01-30-2020, 01:04 PM | #65801 | |
Drives: Crapcan
Cylinder #5 missfire. I have replaced the coil. Verified power to the coil on the harness. Verified pulse signal from the PCM to fire the coil. Checked spark with coil out. Swapped coils with known working cylinder. Swapped injectors with known working. Tested injector. Verified power to the injector on the harness. Verified pulse signal from PCM to fire the injector. Still missfires. Comp and leakdown is next |
The Following User Says Thank You to NoHaveMSG For This Useful Post: | p1l0t (01-30-2020) |
01-30-2020, 01:14 PM | #65802 | |
Sent from my SM-G975U using Tapatalk |
01-30-2020, 01:34 PM | #65803 |
Drives: Crapcan
@Ultramaroon @soundman98
Alright I know there are people that are way smarter then me on this, and well, in general Each one of these heating panels is about 2100 watts and pulls 4.2-4.5amps. On leg one I am pulling about 36 amps in this zone. The manufacturer says it should be 55-60. I don’t see how the heck that’s possible. He also says if I loose some panels it will put more load on the others. But from my understanding the panel can only draw what it can draw regardless of what the other panels are doing. Am I crazy here? |
The Following User Says Thank You to NoHaveMSG For This Useful Post: | korhun (01-30-2020) |
01-30-2020, 01:35 PM | #65804 |
¯\_(ツ)_/¯
Drives: '15 ultramarine
The Following 4 Users Say Thank You to Sapphireho For This Useful Post: |
01-30-2020, 01:53 PM | #65805 | ||
So unless they’re clueless, which I don’t believe is the case, then it’s gotta be something else.
Instagram: @spike.brz
The Following User Says Thank You to spike021 For This Useful Post: | humfrz (01-30-2020) |
01-30-2020, 02:01 PM | #65806 |
Database error
Speaking of being smart, I have no idea what your are asking. All I can see is 2 buts, and 2 cemetery stones.
The Following 7 Users Say Thank You to korhun For This Useful Post: | cjd (01-31-2020), Dadhawk (01-30-2020), NoHaveMSG (01-30-2020), p1l0t (01-30-2020), ScoobsMcGee (01-30-2020), soundman98 (01-30-2020), Ultramaroon (01-30-2020) |
01-30-2020, 02:27 PM | #65807 | |
義理チョコ
01-30-2020, 02:30 PM | #65808 |
義理チョコ
line filter, current sensing, isolation, ...whatever those devices are.
The Following 2 Users Say Thank You to Ultramaroon For This Useful Post: | NoHaveMSG (01-30-2020), soundman98 (01-30-2020) |
01-30-2020, 02:33 PM | #65809 |
義理チョコ
The Following 5 Users Say Thank You to Ultramaroon For This Useful Post: | korhun (01-30-2020), p1l0t (01-30-2020), ScoobsMcGee (01-30-2020), soundman98 (01-30-2020), spike021 (01-30-2020) |
01-30-2020, 02:36 PM | #65810 | |
humfrz Last edited by humfrz; 01-30-2020 at 03:14 PM. |
The Following 2 Users Say Thank You to humfrz For This Useful Post: | p1l0t (01-30-2020), soundman98 (01-30-2020) |
01-30-2020, 03:43 PM | #65811 |
Junior Senior with Cheese
Drives: 15 BRZ
The Following 4 Users Say Thank You to ScoobsMcGee For This Useful Post: |
01-30-2020, 04:01 PM | #65812 |
Drives: 15 BRZ
So if anyone wanted to know what passes for a legit stop sign in York, PA. Here ya go.
The Following 5 Users Say Thank You to ScoobsMcGee For This Useful Post: | korhun (01-30-2020), NoHaveMSG (01-30-2020), p1l0t (01-30-2020), Spuds (01-30-2020), Ultramaroon (01-30-2020) |
01-30-2020, 04:18 PM | #65813 |
The butts are coils for the control relays.
The stones have their connections not shown so could do anything. The pink heaters are two in series but have no values so V=IR needs one more value to be calculated. |
The Following 2 Users Say Thank You to ls1ac For This Useful Post: | p1l0t (01-30-2020), soundman98 (01-30-2020) |
01-30-2020, 04:23 PM | #65814 |
Glad you had more than the first pic since I thought you had the only area in PA with no trees!
The Following User Says Thank You to Tcoat For This Useful Post: | ScoobsMcGee (01-30-2020) |
Similar Threads | ||||
Language Rant Part Deux | MuseChaser | Off-Topic Lounge [WARNING: NO POLITICS] | 43 | 04-23-2017 07:55 PM |
Random thoughts thread | MrVito | Off-Topic Lounge [WARNING: NO POLITICS] | 37188 | 02-25-2016 10:00 AM |
Random Rubber Part | OoLong | BRZ First-Gen (2012+) -- General Topics | 8 | 01-28-2014 10:31 AM |
Crew Carshow : Part Deux 9/7/13 | saiyajinimports | Great Lakes | 0 | 08-17-2013 05:18 AM |
