Old 12-12-2015, 09:13 PM   #1611
FR-Shred
FR-Shred's Avatar
Originally Posted by Pete156 View Post
No. You'll need coils. Back might fit. Front won't.
Any info on required camber? Not too many people are mentioning camber.. Like sure it will fit but I don't want some dumb amount of camber to make it fit.. > -2 would be ideal.
FR-Shred is offline   Reply With Quote
Old 12-12-2015, 09:15 PM   #1612
thunderlights
265's simply wont clear without spacers Not even with 0 camber.
Sent from my SM-G850W using Tapatalk
thunderlights is offline   Reply With Quote
Old 12-15-2015, 10:50 AM   #1613
FR-Shred
FR-Shred's Avatar
Everyone tells me different things.. The guy above said you just need coils you say spacers. Some one else said over -2 camber only. It's just too many cooks in the kitchen haha
The Following User Says Thank You to FR-Shred For This Useful Post:
stevemp5 (12-15-2015)
Old 12-15-2015, 02:33 PM   #1614
c4lvinnn
Drives: Toyobaruion
You do realize that those are just different options to "fix" the issue at hand right?
The stock struts are too fat/wide and will rub on the wheel/tire especially with 265.
Coilovers are thinner/narrower, thus giving you more inner wheel/tire to strut clearance.
Camber/crash bolts can move the strut and its angle towards the inside of the car, thus giving you more inner wheel/tire to strut clearance.
Spacers give you more inner wheel/tire to strut clearance.
What did we learn here?
You need more inner wheel/tire to strut clearance.
c4lvinnn is offline   Reply With Quote
The Following User Says Thank You to c4lvinnn For This Useful Post:
gMit (01-19-2016)
Old 12-15-2015, 05:54 PM   #1615
FR-Shred
FR-Shred's Avatar
But my question was with coils what kind of camber are people running, and a guy said "you need spacers or it'll rub" which doesn't answer the question on camber. Cause as we all know camber and spacers don't do the same thing.
So according to the few people that responded to me I need coils, 0 camber and spacers (mystery size, since that wasn't mentioned), and then you're saying they are all the same (which they are not) so pick one. Haha.
Spacers push the wheel out from the hub. Camber changes the vertical angle left and right. And coilovers will change the spring perch size basically.
If I do spacers more than likely the wheel/tire will be on the fender lip. Cause 9.5" wheels with neutral camber are right on the edge already, so that would then lead back to the original question of what camber are people running?
Old 12-16-2015, 08:26 AM   #1616
Bamsterman
Drives: 13' Scion FRS
I'm looking at running the same specs. From my understanding, you can NOT run a 265 tire with those wheel specs using stock struts. With spacers, it will stick out too much. You will need coilovers for the strut clearance. I don't know exact camber, but with coilovers probably around 1-2 degrees (correct if wrong)
Bamsterman is offline   Reply With Quote
Old 12-16-2015, 08:49 AM   #1617
swarb
Just read the first page on this thread. All your questions will be answered. It won't fit and 255 is still cutting it close.
The Following User Says Thank You to swarb For This Useful Post:
Jive Turkey (01-20-2016)
Old 12-16-2015, 09:46 AM   #1618
jlugo711
Drives: 2014 GT86
I run 18x9.5 +40 squared with coilovers. I have 245/35/18 in front and 255/35/18 rear. I have 1.2degree camber in front and 2.6 in the rear with adjustable LCAs (RSR specifically).
A child couldn't fit their fingers in the rear fenders.
jlugo711 is offline   Reply With Quote
Old 12-16-2015, 01:14 PM   #1619
c4lvinnn
Drives: Toyobaruion
Guys, it's really not that difficult. At all.
Get coilovers, adjustable top hats or crash/camber bolts and get your wheels. Adjust camber to your OWN car. Every car is different. There is no set in stone on what will or will not work given everyone has different thresholds of "does this look good" or "does this "fit""
However, a good basis and in generalization speaking. After you get coilovers and a way to add some camber up front, those specs will fit no problem.
Old 12-16-2015, 03:55 PM   #1620
Jayela
Drives: 2013 Nissan GT-R, 1985 Porsche 944
Hey everyone! Glad to join the club
I'm running Bridgestone Potenza RE-71R front:245/40R17 rear:255/40R17 on Gram Lights 57DR 17x9 +38 with RCE Yellows over stock struts.
Jayela is offline   Reply With Quote
Old 12-18-2015, 02:19 PM   #1621
mmmcambelsoup
mmmcambelsoup's Avatar
Drives: FR-S 10 series
ST coils, 265/35/18 on 18x9.5 et38
IG: @Lucky_FatPat
10 series // TRD x Turbo Build:
http://www.ft86club.com/forums/showthread.php?t=79474
mmmcambelsoup is offline   Reply With Quote
Old 12-18-2015, 09:44 PM   #1622
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
265 square? Geeze, that's like the porter house of meaty tires lol
The Following User Says Thank You to BigFatFlip For This Useful Post:
mmmcambelsoup (12-21-2015)
Old 12-20-2015, 03:26 PM   #1623
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
Why not run square 255s? Your creating extra under steer for no reason.
Old 12-20-2015, 04:09 PM   #1624
Scikotic
Scikotic's Avatar
Drives: 2014 FR-S Silver
Finally got some meats under my car! 255-35-18 on XXR 530 Flat black 18x8.75 +33 squared on Eibach Pro Kit. No rubbing or any other issues
Scikotic is offline   Reply With Quote
The Following User Says Thank You to Scikotic For This Useful Post:
Hicklinc (02-25-2018)
Winter Tire Review Thread (Please contribute) pastuch Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 344 03-13-2024 05:49 PM
Wheel Directory: Forgestar F14 18x8.5 +38/18x9.5 +38 ScionFR-S Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 97 09-09-2015 06:32 PM
Meaty rubber on flush spoke rims? red_comet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 06-14-2013 12:21 PM
Official wheel/tire fitment thread needed empower-auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-22-2012 01:40 AM
The Wheel and Tire Fitting Thread EvoFanatic Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 03-15-2012 03:05 PM
