Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
11-06-2021, 04:26 PM | #1 |
Drives: 2020 Subaru BRZ
Head porting and flow numbers
I saw information concerning intake and exhaust flow from the stock head. But I can't find it now. Does anyone have any information on port flow. It seems I remember the intake was 257cfm but cant recall the exhaust
Also, If anyone has ported their heads and has flowed them, please share your findings please. I have opened up my intake ports to 232 cc from 210 cc. Most all of that volume was in the bowl and throat area. I opened up the exhausts as well but I haven't cc'd them yet. I'm expecting about a 10% increase in volume in the exhaust ports. Part of the reason for getting this information is so I can figure out if it would be worth regrinding my cams for extra lift. I think I can regrind the lobes moving the base circle toward the center of the cam shaft, shim the valves the amount the circle moved to gain .030 to .040" extra valve lift. But I really need to see flow numbers to help make that decision. There isn't anyone near me that has a flow bench. Thanks |
The Following 2 Users Say Thank You to Rabrooks For This Useful Post: | Irace86.2.0 (11-10-2021), Ultramaroon (11-06-2021) |
11-06-2021, 05:51 PM | #2 |
義理チョコ
I've never done this kind of work but I'm super interested in the topic. I'll get the obvious question about Piper cams out of the way. Why not those?
11-06-2021, 06:52 PM | #3 |
The Following User Says Thank You to Rabrooks For This Useful Post: | Ultramaroon (11-06-2021) |
11-06-2021, 08:17 PM | #4 | |
義理チョコ
11-07-2021, 12:20 AM | #5 |
I thought "porting and polishing" went out back in the 50s. -
Maybe I went out back in the 50s - |
11-07-2021, 11:47 AM | #6 |
Drives: JRSC BRZ SOLD
Pulled from couple sources hope this helps.
Stock Exhaust Flow @ .500 lift = 170 FBM Stage 1 & 2 Exhaust Flow @ .500 = 220 Stock Intake Flow @ .500 lift = 280 FBM Stage 1 & 2 Intake Flow @ .500 = 305 |
11-07-2021, 02:31 PM | #7 |
If I was going to port the heads I would go with cams. I would think you will see gains since the heads are the restricted part of our intake system.
11-08-2021, 03:44 PM | #8 |
That Guy
Drives: 2013 asphalt FRS MT
Where was a guy here years ago that flow benched his heads and was working on improving things. His claim was that the flow volume was high enough to support some crazy high power levels, but the flow rate was too slow. He was playing around with adding material in certain areas of the ports to increase flown rate. I have no idea what came of that.
11-08-2021, 05:55 PM | #9 | |
Drives: Crapcan
There is so much to porting including seat angle it is best just left to the pro's.
11-08-2021, 09:05 PM | #10 |
Drives: 2013 frs red
Usually raise the floor to increase airspeed and make the short turn radius a little bigger.
11-09-2021, 05:20 PM | #11 |
Drives: Dodge Patitas
Well, I say go for it. And I mean it in the best way possible. Sub'd.
The Following User Says Thank You to sato For This Useful Post: | Ultramaroon (11-09-2021) |
11-10-2021, 11:25 AM | #12 |
Drives: Q5 + BRZ + M796
I don’t know how much valve lift with duration is available before you get into interference issues with the head of the piston. From what I have read, there isn’t much material or thickness to the walls of the heads for porting. With that said, much of the gains are realized with a combination of parts. One of the critical bottlenecks are the valves. You might want to look into larger valves.
11-10-2021, 11:51 AM | #13 | |
Drives: Crapcan
11-10-2021, 12:43 PM | #14 | |||
https://86speed.com/hks-camshaft-fa2...CABEgL2YvD_BwE Quote:
Similar Threads | ||||
Porting the heads | Rabrooks | Engine, Exhaust, Transmission | 4 | 08-25-2021 10:48 AM |
WTB: OEM Mass Air Flow Sensor/Meter Assembly Air Flow Sensor | driftking96 | Want-To-Buy Requests | 0 | 02-16-2016 03:57 AM |
porting header | Mike Brz | Engine, Exhaust, Transmission | 0 | 01-25-2015 04:16 AM |
BRZ head lights -> JDM 86 head light conversion | BRZPDX | Cosmetic Modification (Interior/Exterior/Lighting) | 6 | 08-02-2013 10:47 AM |
Scion FR-S vs Mazda MX-5 Club Head-to-Head (Review and Video) | M-17 | FR-S / BRZ vs.... | 96 | 03-05-2013 02:40 PM |
