CANADA Canada
Old 01-08-2015, 12:39 PM   #15
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
Drives: '13 Whiteout FR-S A/T
In cold weather like this I naturally let it prime twice. One of the things from my old Civic was that you had to prime it twice or else it wouldn't start below freezing (stupid, I know)
drewbot is offline   Reply With Quote
Old 01-08-2015, 12:39 PM   #16
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
Also, I'm assuming this is the OP's first winter - yes, the fluttering is normal when idling after cold start
Old 01-08-2015, 01:04 PM   #17
wparsons
wparsons's Avatar
Originally Posted by FRSBRZGT86FAN View Post
Don't boxer engines get piston slap when really cold?
Why would it being a boxer immediately mean piston slap?
Piston slap is from the piston/cylinder gap, and also related to R/S ratio, etc. The pistons don't care which way they're oriented compared to the car.
flickr
The Following User Says Thank You to wparsons For This Useful Post:
pushrod (01-08-2015)
Old 01-08-2015, 02:43 PM   #18
Originally Posted by wparsons View Post
Forget about cold starts, you *should* always let the pump fully prime before cranking the engine over. You can hear it if you listen, but if you wait for the fuel gauge to move to however much gas you have left that's typically long enough.
Holy crap I learned something on here!!!!!!
In all the years I have had "modern" tech cars I never once heard or thought of doing this and it makes so much sense!
Now of course if Ubersuber was still around then there would be a 1500 word essay disputing this but research usually showed Mr. Parsons was right anyway so I am going for it.
D_Thissen (01-08-2015), pushrod (01-08-2015), wparsons (01-09-2015)
Old 01-08-2015, 02:53 PM   #19
Thorpedo
The SquadWhisperer
Drives: '13 Ultramarine FR-S (STX)
I can hear light piston slap in mine when started in cold conditions. It's nothing to worry about. Just let it warm up before experiencing any sort of high load situation or high RPM.
2013+14+15 Atlantic Region Motor Sports Autocross STX Champion
2013+14+15 Atlantic Region Motor Sports Overall Autocross Champion
2017 Bluenose Autosport Club Overall Rallycross Champion
Powered by Great North Performance, Jani-King Canada, and OK Tire.
Thorpedo is offline   Reply With Quote
Old 01-08-2015, 02:56 PM   #20
adamg
Drives: brz
adamg is offline   Reply With Quote
The Following 4 Users Say Thank You to adamg For This Useful Post:
SLVRSRFR (01-08-2015), Tcoat (01-08-2015), Wilso (01-08-2015), wparsons (01-09-2015)
Old 01-08-2015, 02:59 PM   #21
Originally Posted by adamg View Post
Demandred7 (01-08-2015), SLVRSRFR (01-08-2015), wparsons (01-09-2015)
Old 01-08-2015, 03:35 PM   #22
SLVRSRFR
Drives: 2013 BRZ 6MT, 2007 WRX Wagon 5MT
I got some nice poppy back-fires and an uneven idle for a bit after starting this morning, and despite priming the pump, it was a longer crank than usual. but she fired up!
Does anyone else have the same issue of an annoyingly uneven idle when your defrost/AC compressor is on? I'll be sitting at a light with the defrost on, and the car will be idling nice and even, i hear the compressor kick on and the revs drop almost to the point of the car stalling (it actually shudders mildly), and then back to normal.
Doesn't really bother me while driving but when stopped, it's annoying and sounds like shit.
Also my A/C compressor noticeably and audibly "chirps" when it kicks on. Not quite "crickets" but similar, and loud enough that you can hear it in the car sometimes.
@bpennerz
SLVRSRFR is offline   Reply With Quote
Old 01-08-2015, 03:52 PM   #23
BRZZZZZZZZZZ
Car Nut
BRZZZZZZZZZZ's Avatar
Drives: BMW 335d, Toyota Echo RS, FRS
My car used to missfire when started from cold in anything under 5 degrees Celsius, when it was stock.
BRZZZZZZZZZZ is offline   Reply With Quote
Old 01-08-2015, 05:40 PM   #24
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
I only say this because this occurred on older wrxs
Old 01-08-2015, 07:27 PM   #25
I think we all have that.
In fact it seems so common I would be more concerned if mine didn't do it!
It is the subject of many threads and some people just can not face the fact it is just part of how these cars work.
Old 01-08-2015, 07:34 PM   #26
pushrod
Benched 86lb
pushrod's Avatar
Drives: Ultramarine FR-S
No, because I disconnected the power to the AC compressor so it never kicks on. I suggest you do the same. Takes 5 seconds; it's right on top of the compressor in plain sight. Just move the loose wire out of the way of the serp belt.
pushrod is offline   Reply With Quote
The Following User Says Thank You to pushrod For This Useful Post:
SLVRSRFR (01-09-2015)
Old 01-08-2015, 07:37 PM   #27
Pkush
So how do you "prime the fuel pump"
Teach me. I got push to start, simply push the button without having clutch pressed so everything lights up and give it some time before starting the engine? how long?
The last few nights we were at 0F so in the morning when I start the car and release teh clutch in neutral it did jump forward a bit and rpm fell from 2000 to 1500. and I do get the knock too. First 20 seconds after a cold startup. I'd say anything colder than 20F
Pkush is offline   Reply With Quote
Old 01-09-2015, 10:43 AM   #28
SLVRSRFR
Any issues with doing this? Just eliminates the A/C? Does the defrost still work as adequately without it?
@bpennerz
TPMS IN COLD WEATHER Scionshaun Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 11-20-2016 06:27 AM
Cold weather knocking during start ups. JDMenrique Issues | Warranty | Recalls / TSB 38 01-12-2015 11:53 PM
e85 in NY cold weather whitefrs Forced Induction 5 12-10-2013 09:52 PM
White Smoke cold start up in Cold Weather (turbo cars) whitefrs Forced Induction 17 09-25-2013 05:05 PM
rattling in cold weather mezdup Issues | Warranty | Recalls / TSB 2 01-22-2013 09:32 AM
