04-07-2018, 02:11 PM | #57 |
Drives: 2018 BRZ Limited, 2017 Sportage
215's on a car as light as the BRZ/86 are NOT skinny tires and are, in fact the REQUIRED size for this car. I do agree with the bulk of you, however, that the OEM Primacy tires are not performance oriented.
04-07-2018, 02:26 PM | #58 | |
pessimistic skeptic
04-07-2018, 04:05 PM | #59 | |||||
Glorious BRZ Master Race
Drives: Subaru Libird
04-07-2018, 08:20 PM | #60 | |
From a performance perspective for MY particular use, I get no real benefit from wider rims and tires. And again, a-hole comment aside, I said I LIKE your rims. They really look good on the car. I do honestly believe that people put wider rims and tires on a car to make it look more than it is. We have a 200 hp car, not a 500 hp car. The first thing "ricers" do is put on wide tires and lower the car. Next, they change the exhaust to make more noise. If it walks like a duck...... |
The Following User Says Thank You to rvoll For This Useful Post: | nikitopo (04-08-2018) |
04-08-2018, 02:02 AM | #61 | |||
215 is narrow relative to the size recommended by the OEM on their optional 7.5" wheels. 225 > 215. That's straight inequality math, not opinion. Assume stock 17x7 +48 as baseline to compare flushness: TRD 17x7.5 +43: (0.5"/2)*(25.4mm/inch) + 5mm = 6.35mm + 5mm = 11.35mm more flush than stock TWS 18x8 +44: (1"/2)*(25.4mm/inch) + 4mm = 12.7 + 4mm = 16.7mm more flush than stock TWS is 5.35mm more flush than TRD. That's more than a spacer. And millimeters count (I run a 3mm spacer for clearance). So you're saying a ricer changes their wheels for aesthetic purposes and there's a performance hit (though it can be neglected because their purpose is generally not for racing). They just want to cruise in style. Sounds awfully familiar... Quote:
I selected wheels/tires that flow with the body lines and don't care if the car is too light for its tires (though it's within 100 lbs. of a base 987 Cayman with similar power and same staggered tire widths). And tuned to the fully stock and quiet exhaust system. Toyota determined an optimal height for this car through prototype testing and VLN races then raised it for passenger vehicle mass production purposes (to clear city nuisances like driveways, parking blocks, etc.). Following 86 Chief Engineer Tetsuya Tada's height recommendation I lowered it on OEM parts so it "walks like a duck":
04-08-2018, 02:21 AM | #62 | |
Drives: '15 BRZ RA
Physics is just a science to model reality. If your model is wrong, then you change the model not the reality. This is why as noted before we need experiments and measurements to confirm the model. |
The Following User Says Thank You to nikitopo For This Useful Post: | rvoll (04-08-2018) |
04-08-2018, 09:59 AM | #63 | |
04-08-2018, 11:36 AM | #64 | ||
And the list goes on. Then there's the Griffon 86 tuned by TRD to set a Tsukuba lap record. 18x9.5 TWS wheels and 265/35 tires but weighed only 2161 lbs. http://www.trdparts.jp/griffon/spec.html
04-08-2018, 07:52 PM | #66 | |
Secondly, your calculation is in error. This is an example that mirrors the physics teachers you quoted before who lack real world experience and thus don't understand dynamic analysis. Wheels carry something called "tires". Tires stick out more than the wheels. Thus, it doesn't matter what wheel size you use because the poke will be based on the part of the tire/wheel that sticks out the most. You have a precise calculation but it does not mirror the real world. In fact, with the same width tire, the TRD rim will, in reality, be slightly more flush than your rim because of the offset. By the way, I see no reason not to put a 225 on either rim as it is well within the tire specs. That being said, if you put 215 on the 7.5" rim and a 225 on the 8" rim, then the section width difference is 0.4"/2*25.4 or 5mm. In that case, your 225 would be 4mm more flush. Because of the section width, however, if I do get the 7.5" rims, I'll probably also go for the 225's because they are a slightly better fit. And thus, I'll be a little more flush than you. And again, I think your wheels look great!!!! I liked them so much I did a search to see the price. I wouldn't have done that otherwise. If they would have been in the price range of the TRD wheel, I might well have been convinced. However, they cost twice as much and that is hard to justify given that they would both be almost just as flush.... |
04-08-2018, 08:09 PM | #67 | |
There are some situations where wide wheels make sense. For example, at high speeds you could have greater downforce which would affect the contact pressure. If you have more hp on a dry pavement, wider wheels "might" help to prevent wheel spin. But on a track with long straightaways, very wide wheels will kill you both with weight and resistance. All of that said, most of us don't race our cars at high speeds. Because of that, it is much harder to argue for lower profile, wider wheels because they reduce comfort and don't fare as well on roads that are not extremely flat. Again, tire selection makes a huge difference for most of us who don't race our cars. The reason many BRZ's are pictured with large, wide wheels is because that just looks sexy. A few years ago, one of my neighbors had a slammed Miata with 19" wheels. It looked sexy, but he had to replace his front bumper at least twice a year, could not ride on bad roads, and had to sit on a pillow because his butt hurt so much on rides longer than 15 minutes. And you are right, my problem is not with physics, but with the analysis and variables thereto.... |
04-08-2018, 09:43 PM | #68 | ||
Drive upgrades. Don't buy them.
04-08-2018, 10:23 PM | #69 | |
https://www.michelinman.com/upload/m...t-sport-4s.pdf So for a 215/45/17, the OEM spec, you can put it on a 7-8" rim. For a 225/45/17, you can put it on a 7-8.5" rim. But if I wanted to put on a 245/40/17, I could not put it on a 7.5" rim. The narrower the sidewall, the more limited your rim range will be. So on my 7.5" rim, I could go up to 235/45/17. Next time, read my posts more carefully.... |
04-08-2018, 10:46 PM | #70 | |
you dont know what youre talking about.
Similar Threads | ||||
FS: Brand New 2018 BRZ STI tS Parts. Wheels, BNIB D4S, Cosworth Filter | botbs | Canada Classifieds | 19 | 06-18-2018 07:36 PM |
Advan Wheels New Release for 2018 ~ RZ-F2 & TC-4 | Kami Speed | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 5 | 01-09-2018 05:13 PM |
2018 San Diego Auto Show! 86 (with TRD wheels, exhaust, lowering springs) and BRZ tS! | ERA | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 8 | 01-02-2018 08:13 AM |
2018 BRZ STI | raven1231 | FR-S / BRZ vs.... | 19 | 06-26-2017 11:39 AM |
Where are the 2018's ??? | ~el~jefe~ | FR-S / BRZ vs.... | 41 | 05-24-2017 12:03 PM |
