Member's Car Journals Car journals by our members. |
09-24-2016, 06:01 PM | #57 |
Drives: RX-7 / BRZ
Been next to nothing on this car all summer. After the DI seals failing I was graced with my cat (front pipe) burning up causing issues and my Exedy S2.5 clutch began to start slipping. After throwing on serious rubber it quickly became the weak point. I can still drive it but, I've had to stick to the lower power maps and try to keep out of boost in 5th gear. I'm still weighing options. I was sure about going twin disc until I heard the godawful noise of it in person. I still daily the car so I'm taking a bit of time to figure out what clutch of get. I'm also looking at the FX400 and SouthBend S3 Endurance.
Also have temporarly given up on buying a hood. After my first Varis hood being damaged and not wanting to wait another 6 months I ordered the Black-Ops Hood (viper look-a-like) only to have that ordered cancelled as it is no longer in production or being produced. :/ I'm still not inlove with the Tracspec of Velox vents, I likew them on a dark car but, not on lighter colors or WRB. Welp, guess this mean's it's time to bust out the fiberglass and make my own. Maybe attempt carbon when I get there but will see how the plug turns out and how well my mold does. I've decided to go with a design similar to the STI's BRZ GT300. I figure they've already done more R&D on the duct placement than I care to and I've liked it from the get go. Grabbed a hood from a buddy and began measuring/plotting and cutting. The aluminum is like butter! So far everything is pretty tight when on the car but, just barely clears the turbo and intake tube. After figuring out the depths I'll tack some aluminum rod in to hold the vent's at the correct depth and begin designing and shaping the missing pieces. Once that's done I'll break out the clay and begin sculpting some smooth transitions.
//2018 Crystal White Pearl BRZ Ts 2.2l Harrop Supercharged |
The Following User Says Thank You to Kiske For This Useful Post: | DustinS (06-04-2018) |
05-30-2018, 07:04 PM | #58 |
Drives: 2017 86
Where did you get the JDM BRZ Ts GunMetal OEM Interior Trim Set?
05-30-2018, 07:45 PM | #59 |
Drives: 2016 Scion FR-S
Really curious about where you sourced that grill material? I've been looking for something similar for my FRS to get more airflow.
05-31-2018, 10:07 AM | #60 |
Drives: 13' DGM Built FBM BRZ
I remember seeing this thread years ago, I hope there is still progress going on! Making me want to start a thread of my own.
06-01-2018, 06:53 PM | #61 | ||
Drives: RX-7 / BRZ
The car blew up, burned down and has been sitting in my drive way since.
Similar Threads | ||||
2013 brz automatic borla header catless down shifting problem from 3rd to 2nd. | rjgough95 | Issues | Warranty | Recalls / TSB | 4 | 10-27-2014 03:37 PM |
Torque app problem | Mikeez | Issues | Warranty | Recalls / TSB | 20 | 10-25-2014 04:12 PM |
BReeZy - Juliette's 2013 Subaru BRZ | llama_au | Member's Car Journals | 11 | 05-04-2013 07:21 AM |
Garage Life: We bring your dreams to life! | Garage Life | Southern California | 0 | 08-17-2012 07:33 PM |
2013 Dodge Dart first real life photos and accessories/engines/transmission list | Aeghtysix | Other Vehicles & General Automotive Discussions | 1 | 01-09-2012 10:12 AM |
