Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
05-12-2021, 03:22 AM | #1 |
Drives: 2017 subaru brz
Rear Sway Bar Looks Shifted?
Hi everyone. I went and got an alignment today and was told that my left rear camber is very out of spec. When I got home, I noticed that my rear sway bar was shifted to the left judging by the clean spots with no dust/dirt as you can see next to the bushings. Would this be normal after an alignment is performed?
I wanted to get some opinions on whether this is something the shop fcked up and in turn messed up my alignment or not? It just looks like the sway bar was freshly moved, but I'm no professional. I am also absolutely trying to figure out if the shop is to blame since pre alignment, they took my car out for what seems to be a test drive, but for lack of a better term, drove it like they stole it. They then proceed to damage my hood when working on the car. Hence I don't trust the tech's alignment job either. Anyway, here are my alignment sheet and photos of the rear sway bar. Thank you! P.S. My left rear strut appears to have a film of oil covering it. Is it blown? x.x |
05-12-2021, 09:44 AM | #2 |
The bar being slightly shifted won't be doing anything to the camber. You could probably use new bushings, but I also don't think it was damaged by the alignment either.
05-12-2021, 11:44 AM | #3 |
Drives: 2016 BRZ Limited
Sway bars shift, that's why the lock collars are there. Hopefully it's just worn out bushings like wparsons said, but if your left shock is shot I think it could let that side sit lower and thus get more camber. Go to a different shop and see.
05-12-2021, 03:47 PM | #4 |
Drives: '23 BRZ
They just adjusted toe. IMO -1.8 one side -2.3 other side rear camber isn't that big a deal. Camber isn't adjustable anyway, I wouldn't worry about it.
Likewise, sway bar can shift left/right, should wiggle itself into a neutral position if it moved. If they damaged your hood they should be responsible for fxing it of course |
05-12-2021, 03:48 PM | #5 |
Drives: '13 FRS - STX
Swaybar is supposed to move a little left to right so it doesn't get bound up.
Half a degree camber difference across the rear is not unheard of with stock control arms. Looks like a standard 86 alignment without aftermarket alignment parts to me. Edit, left rear is out of spec because the lowering springs add negative camber, probably would be about -1.8/-1.3 if you had brought it in before installing the yellows. |
The Following User Says Thank You to strat61caster For This Useful Post: | wparsons (05-13-2021) |
05-13-2021, 01:02 AM | #6 | ||||
05-13-2021, 08:22 AM | #7 |
Drives: '23 BRZ
Could be difference in error between two different alignment rigs, repeatability error, or could be the rear subframe has migrated a bit on its bushings. I don't think it's anything to worry about.
05-13-2021, 12:47 PM | #8 |
Rear suspension is contained within the subframe, subframe shifts don't change alignment.
05-14-2021, 12:06 AM | #9 |
My FL, RL, RR struts are getting replaced. I don't want one corner to have old suspension so I'll be replacing my FR myself for peace of mind. Blowing up already at 36k smh.
Should I replace the top hat/mount while I'm at it or save $60? I have no idea if these often wear out. |
05-15-2021, 11:59 AM | #10 | |
Regarding your camber difference in the rear, it is actually possible to install the rear shock/sprint assembly backwards. Unlike the front springs, when you set the rear springs on the ground you’ll notice they sit at a slight angle. If they are installed wrong you will lose camber. I have never really seen this addressed in any DIY guides as the rear springs and rear shocks have the same part numbers left to right, but one assembly needs to be installed in the opposite orientation as the other. |
The Following User Says Thank You to norcalpb For This Useful Post: | jflogerzi (05-17-2021) |
Similar Threads | ||||
OFT Unstable revs when shifted to R/D from Parking | powerwdp | Software Tuning | 20 | 04-28-2020 09:20 PM |
Money Shifted my car, should I be nervous? | norcalpb | Engine, Exhaust, Transmission | 11 | 12-31-2019 06:38 AM |
WRX rear sway bar: good front sway bar combo? | LerpK | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 12 | 11-11-2016 06:02 PM |
<FS> Perrin 25mm rear sway, Radium front strut, Cusco rear strut bar | mav1178 | Brakes, Suspension, Chassis | 2 | 07-21-2016 05:49 PM |
WTB: Rear sway end links or sway bar with endlinks | JoeBoxer | Want-To-Buy Requests | 1 | 08-03-2015 01:20 PM |
