Tracking / Autocross / HPDE / Drifting What these cars were built for! |
01-20-2022, 11:46 AM | #29 |
Drives: Crapcan
It is something that becomes more evident when you try a stouter pad like the CSG's. I didn't know what it was when I had the XP10's, but when I went C1's it became evident what was going on.
01-20-2022, 01:10 PM | #30 | |
The increased bite is from having more mechanical torque from the increased radius of the force applied. a 2 piston floating and 4 piston opposed caliper apply identical force, assuming the pistons are sized identically. Each force has an equal and opposite (normal) force. On the 2 piston oem caliper, this opposing force is applied by the other side of the caliper without pistons. |
01-20-2022, 02:10 PM | #31 | |
FNG
Drives: 2013 Subaru BRZ
As for my example, I'm running 6 piston BBK and the layout and size is definitely different than the stock 2 piston. Also, the greater dissipation of heat due to the larger friction surface of the rotor is a key difference in "feel" as well. It may react the same at the limits of each respectively it's just that you won't reach those limits at the same time. I know I'm preaching to the choir though. |
01-20-2022, 02:24 PM | #32 | |
Drives: Crapcan
Brake pad recommendation
My comment on the feel of the C1's vs XP10's was on BBK. XP10’s after about 6 days. Maybe as many as 8, I don’t recall. C1’s did over 12 track days and still have the original paint on the backing plates. Front C1’s still had just under 1/4 inch left.
The Following User Says Thank You to NoHaveMSG For This Useful Post: | RT-BRZ (01-20-2022) |
01-20-2022, 02:53 PM | #33 | |
- Use a hand caliper spreader tool that's normally used to retract pistons. Spread the OEM calipers by hand. - Note the amount the caliper flexes (tacos). - Repeat with the Wilwood. Note the diminished flex. - the average adult male has about 72lbs of force in their squeeze grip. Brake systems will be anywhere from 600-2000psi. - Imagine the additional flex with even a 10x increase in force. - Now, imagine how much less flex there would be in a stiffer caliper. Wilwood is among the softest aftermarket calipers, and still exhibits a significant increase in pedal firmness. The heat dissipation is only an issue if you're overheating your pads to begin with. Ideally you want the bare minimum dissipation without overheating for maximum thermal stability, which reduces crazing/cracking. Example of crazing on my brz when I used stock brake calipers. https://www.instagram.com/p/Bki4Vc_Ay5Q/ |
01-20-2022, 03:24 PM | #34 | |
Drives: 2022 GR86
1) At least some (all?) caliper spreader tools use leverage to multiply the force applied to the grip. Looking at my caliper piston spreader tool, I think it generates at least 5x force multiplications. 2) To futher make this more of an apples to apples comparison, a 40 mm piston is ~0.787 inches in radius, which makes it ~1.948 square inches of surface the brake fluid is applied to. 600-2000psi of pressure times 1.948 square inches times two pistons per side is ~2300...7800 lbs of force. |
The Following User Says Thank You to timurrrr For This Useful Post: | RT-BRZ (01-20-2022) |
01-20-2022, 03:29 PM | #35 | |
Drives: 2022 BRZ Limited
01-20-2022, 03:31 PM | #36 | |
The Following User Says Thank You to CSG Mike For This Useful Post: | RT-BRZ (01-20-2022) |
01-23-2022, 10:10 AM | #38 |
Drives: 2022 BRZ Limited on order
Quick update. Two track days last weekend on stock pads and fluid. Yesterday finished another track day. Six 20 minute sessions at The Ridge. This time had CSG C1 pads on the front and C11 on the rear with Motul 660.
No fading, great smooth predictable bite and release, and consistent all day. Would get into ABS easier but was easy to adapt to. Would buy again. |
02-25-2022, 12:19 PM | #39 | |
Drives: 2022 Subaru BRZ Limited 6MT
I consistently read positive reviews for track use on these pads but wondering if they'd be ok as street pads as well, wondering how they perform when cold. In the description on their website it seems to say they work from street to track, just wondering if you've tried these as street pads?
02-25-2022, 01:47 PM | #40 | |
Drives: '13 Whiteout
02-25-2022, 08:03 PM | #41 | |
Drives: 22 GR86
i looked for track day pads and couldn't find them, what model numbers are you using? thanks! back on topic: I talked to mike at counterspace garage and i'm going to try some GLOC R12s front & rear for my maiden track adventures. gotta pick some tires now, debating pilot sport cup2, NT01, proxes R888R, azenis RT600? |
02-26-2022, 10:37 AM | #42 | |
PST1124 Rears Amazon Carid Summit Racing The CSG pads I hear are better however I’ve been happy with these for now. Last edited by TommyW; 02-26-2022 at 10:53 AM. |
The Following User Says Thank You to TommyW For This Useful Post: | evanescent03 (04-17-2022) |
Similar Threads | ||||
Recommendation for GTA PDR? | 1Cor10:23 | CANADA | 12 | 11-08-2014 09:08 PM |
Brake pad and fluid install shop recommendation(south florida)? | becauseracecar1 | Southeast | 3 | 04-21-2014 10:32 AM |
FS: FRS OEM E-Brake (Emergency Brake) Hand Brake Boot | CamryDS | Interior Parts (Incl. Lighting) | 0 | 06-24-2013 11:26 PM |
Non LED recommendation for DRL | boredom.is.me | Cosmetic Modification (Interior/Exterior/Lighting) | 13 | 05-11-2013 05:34 PM |
Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS | Redline360 | Brakes, Suspension, Chassis | 12 | 01-05-2013 10:20 PM |
