02-04-2021, 03:51 PM | #99 | |
Identifying as a Member
Drives: 2013 FRS LS1
In the midst of an LS1/T56 swap build page here or follow me on YouTube or IG.
ACT Clutches - APEXi - Buddy Club - Carbing - DBA - Diode Dynamics - Fidanza - HKS - ICT Performance - Project Kics - RPM Transmissions - SEIBON - Sikky Manufacturing - SPC - Tick Performance - TK Style - VERUS - VOLK - Whiteline Last edited by Tomm; 02-04-2021 at 06:49 PM. |
02-04-2021, 04:21 PM | #100 |
Drives: Crapcan
That seems pricey to me, the going rate in my area is around 700 depending on millage.
The Following User Says Thank You to NoHaveMSG For This Useful Post: | Tomm (02-04-2021) |
02-04-2021, 04:32 PM | #101 |
That’s ab what I’ve seen, cheapest I’ve seen is $795. Most I’ve seen is $1495. I err on the expensive prices.
ACT Clutches - APEXi - Buddy Club - Carbing - DBA - Diode Dynamics - Fidanza - HKS - ICT Performance - Project Kics - RPM Transmissions - SEIBON - Sikky Manufacturing - SPC - Tick Performance - TK Style - VERUS - VOLK - Whiteline Last edited by Tomm; 02-04-2021 at 04:46 PM. |
The Following 2 Users Say Thank You to Tomm For This Useful Post: | Irace86.2.0 (02-04-2021), NoHaveMSG (02-04-2021) |
02-04-2021, 05:17 PM | #102 |
Drives: Q5 + BRZ + M796
K24A comes in several varieties. Are we talking about the TSX K24A2? USDM or JDM? The price depends on the miles and condition and how dressed the engine is. Have you seen a fully dressed TSX motor with sub-80k miles and no broken components around $700? I’m sure that could be the case.
The Following User Says Thank You to Irace86.2.0 For This Useful Post: | CSG Mike (02-05-2021) |
02-04-2021, 05:45 PM | #103 | |
Drives: Crapcan
02-04-2021, 06:00 PM | #104 |
Drives: AP2 S2000, 91 Miata 1.8L Rotrex 5MT
You can get a good condition K24A2 for ~$700 no problem if you shop around. Can't say that about most other desirable engines...
2022 Hyundai Elantra N 6MT SCCA TT S3//Will be back in an 86 eventually
The Following User Says Thank You to Goingnowherefast For This Useful Post: | PulsarBeeerz (02-04-2021) |
02-04-2021, 07:05 PM | #105 |
In the end, the difference between $750 and $1500 still isn’t a big deal in the total price of the swap. The extra $300-750 is maybe 5% of the total cost.
The Following User Says Thank You to Irace86.2.0 For This Useful Post: | ninjan00dles (02-10-2021) |
02-05-2021, 01:29 AM | #106 |
Drives: 2017 Hot Lava 86
The kswap moves the trans back about 4 inches. With the IRP shifter it deletes the shifter carrier and we are just left with the shift rod, which was more than 4”, I feel like it was probably 6-8”. We should be able to run the IRP shifter with just a shortened shift rod. The shifter would stay in the same location and still be bolted to the chassis. I’m meeting with K Power soon to let them use my 2017 to check the CANBUS, I’ll ask some questions while I’m there.
The Following 8 Users Say Thank You to Ebush For This Useful Post: | Irace86.2.0 (02-05-2021), Jdmjunkie (02-05-2021), Lonewolf (02-05-2021), NoHaveMSG (02-05-2021), PulsarBeeerz (02-05-2021), Tomm (02-05-2021), venenon (02-05-2021), Wally86 (02-05-2021) |
02-05-2021, 07:42 AM | #107 | |
ACT Clutches - APEXi - Buddy Club - Carbing - DBA - Diode Dynamics - Fidanza - HKS - ICT Performance - Project Kics - RPM Transmissions - SEIBON - Sikky Manufacturing - SPC - Tick Performance - TK Style - VERUS - VOLK - Whiteline |
02-05-2021, 11:30 AM | #108 | |
Drives: Crapcan
This is in neutral. Sent from my iPhone using Tapatalk
02-05-2021, 01:09 PM | #109 |
That part isn’t what would be shortened, there’s a rod bolted to that, the rod goes from there to the actual shifter. If your able to, measure that rod and it will tell us if the IRP is able to be used. From what I remember, and from pictures online that rod is well over 4” long and looks like it could easily be shortened for the kswap.
02-05-2021, 01:18 PM | #110 | |
Drives: Crapcan
02-05-2021, 01:30 PM | #111 | |
02-05-2021, 04:02 PM | #112 | |
It has been a while since my transmission was out of the car or since I had a look at a picture, but you are right. It looks like they could make a custom carrier without welding or anything that accomodates the stock shifter or something like the IRP shifter. Specifically, this long rod could be replaced with a shorter rod:
Similar Threads | ||||
Rigid Industries SR-Series Pro Light Bar on my BRZ | Stang70Fastback | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 12-29-2019 03:13 PM |
Airlift from industries finest | J_Nasty | Member's Car Journals | 0 | 02-04-2017 01:59 PM |
Carbox Industries - Introduction | CarBox | CANADIAN Sales | 5 | 04-22-2014 01:22 PM |
86 industries | Duthebarber | Northern California | 70 | 03-28-2014 04:10 PM |
Another 86 Industries another bad experience | sikest | User/Vendor/Sponsor Reviews, Feedback, Comments | 3 | 03-13-2014 01:00 AM |
