Old 12-02-2015, 04:18 PM   #1597
showoff3civic
Drives: 2015 BRZ
Meaty Tire Thread
@FR-Shred - look at all my posts from previously.... It's all based off the same specs you're looking at except the stock strut question. And honestly you should do the drop first because the car looks really odd on big wheels
showoff3civic is offline   Reply With Quote
Old 12-02-2015, 04:23 PM   #1598
YamahaR86
JDM Vaping Stance Nation
YamahaR86's Avatar
Drives: 2013 White
Originally Posted by serial gixxer View Post
I will be swapping shoes but here she is as it sits at the moment. Enkei rs05rr 18x9.5+43 265/35/18 michelin PSS square.
What lip kit/side skirt is that?
YamahaR86 is offline   Reply With Quote
Old 12-02-2015, 04:28 PM   #1599
FR-Shred
FR-Shred's Avatar
I'm dropped on springs, just stock struts.
FR-Shred is offline   Reply With Quote
Old 12-02-2015, 04:31 PM   #1600
showoff3civic
Drives: 2015 BRZ
But you said you're going to get coilovers before the wheels?
I can tell you its a dramatic difference:
The Following User Says Thank You to showoff3civic For This Useful Post:
Hicklinc (02-25-2018)
Old 12-03-2015, 12:01 AM   #1601
serial gixxer
Varis
serial gixxer is offline   Reply With Quote
Old 12-03-2015, 11:13 AM   #1602
YamahaR86
YamahaR86's Avatar
Drives: 2013 White
Varis
Looks damn good. Never seen it before, only seen it on as a full blown varis.
The Following User Says Thank You to YamahaR86 For This Useful Post:
serial gixxer (12-03-2015)
Old 12-09-2015, 03:58 PM   #1603
zkahle
zkahle's Avatar
Drives: 2013 Scion FRS Asphalt
Sorry to thread jack as i only have 245's but they are stretched. Hopefully this hasnt already been asked before but I am sure it has, I just don't have the time to spend searching through the forums this week. As of right now I am running Ambit 18x9.5 +38 all the way around with 245/40/18 all around. I am lowered on Eibach SS springs. Love the way the car looks in the rear but I am going to need to add additional camber up front to make the wheels flush and minimize any rubbing. Do I have the clearance to add any additional camber up from or am i already to close to the stock suspension? Would love yalls opinion. I already purchased some whiteline camber bolts for the front for some additional camber, need an alignment ASAP.
Hook Em'
zkahle is offline   Reply With Quote
The Following User Says Thank You to zkahle For This Useful Post:
JMon85 (03-29-2018)
Old 12-09-2015, 04:57 PM   #1604
swarb
@zkahle others have mentioned that anywhere close to 1.3-1.5 camber(or more than 1 degree) will rub with those wheel specs. 245/40's are too tall. If you aren't sure, stick your phone under the car and take a video and you can see for yourself that you are already pretty close.
The Following User Says Thank You to swarb For This Useful Post:
zkahle (12-10-2015)
Old 12-10-2015, 12:30 AM   #1605
zkahle
zkahle's Avatar
This may be completely re****** but what about adding some small spacers, like 5-7mm to allow for more (-) camber adjustment or would that essentially do nothing since I'd be adding new more poke? Also what about adding adjustable top hats? If so what is a good brand that won't break the bank.... I'm already over Budget with the current set up.
Hook Em'
Old 12-10-2015, 03:28 AM   #1606
swarb
Studs only have room for 3-5mm spacers. That would help a little.
The smallest bolt on spacer is 15mm. You would have to do extended studs if you wanted more than 5mm.
Top hats do nothing except give you more camber adjustment than crash/camber bolts alone would. Over budget? You are in the wrong game. Slow your roll.
Like I said earlier, record a video with your phone under the car with a flashlight and see how close you are. The wheel cambers under compression.
You have 3 options.
1. Leave as is and get stock spec alignment. Or try your luck with camber bolts/spacers.
2. Spend money and buy full suspension. You wanna play with the big boys with big boy 9.5 width wheels? You gotta spend like a big boy.
3. Get smaller wheels.
I am done responding here. You have your options laid out for you. I would try spacers and camber bolts and go from there as it is the cheapest option. Good luck.
The Following 3 Users Say Thank You to swarb For This Useful Post:
LOLS2K (12-10-2015), Summerwolf (12-21-2015), zkahle (12-10-2015)
Old 12-10-2015, 08:15 AM   #1607
LOLS2K
/scion
LOLS2K's Avatar
Drives: '13 86 M/T
@swarb #2 was my favorite.
LOLS2K is offline   Reply With Quote
Old 12-10-2015, 08:25 AM   #1608
thunderlights
You could try the reverse of camber bolts, like add positive camber through the two bolts( this should give you more clearance) and fix your camber with an adjustable top mount. Again, this is only a theory, it might not work. You should just get tein flex z's, great option for low budget coils.
Sent from my SM-G850W using Tapatalk
thunderlights is offline   Reply With Quote
Old 12-10-2015, 09:45 AM   #1609
zkahle
zkahle's Avatar
Well thanks for the info @swarb even if it was brutally honest. Unfortunately as a undergrad student who works part time I don't have the money for all the "big boy" toys. Just trying to do the best with what I have. Thanks again.
Hook Em'
Old 12-11-2015, 11:56 AM   #1610
Pete156
I like to eat!
Question guys..
I'm looking at 18x9.5 +38 wheels and want to probably go 265 tires.. Will that wheel and tire combo fit stock struts? Will it work with my camber too?
No. You'll need coils. Back might fit. Front won't.
Pete156 is offline   Reply With Quote
The Following User Says Thank You to Pete156 For This Useful Post:
FR-Shred (12-12-2015)
Winter Tire Review Thread (Please contribute) pastuch Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 344 03-13-2024 05:49 PM
Wheel Directory: Forgestar F14 18x8.5 +38/18x9.5 +38 ScionFR-S Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 97 09-09-2015 06:32 PM
Meaty rubber on flush spoke rims? red_comet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 06-14-2013 12:21 PM
Official wheel/tire fitment thread needed empower-auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-22-2012 01:40 AM
The Wheel and Tire Fitting Thread EvoFanatic Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 03-15-2012 03:05 PM
