Scion FR-S / Toyota 86 GT86 General Forum The place to start for the Scion FR-S / Toyota 86 | GT86 |
04-06-2015, 05:35 PM | #1 |
Drives: 92 Prelude
NEW OBD2 Smog test checking ecu for tunes!?
Anybody know if this will have a problem for Ecutek or OFT buyers?
Link here: http://alankandel.scienceblog.com/20...ade-with-star/
04-06-2015, 05:45 PM | #2 |
Thupercharged
Isn't this pretty much what they already do in many states?
Chicago is an OBDII test, they are only concerned with emissions readiness monitors. I've passed in 3 different cars, all with tunes/reflashes. I would be more worried about visual inspections, I think OBDII only tests are the easiest to pass
2013 FRS
Vortech V3 11psi Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300 2019 Series.Grey STI - Stage1+ SF |
04-06-2015, 05:50 PM | #3 | |
Drives: 92 Prelude
The Following User Says Thank You to jaorocks1 For This Useful Post: | adjusts (05-25-2020) |
04-06-2015, 05:54 PM | #4 |
i want to know too
04-06-2015, 06:00 PM | #5 |
Drives: 2005 Toyota Camry
Considering you're exempt until 2018 at the earliest.... why worry about it now?
-alex |
04-06-2015, 06:00 PM | #6 | |
Thupercharged
These features are rarely advertised as its sort of a touchy subject. I've passed all testing with tunes on the ecu, several times without cats, and usually some form of forced induction. They don't even pop the hood, they only want to read the emissions monitors and keep the line moving. This depends on your local area of course. No cats would fail a visual, and more than likely fail a true smog test with tailpipe sniffer. Check your local laws on emissions testing to see what they do. Most places even allow one or two monitors to be "not ready" so you can do some tricks to pass anyways.
2013 FRS
04-06-2015, 08:44 PM | #7 | |
Drives: '11 Cayman , '14 Camry, '11 Tacoma
And starting this year, all cars less than 3 years old with less than 70K will be exempt from all testing. |
04-06-2015, 09:36 PM | #8 |
LOL, CA. That crap spreads, unfortunately.
WTH is this: Breitler noted, “The need for change is clear, officials say. A 2009 audit found that 19 percent of cars that initially passed a smog check ended up failing a roadside inspection within a year.” |
04-06-2015, 09:38 PM | #9 |
Drives: Slow
OBDII scan only testing works out great if you have a modified car or your income depends on car related repairs.
The Following User Says Thank You to civdaddy For This Useful Post: | adjusts (05-25-2020) |
04-06-2015, 10:35 PM | #10 |
Drives: FRS,09 370z, 00 CelicaGT-S, 85 300Z
My 09 370z has a uprev flash. It passed fine.
Similar Threads | ||||
Will headers cause me to not pass smog? | 67corvette | Engine, Exhaust, Transmission | 39 | 11-13-2018 11:12 AM |
CA Smog for Milltek Exhaust | Decisis | Engine, Exhaust, Transmission | 6 | 01-09-2015 07:58 PM |
Smog stock air intake | davebrus | Northern California | 6 | 05-12-2014 12:42 PM |
Smog & Tunes? | fooddude | Software Tuning | 5 | 04-14-2014 04:18 AM |
SMOG Issues | SkullWorks | Engine, Exhaust, Transmission | 8 | 10-04-2012 01:23 PM |
