Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
01-07-2019, 01:31 PM | #1 |
Drives: 2014 Scion FR-S
New Owner. AT whine in high revs normal?
Im the new owner of a 2014 FRS Automatic with 29,000 miles on it and yesterday I took it out into the country side for a proper day of spirited driving. At high revs in Manual Mode and in Sport mode I could hear a distinct gear/transmission whine. Is this normal? Im guessing so as the car doesn't seem to have a lot of sound proofing. Also, having the engine sound piped into the cabin probably doesn't help either(I will be deleting the sound tube). Just figured I would ask if this was a normal sound before I call up the dealer and accuse them of selling me a vehicle with transmission problems. The car drives and shifts great. Cant really see how it would be low tranny fluid as the vehicle has had all of the prior service done at correct intervals and the fluid wouldn't even be changed until the 60, 000 mile mark.
01-07-2019, 01:41 PM | #2 |
Drives: 2014 GT86
Bought used? Are you sure, it is completely stock? After all, there might be some aftermarket bushings in suspension/transmission/engine, that may increase NVH/whine. Not familiar with ATs, but some of transmission mount bushings / rear crossmember and diff bushings added slight "supercharger alike whine" on my MT.
The Following User Says Thank You to churchx For This Useful Post: | Leonardo (01-07-2019) |
01-07-2019, 01:49 PM | #3 | |
Country Boy 4 Life
Welcome to the forum. Fellow Oregonian Removing the sound tube makes the cabin 3db quieter. It was one of my first mods. (And it's Free!) I have an AT. I would highly advise changing the fluid sooner. My car started to shift like crap at 45k. The salesman at the dealership said that I was doing the transmission fluid change early. (he tried to talk me out of it) So, I walked out into the shop and talked to the mechanic. He told me the fluid was dark and needed changed. My car drove great after the fluid change. I did it again at 75k. I drive my car pretty hard. I bet your car's noise is normal, but without actually hearing the noise, I am just guessing that it is because you say it drives good.
I LIKE TIRES! |
The Following User Says Thank You to Leonardo For This Useful Post: | VoltsFRS2013 (01-16-2019) |
01-07-2019, 02:54 PM | #4 |
Drives: Halo 86, '19
New 2019 AT; I get it as well. It's not very consistent but it seems more prone to whine after highway driving for a time. I also get the higher RPM whine when letting it fully go.
I think you're fine for the most part, I'm still getting used to the harmless odd noises myself which seem common in this car. |
01-07-2019, 03:21 PM | #5 |
Drives: 2017 toyota 86
The only time my AT ever "whined" was right after putting in fresh fluid in the diff after my FD swap break in period. but it would only happen at lower RPM when coasting down a hill. and it went away within 200 miles of driving. otherwise no real noticeable noise from the tranny, although car is only at 8k miles.
01-07-2019, 04:44 PM | #6 |
Drives: 2019 BMW ///M4
I had the same concern:
https://www.ft86club.com/forums/show...t=65412&page=2 Toyota Rep considered it normal.
N1rve
2019 BMW ///M4 - Alpine White | Sakhir Orange/Black Leather | M-DCT | Executive Package | 19" Black 437M Wheels | Carbon Fiber Trim | Sunroof | Active Blind Spot | Heated Steering Wheel | Adaptive M Suspension |
01-08-2019, 02:28 AM | #7 | |
Yes it is completely stock except for the K&N drop in filter I installed. |
01-08-2019, 02:32 AM | #8 | |
Thanks for the info on the fluid. I am coming up on the 30K service and will ask that they inspect the tranny fluid. Im not too concerned. It sounds normal to me but wasn't sure if the sound was normal for this particular vehicle. Might crawl up under the vehicle this weekend and check the fluid level for some piece of mind. Where about in Oregon? |
The Following User Says Thank You to darkslide18 For This Useful Post: | Leonardo (01-08-2019) |
01-08-2019, 02:34 AM | #9 | |
01-08-2019, 04:35 AM | #10 |
Drives: 2014 GT86
darkslide18: it's not so much level that needs to be checked (rather i doubt it wll be below required level) as oil state (which should be sent in lab to check state/contents .. but by then much simpler is just do flush/refill instead). Simply by time due temps some fractions in oil break up/degrade, and despite filtering, more crap like metallic particles get's in, and it starts to work less reliably/with more wear and such. Even if level is ok. Even if manufacturers (not sure the reason) often claim that oil is for the life of vehicle or simply too long change intervals, often it's advisable to replace oil way sooner.
01-08-2019, 12:02 PM | #11 |
Drives: 2014 Scion FRS (Asphalt)
I get this whine when my transmission is still cold in the morning and at high rpms. Changing the tranny and diff fluid did seem to make it quieter. But from what I can tell it appears to be normal. It's been doing this before and after I was boosted so it doesn't appear to be any form of damage.
AVO Stage 2 Turbo Build Thread
https://wheelwell.com/tyler-nguyen-1...014-scion-fr-s |
01-16-2019, 02:14 PM | #12 |
BAE
Drives: Asphalt FRS
When i had my auto brz, the whine came from low tranny fluid. It wasn't all the time but when i got around to checking the fluid... it was definitely lower than normal. I added fluid after that and everything went away. It also happens when i started the car after letting it sit overnight and if i didn't warm it up a little bit it shouldn't want to drive nicely either. Both things led to me checking the fluids.
Check the fluid / swap it anyway for piece of mind. |
01-16-2019, 09:25 PM | #13 | |
Drives: 2022' GR86 Premium 6MT
22' Toyota GR86 - Trueno Blue - M/T (CURRENT)
18' Toyota 86 GT Black - Moonslate Gray - M/T (SOLD) 13' Scion FRS - Ultramarine - A/T (SOLD) |
The Following User Says Thank You to VoltsFRS2013 For This Useful Post: | Leonardo (01-16-2019) |
01-16-2019, 09:37 PM | #14 | |
Country Boy 4 Life
It was 3 years ago... Um, it shifted like crap. Wait, I said that already. So, yeah, Like I said I changed the trans fluid the next time waaaay sooner. I have not experienced the crappy shifting in a long time. So, if you feel your car has changed in how it shifts compared to new... Chang your fluid, it's time. I use the paddles 1% of the time. I'm from the NEVER LIFT camp.
I LIKE TIRES! |
The Following User Says Thank You to Leonardo For This Useful Post: | VoltsFRS2013 (01-17-2019) |
Similar Threads | ||||
Revs stays high | Claymore | Engine, Exhaust, Transmission | 6 | 05-27-2016 02:09 PM |
High Pitch Whine? | 636 | Issues | Warranty | Recalls / TSB | 49 | 02-06-2016 12:32 AM |
Effects of driving at high revs daily | fidelacchius | BRZ First-Gen (2012+) -- General Topics | 30 | 08-22-2014 09:35 PM |
AT holding 2nd gear to high revs during a long left turn | EK_Golfer | Scion FR-S / Toyota 86 GT86 General Forum | 9 | 03-01-2013 10:35 AM |
AC cuts out at high revs. Cool feature? | Superhatch | BRZ First-Gen (2012+) -- General Topics | 9 | 06-28-2012 02:13 PM |
