The Following User Says Thank You to Tcoat For This Useful Post: | Tomm (11-19-2020) |
11-19-2020, 12:02 PM | #44 |
Sent from my ONEPLUS A5010 using Tapatalk |
11-19-2020, 12:03 PM | #45 |
Identifying as a Member
Drives: 2013 FRS LS1
Agreed, I just like unconventional swaps.... But your comment ab truck motors makes me want to drop my 2uz in my FRS.
In the midst of an LS1/T56 swap build page here or follow me on YouTube or IG.
ACT Clutches - APEXi - Buddy Club - Carbing - DBA - Diode Dynamics - Fidanza - HKS - ICT Performance - Project Kics - RPM Transmissions - SEIBON - Sikky Manufacturing - SPC - Tick Performance - TK Style - VERUS - VOLK - Whiteline |
The Following User Says Thank You to Tomm For This Useful Post: | Tcoat (11-19-2020) |
11-19-2020, 02:29 PM | #46 | |
Drives: 18 Brz (Sold) / 22 BRZ
Do you think something more drastic is needed? Cams? So, would it ve better to wait till wrx/sti versions of the FA24? Ford, as example, manages very well the same engine configuration across mustang, f150 and CD6 Explorer Last edited by Stonehorsw; 11-19-2020 at 02:32 PM. Reason: Improvements |
11-19-2020, 02:46 PM | #47 | |
I am going to stand by my statement that if they couldn't make the old WRX/STi engines work well in the twins I see no reason why this one would all of a sudden be a great swap. Can't think of the Gen 2 as the same car as the gen one since there are significant enough changes.
The Following 3 Users Say Thank You to Tcoat For This Useful Post: |
11-19-2020, 06:06 PM | #48 | |
Drives: Q5 + BRZ + M796
I'm guessing the WRX would stay with the FA20F and the STI will likely go with a beefy FA24F, but the motor might not drop into the 86 because of the oil pan, because the under-mount turbo causes interference, and because of things like where the starter mounts up. The internals will be stronger, but the motor will definitely be lower compression for pump gas, so it probably won't build power as fast, it will require more boost, nor have as good of gas mileage.
The Following User Says Thank You to Irace86.2.0 For This Useful Post: | Tcoat (11-20-2020) |
11-21-2020, 07:53 AM | #49 |
Drives: 2013 frs red
Probably be cheaper to buy the new car.
11-21-2020, 12:33 PM | #50 |
I would just part out and sell and jump to second gen. Way less hassles. Just my 2 cents
2013 Series 10 FRS #553
11-21-2020, 02:12 PM | #51 |
Weight Weenie
Drives: 15 FR-S
Jump to a new car? No challenge there. A motor out of a wrecked car won't be that bad and most everyone will have there Gen 1 paid for.
30K or 2-4K and some elbow grease? (Guessing at price before anyone gets their panty's in a not) |
11-21-2020, 02:54 PM | #52 |
Persona Non Grata
Drives: '15 BRZ (WRB)
It's still way to early to say with certainty, but it seems to me the best swap will be your Gen 1 ignition switch into a Gen 2 and use your old key.
Slow is smooth, and smooth is fast
The Following User Says Thank You to Capt Spaulding For This Useful Post: | Calum (11-21-2020) |
11-21-2020, 07:04 PM | #53 | |
Drives: '13 FRS - STX
Unless you value your labor at like $2/hour then go for it I guess. Will be curious to see how the new engine takes boost at 13.5:1 CR. And you don't have to wait until 2022 for engines to start hitting the junk yards. |
The Following User Says Thank You to strat61caster For This Useful Post: | NoHaveMSG (11-23-2020) |
11-21-2020, 08:53 PM | #54 | |
Weight Weenie
Drives: 15 FR-S
I'd prefer to stay NA and track the car a lot. I figure if I blow and engine or just wear one out why not swap it, if it's doable. The labour part doesn't bother me. It's a good learning experience and hobby. |
11-21-2020, 09:51 PM | #55 |
Drives: BRZ ts
I do not know the details of this so forgive the ignorance.
Wouldn’t this be the platform to do a cam tune with? |
11-23-2020, 11:08 AM | #56 | |
I don't know what new, anti-knock tech might be utilized on this new engine, but the 13.5:1 CR is pretty high for boost. Boost limits will likely be lower than the limits for the FA20D, but this engine might have new tech and the benefits of the extra 400cc of displacement and the higher compression to make the extra power, so perhaps there will be modest power gains or neutral gains on pump gas. Even if the static compression is high, the dynamic compression can be lower. On E85, people are running really high boost levels for the FA20D without issue, and I am not aware of what the boost limit is on the FA20D or what it could be on the FA24D. I think anyone looking for 500whp or less will find that the higher compression isn't an issue, and that it is an advantage for faster spooling, so more power across the rev range, along with better fuel economy over a conventional booster car. The downside will likely be much more heat from the higher compression, so tracking a boosted car might require more cooling issues, and there will likely be more variance between weather conditions, as timing gets pulled on hot days. The popularity of modifications typically follow an expense bell curve, in which, the most basic and least expensive mods are the most popular and the most expensive mods are the least popular. Diving deeper, the majority of people will do a catback then there are the ones doing full exhaust and a tune with maybe a CAI then there are the ones adding E85 to that setup then FI on pump gas then FI on E85 then FI on a built motor w/ or w/o E85, but typically it is with E85, and in that subset, there is a spectrum to the depths of the builds from piston/rod motors to built heads, closed deck, large stud setups. With that said, adding exhaust mods and E85 should yield decent gains with the high compression. FI on boost gas with the FA24D will have modest gains over the FA20D, if any. FI on a stock block with E85 should net 400-450whp with the higher compression and larger displacement and proportionally stronger motor unless they went cheap like using the same size rods as the FA20D (unlikely). This is going to be the sweet spot because the extra 50-100whp over the prior limit means the car is now in a new power bracket capable of competing with much more powerful cars. Anyone going for a built motor will likely want 500+whp (unless they just want more reliability or better pump gas gains), and they will likely want to drop compression to 10.5:1 on E85 (or something like that), so they can raise boost, while significantly lowering heat, whether that is to hit a power level or reliably track the car.
Similar Threads | ||||
FA20 vs FA24 | Zata | Engine, Exhaust, Transmission | 15 | 06-01-2023 10:18 AM |
2JZ Swap - Looking for Labor Info from Swap Shops/XP'd Members | Cookiemonster | Engine Swaps | 18 | 05-25-2019 12:40 PM |
FA24 Mix n Match | RiceCracker86 | Engine, Exhaust, Transmission | 1 | 04-18-2019 03:59 PM |
Dead RB25 Swap, Alive 2jz swap | -Phil | Engine Swaps | 72 | 09-15-2018 02:35 PM |
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions | Dezoris | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 15 | 06-06-2017 10:54 PM |
