Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
07-29-2013, 02:10 PM | #15 |
BUMP
Seems like there have been SOME (not saying it's a fact) reported issues with FA20Club, Motiv, and PLM. Can anyone confirm the rest? Perrin did a sneaky job of picturing their over pipe without a sway bar attached to the car. @PERRIN_Chris ??
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread) |
07-29-2013, 02:36 PM | #16 | |
Running a Whiteline 22mm bar up front. |
The Following 4 Users Say Thank You to FT-86 SpeedFactory For This Useful Post: |
07-29-2013, 07:09 PM | #17 |
Drives: 2014 Subaru BRZ
As long as you're using the factory header, or header that ends in the same spot as stock, with our overpipe and our swaybar, you will be fine. There isn't a ton of room there, so with an aftermarket header or different bar, it might not clear.
The Following 2 Users Say Thank You to PERRIN_Chris For This Useful Post: | swift996 (07-29-2013), whataboutbob (07-30-2013) |
07-30-2013, 09:20 AM | #18 |
I've ordered a Perrin over-pipe and will update with fitment on the hotchkis sway bar (25.4mm). I'm running the FA20club catted header so I'll cross my fingers on the fitment..hopefully it clears well. Being that close to engine heads I don't want the control arm or sway bar smashing into it under heavy compression of the suspension.
07-30-2013, 11:40 AM | #19 | |
Drives: White FR-S, 6M
07-31-2013, 09:33 PM | #20 |
The Following User Says Thank You to swift996 For This Useful Post: | Hotchkis (08-01-2013) |
08-01-2013, 01:05 PM | #21 | |
Drives: Firestorm fr-s
08-01-2013, 01:09 PM | #22 |
Nothing so far but have had it on for 12hrs.
08-01-2013, 01:10 PM | #23 |
The problem is not sitting still or at idle but when the motor is under load and it twists on the motor mounts. After adjusting I've got about a half inch of clearance now over the sway bar and its doing well under load in 1st and 2nd gear with no noises.
08-01-2013, 03:47 PM | #24 |
Update
Unfortunately after a further road test it does make contact with what sounds like the sway bar in 2nd gear from about 4.2k - 6.3k rpms and in 3rd gear for a little less time. This is under WOT. It's like if the pipe shifted the hump back about an inch it would be perfect. It's not violent but you can feel the vibration come up through the chassis.
08-01-2013, 03:53 PM | #25 |
You might try dropping down the brackets the sway bar mounts to like chutrain advised. Thats what I did yesterday. I spaced it down about 2-3 mm with 2 washers per bolt. I think what we've learned here is stay with a thinner solid sway bar when combining with an aftermarket overpipe
08-01-2013, 04:01 PM | #26 |
Drives: 2013 FRS
What size away bars are you guys running?
08-01-2013, 04:11 PM | #27 | |
08-01-2013, 04:14 PM | #28 | |
Similar Threads | ||||
Wheel Directory: Forgestar F14 18x9.5 +38 | empower-auto | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 28 | 12-26-2014 05:24 AM |
Motiv Concepts Overpipe + HFC, Overpipe + Test Pipe Specials! | MotivConcepts | Engine, Exhaust, Bolt-Ons | 96 | 07-19-2013 02:03 AM |
Body Kit with the most clearance? | Sambo FRS | Cosmetic Modification (Interior/Exterior/Lighting) | 7 | 06-20-2013 01:47 PM |
Driveway Clearance? | topazsparrow | Scion FR-S / Toyota 86 GT86 General Forum | 17 | 06-14-2013 11:37 AM |
BRZ front clearance | a2cpc | BRZ First-Gen (2012+) -- General Topics | 14 | 01-23-2013 07:38 AM |
