08-05-2013, 11:58 PM | #785 | |
08-06-2013, 12:16 AM | #786 |
WUB WUB
Drives: 2013 Firestorm
That's where i'm lucky. I've got a friend who works for Lexus, so he should be able to get them for much cheaper than what it'd cost me to buy.
08-06-2013, 12:22 AM | #787 |
Professional Smartass
Drives: White Out FRS
Can anyone who has installed this kit on their own comment on install difficulty? What was the most difficult or tricky part?
If I missed this information somewhere I apologize. |
08-06-2013, 12:31 AM | #788 | |
AutoX-10/10ths every run
My notes to compliment the Innovate manual can be found here: http://www.ft86club.com/forums/showp...84&postcount=1
[ Delicioustuning | Counterspacegarage | RS-R USA | Cusco USA | SPL Parts | ACE Header | Stark Performance | Infinite Motion | Ciro Racing | Build thread:Here ] [ GR Corolla Core in White w/LSDs on wish list ] |
The Following 2 Users Say Thank You to whataboutbob For This Useful Post: | brybot (08-15-2016), post_break (08-06-2013) |
08-06-2013, 07:38 AM | #789 | |
Overall, most people with a little bit of mechanic knowledge should have no issues. It's a process but really any FI application is. I think it's pretty straight forward relative to other kits. There isn't anything you do that you ask why do I have to do this?
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread) |
The Following 2 Users Say Thank You to swift996 For This Useful Post: | brybot (08-15-2016), post_break (08-06-2013) |
08-06-2013, 08:56 AM | #790 |
Drives: 2013 SWP BRZ
If you take all the hoses prior to the install and lay them out by length, its very easy to see which one is which throughout the install and directions. You can even measure them if you aren't sure.
Have someone help you drop the supercharger down onto the top of the motor, because you have to go under the AC line and between the engine harness and it can be a little tricky trying to do that while leaning over and supporting it. Also I have yet to see one person not have to file down the alternator, so save yourself some time and just file it. I had to file it quite a bit to get mine to fit (I pulled it off 3 times and filed before it sat down without touching). Also the instructions don't say it, but when taking off/putting on the belt, grab a 14mm socket and set it to the right (to tighten the bolt). You have to pull the dynamic tensioner towards the driver side and it releases all the slack by pulling the pulley down. |
08-06-2013, 09:09 AM | #791 | |
Drives: FR-S 6MT
[ame="http://www.amazon.com/Gates-91132-Belt-Tension-Tester/dp/B000CRDLZM/ref=cm_cr_pr_product_top"]http://www.amazon.com/Gates-91132-Belt-Tension-Tester/dp/B000CRDLZM/ref=cm_cr_pr_product_top[/ame] Seems like you either have too much slack in the belt because of the tensioner.. Or your running up the side of the belt due to an alignment issue.. |
08-06-2013, 09:10 AM | #792 |
The 800 and 900mm seemed the same length and didn't measure to the correct specs. I don't think it was that intuitive. I've already provided some feedback such as placing a color dot or a clip/band that would uniquely identify them. Hopefully innovate can add something like that to improve the ease of install. A simple routing diagram would be helpful too.
08-06-2013, 09:28 AM | #793 |
I'm not saying a color chart or labels aren't a good idea, because they are, but all of them are distinctly a different size. the 800/900 are close, but the one is longer and I could tell just by looking at it without measuring anything.
08-06-2013, 10:10 AM | #794 | |
Grip>Slip
08-06-2013, 10:16 AM | #795 | |
Drives: 2016 Subaru WRX
-2016 Subaru WRX
-2013 Scion FR-S: Wastegated Vortech V3'd, E85 SOLD |
08-06-2013, 10:42 AM | #796 |
Drives: FR-S 6MT
I don't know how much deflection is normal or how much tension there should be. I'm sure it documented for stock and your setup.. Most SC have a dedicated pulley and belt for the drive system. But this system shouldnt be far off normal with the blower. Otherwise you either slip or put too much side load on the bearings of the other driven components. I was surprised they could turn that blower at max rpms without slippage on the serpentine belt.
08-06-2013, 10:52 AM | #797 | |
Grip>Slip
08-06-2013, 10:59 AM | #798 | |
Drives: FR-S 6MT
Similar Threads | ||||
Innovative ideas to increase interior storage capacity? | swift996 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-30-2013 10:45 PM |
AVO vs Innovative | diss7 | Forced Induction | 32 | 01-21-2013 06:15 PM |
Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 12:18 PM |
Technical topic sub-forums | OrbitalEllipses | Site Announcements / Questions / Issues | 1 | 07-17-2012 11:38 PM |
Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 05:14 PM |
