Issues | Warranty | Recalls / TSB Problems, issues, recalls, TSBs |
10-19-2018, 11:22 PM | #29 |
義理チョコ
legit
10-27-2018, 07:14 PM | #30 |
Financial Distress
Drives: 2017 GT86 325WHP
Quick update: Went to the local crafts store (Michael's where I live) and picked up some cushion foam. The rattle from the back comes from the 3rd brake light's mount.
Open your trunk, look inside the ceiling of it, directly in the middle is a hole that will show daylight, and a black wire heading up through it. Cut some blocks from the foam and stuff it all deep inside that little hole, there is yet to be a YouTube video showing this method, they usually tell you to put the foam in "any hole you see". The hole I mentioned is the root of the problem, zero rattle ladies and gentlemen. |
The Following User Says Thank You to scottryan For This Useful Post: | Ultramaroon (10-28-2018) |
10-28-2018, 04:59 PM | #31 | |
義理チョコ
The Following User Says Thank You to Ultramaroon For This Useful Post: | scottryan (11-12-2018) |
10-29-2018, 11:29 AM | #32 | |
Drives: 2015 Subaru BRZ Limited ISM
I stripped my interior and did a full damping/noise reduction treatment (Google sound deadener showdown for guides). It definitely cleaned up my interior of any creaks, squeaks, and rattles. I'm completely satisfied in that respect BUT highway speed wind noise is still an issue for me(60+mph). I might need more melamine foam coverage in the headliner as I only had enough to cover a piece. If anyone has successfully tackled high speed noise that would be good info. Under 60mph in cabin noise is well controlled after treatment.
11-12-2018, 10:52 AM | #33 |
Financial Distress
The Following User Says Thank You to scottryan For This Useful Post: | Ultramaroon (11-16-2018) |
11-16-2018, 07:32 PM | #34 |
Drives: 2018 Subaru BRZ tS
Keep the rear seat backs up. A lot of noise comes through from the trunk area.
11-16-2018, 08:43 PM | #35 |
I turn the tunes up until the window buttons start vibrating then turn it down just a hair
11-16-2018, 09:03 PM | #36 |
義理チョコ
The Following User Says Thank You to Ultramaroon For This Useful Post: | Leonardo (11-16-2018) |
Similar Threads | ||||
Highway vibrations??? | Fred Flintstone | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 7 | 04-09-2018 10:33 AM |
Guys only ! Have a laugh or two inside.. | Mikem53 | Off-Topic Lounge [WARNING: NO POLITICS] | 29 | 10-23-2014 11:07 AM |
Transmission Vibrations | Scavanger | Engine, Exhaust, Transmission | 2 | 09-22-2014 02:09 PM |
Anyone having problems with vibrations? | ShibaYuki | CANADA | 22 | 01-21-2014 09:06 PM |
Rattles & Vibrations | brian_c_m | AFRICA | 65 | 03-22-2013 03:07 PM |
